Need advice: Elevating a Prius for storage during hurricane season
Discussion in 'Gen 3 Prius Main Forum' started by jmann, Aug 22, 2025.
  1. jmann
    jmann Member
    201
    30
    Cleveland, OH
    I'm moving my 2012 Prius to Florida for seasonal family vacation home use. For summer on-site storage, I need to keep the underbody of the car around 20-24 inches above the garage floor. The car has little value. I do not want to buy a lift that costs more than the car.
    Ramps would be easy, but I would need to make custom ramps of 16-20 inches and in multi-piece segments in order to clear the underbody of the back wheels when driving up.
    Lifts generally would cost more than the car.
    I don't think I can fit a ramp with lift under the Prius's back wheels. And I fear it would be too complicated for others to use.
    An ideal solution would be a ramp platform, but I need to find one and account for the bottom of the car car clearing the corner at drive-over height. This results in a very long required drive-up ramp to the platform.
    My idea of an ideal solution would be a platform you drive onto and then pivots under the car weight to go from slanted to level. while still being light enough to move and store in season. ..... This is cool, but it is probably heavy and unafordable Ramps | Podium Car Display Ramps for car dealership
    I can figure out how to make use of loading ramps on some way like these: Stalwart Set of Two 69-Inch Loading Ramps with 2200lb Combined Capacity - Walmart.com
    Or a large platform that sits propped up at 20-inches in the front the car drive onto. Then I use a single jack to lift the back and put stands under the two back corners.
    Has anyone in the south solved this? What are your suggestions?
    #1 jmann, Aug 22, 2025
  2. ASRDogman
    ASRDogman Senior Member
    7,524
    3,891
    Regular ramps for the front, they jack stands for the rear...
  3. Leadfoot J. McCoalroller
    8,056
    7,537
    Pennsylvania
    2018 Prius c
    Why not build a ramp and false floor for the garage space? Just set up a deck at the correct height, build some ramps that lead up to it. Maybe even just make that a permanent feature of the garage? Done right it would work for any car, not just the current one, and it still wouldn't be that expensive.
  4. bisco
    51,801
    keep in mind that old hybrid batteries don't like to sit unused
    Danno5060 and Grit like this.
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Egr?
  6. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Jack stands on all fours, raMPs off balances the car and pressure points
    Off to the front or back is no good
  7. jmann
    jmann Member
    201
    30
    Cleveland, OH
    the best answer would be car lift ramps like this, but I can't find any, and I suspect that this is a several thousand dollar solution (No accessories that cost more than the value of the car), not a few hundred dollar solution.
    The basic design you see in the picture above is that the ramp pivots on one side. You drive onto it and then use a jack to lift the front end and drop down the supporting feet that hold the front side up.
    though it may be possible to rig up something of equivalent utility using 3000 lbs rated loading ramps combined with other bits and pieces.
    And to add to the requirements, my can't-follow-instructions; love-to-complain; forgot-details-are-important boomer parents need to be able to operate the solution in my absence. Anything with more than one step in the process is an issue.
  8. jmann
    jmann Member
    201
    30
    Cleveland, OH
  9. Mendel Leisk
    41,243
    How sure are you about this? Is this going to to be gradual welling of water, or could there be a sudden surge? The numbers are based on historical data? Would there be room on the property for a raised berm with a ramp, and maybe a tent-port?
  10. jmann
    jmann Member
    201
    30
    Cleveland, OH
    My observation is that we have not had more than 16 inches of water above slab height (except for the big hurricane three years ago, but this a different type of problem). This level of surge flooding occurred twice last season. Target height for the garage slab is to get the car 20-24 inches off the garage slab based on short term location specific observation.
    Prius clearance height is already 4 inches, so I'm probably looking for 18-20 inches in a solution.
    And yes, I realize that in the absence of any other solution, I could use concrete blocks ($1 each) and loading ramps $200-ish if the car won't bottom out on drive-over transition.
    #10 jmann, Aug 23, 2025
  11. ASRDogman
    7,524
    3,891
    You could install an electric lift, then you could raise the car 6 feet.
    And you'll be able to work on it also.
  12. jmann
    jmann Member
    201
    30
    Cleveland, OH
    we don't even have 7ft clearance in the garage.
  13. ASRDogman
    7,524
    3,891
    oh, well I didn't know that.....
  14. jmann
    jmann Member
    201
    30
    Cleveland, OH
    those garage scissor lift could be fine if i can get one from the second hand market at a reasonable price (like under $500)
    But I don't know if leaving the car not on the suspension for long periods of time is a problem, nor if the several hours of salt water that the wheels, brakes, and bearings would be sitting in during flooding would be a problem.
    I also think the baby boomers wouldn't be able to operate it.
  15. jmann
    jmann Member
    201
    30
    Cleveland, OH
    this photo shows the flooding from the first flood last year. The second flood may have been two or three inches higher. But this is our house specific storm surge level during hurricanes.
    there isn't anything we can do about the big hurricanes, but the little hurricanes and storm surge from those, the goal is summer storage a little bit above this height.
    And yes, the alternative is to park off-site in storage closer to the airport. In some ways that could be more coinventing, but in many ways it is less convenient, more prone to theft and weathering, and has more variables.
  16. ASRDogman
    7,524
    3,891
    My brother has one of those. It works great. Not hard to use either.
    Storage can be tricky. He stands them up on either side of the garage door, they are
    heavy, he's not strong, but he does it.
    You could always use it to raise the car, then put jack stands under the car, then lower it.
  17. jmann
    jmann Member
    201
    30
    Cleveland, OH
    good feedback. Thank you.
    ASRDogman likes this.
  18. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Every one here believes we all have a 3 car garage and can DIY our garage way out of car mechanic shop fees
  19. Mendel Leisk
    41,243
    It’s inalienable right: life, liberty, and a 10’ ceiling garage with lift! :)
  20. ASRDogman
    7,524
    3,891
    Since he didn't say anything about how high the garage was, no one knew.
    If someone doesn't give ALL important information, you won't get good solutions....
