Oil change advice (just coming off original maint plan)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Dave deBronkart, Apr 24, 2025.
  1. Mendel Leisk
    40,961
    65 miles per US gallon is extremely good. Are you calculating, and considering the oversized tires? They will make the car underestimate distance travelled.
    Increasing the car’s ground clearance (obviously) increases air resistance as well.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,198
    782
    Monument, Colorado USA
    I love your red color in that AWD....my 2021 AWD Prius LE is Wind Chill Pearl and my wife knicknamed her "Minnie" (Only older folks get that.)
    She's (the car) my commuter car so has over 50,000 and I've done all my own maintenance....oil/tranny/both radiator and hybrid system coolants and even drained/filled the rear electric motor with new Toyota WS transmission fluid. I want to change out the PCV valve (every 50,000 miles) but found out I need to remove exhaust manifold to get to it so ordering new gaskets, first.
    Let me know if you have any questions about DIY maintenance. (And I use Valvoline 0W-16 every 5,000 miles, which is about every 4-5 months. I buy the 5-gallon Valvoline cartons off Walmart.com when they are on sale...latest sale was $116, free shipping, so that's just $23 a gallon.)
  3. Mr.Vanvandenburg
    1,344
    559
    2020 Prius Prime
    Mobil 1 0w-16 is the same price as 5w-30 or 0w-20. The filter is assumed the same. Most shops use bargain oil filters. I would use a better filter. DIY isn’t that difficult. Need ramps . I go 5k or less, the engines often don’t get warmed up properly. 10 k is too long imo.
    ColoradoBoo likes this.
  4. ColoradoBoo
    1,198
    782
    Yep, YZZN1 Toyota filters are often now sold right at Walmart...I keep a stash (fits the Prius and both Corollas...2008 and 2024...which is odd but handy)
  5. 97trophy
    97trophy New Member
    From what I have read hybrid engines are tough on oil, I would not leave it 10k miles per oil change.
    Iron Man Prius likes this.
  6. BiomedO1
    3,118
    1,653
    SacTown, Ca
    And they're cheap too; less than the bottom rung Fram.
    FWIW; that Toyota prepaid service was for 10K mile oil changes. I do 10K oil changes, but with 20K mile motor oil and Fram endurance filters. My understanding is that the 20K mile oil has a more robust additive package and the endurance filter is a bit more restrictive.than OEM. Since I've got a PHEV, I've conservatively calculated that I'm doing at most 7500 actual ICE miles, based on my 80% EV operations at the 10K oil change interval..
    I'm probably going to stock a few OEM filters, in case I can't get the Fram endurance filters on sale.
    YMMV
  7. Iron Man Prius
    Iron Man Prius Junior Member
    86
    22
    Fullerton
    Three Touring
    What's strange is, yes the speedo is now 2 mph SLOWER than actual speed (according to Google maps) BUT, when calculating distance my odometer/trip meter are dead accurate. If you can explain that to me, I am all ears. So, I think the 65 mpg (with no A/C) is mostly accurate. This is also hand calculated. I agree in theory the 1.5'' lift kit does add a minute amount of air resistance, maybe..none that I can detect since perhaps the LRR tires make up for it.
  8. ColoradoBoo
    1,198
    782
    Yep seems all my Toyota's MPH lies by about 2 mph.....says I'm going 45 but I'm really going 43. I suspect it's on purpose...better low than high.
    "Sir, do you know how fast you were going?" "No, ossifer, Toyota doesn't even know how fast I was going!"
  9. Mendel Leisk
    40,961
    Iron Man's saying is speedo is slower (aka lower?) than actual, which is the opposite of the usual.
    Speedometers read high on purpose, legislated by various authorities, in a mostly vain attempt to slow drivers down.
  10. Iron Man Prius
    86
    22
    Fullerton
    Three Touring
    Yes this is all because of the tire size (sidewall) difference. Now I'm showing 2 mph slower than what I am actually going but the odometer reads normal distance..crazy.
  11. Doug McC
    Doug McC Senior Member
    1,055
    402
    Midwest
    2022 Prius
    Perhaps, however it’s no more trouble to pour the required weight oil in than to pour a different one.
  12. Iron Man Prius
    86
    22
    Fullerton
    Three Touring
    And vice-versa...
  13. Mendel Leisk
    40,961
    What’s “required” is debatable.
  14. Doug McC
    1,055
    402
    Midwest
    2022 Prius
    OK, recommended then ;). Better be careful Mendel, you might get drafted by the current US Presidential Administration considering their strong opposition to the opinions of experts. ;)
  15. Mendel Leisk
    40,961
    Call it healthy scepticism?
    Toyota has varied the oil spec, for apparently same engine (same make/model), in different markets. Too, they seem to gamble some, when mpg achievements are involved: third gen rushed-to-production EGR and low-friction piston rings for example. Maybe they're gambling a bit with ultra-light oils too.
    And the language regarding oil weights: they recycle this paragraph, goes something like:
    The optimum oil for your vehicle is XXWXX. YYWYY may be used but change it back to XXWXX at half the usual interval
    All well and good, but they do this cut-and-paste exercise with that statement, always towards thinner oils.
