Catalytic Converter stolen, next steps?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by linuxgod, Aug 25, 2025.
  1. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    Someone stole the catalytic converter off my daughter’s 2013 Prius V Five last week while she was parked in the city. We have comprehensive coverage on the car, but after getting a $4900 estimate for a new cat, o2 sensor, and heat shield they damaged I’m expecting this to be a fight with the insurance company.
    The car is currently parked at the dealer because it’s my understanding that there aren’t many (any?) legit aftermarket options for the Prius V, and the dealer is TBH one of the few shops I’ve used around me that is honest. (Expensive, but honest).
    For those who have dealt with this before:
    1. what are the odds that Allstate is going to underestimate the repair cost and refuse to pay the dealer amount?
    2. What are the odds they’ll try to total the car? (Similar replacements seem to be about 10-12k private party for a Prius V Five with about 120k miles).
    3. What should I be wary of in this process? (Either with the insurance company or generally with the repair?)
    4. Any other advice?
  2. rjparker
    9,884
    6,092
    I think they won't total the car. They may refuse a dealer markup.
    Allstate is not great to start with but that dealer price is high since retail for a bolt on cat and exhaust heat recirc system is around $2k.
    I would expect a $2.5k to $3k offer could allow a muffler shop to install an oem cat and recirc system.
    There are aftermarket cat only suppliers like the Walker 16649 that will keep the light off. Assuming they left the recirc system. The concern might be for how long the Walker cat lasts especially if your v burns oil which is common. I have seen one Prius go three years and counting with a Walker.
    #2 rjparker, Aug 25, 2025
  3. BiomedO1
    3,154
    1,668
    SacTown, Ca
    Any high quality muffler shop can do this repair; but it depends on where they sawed it off and what's missing. I believe your in a CARB state, so that replacement need to be CARB compliant - which means OEM or 1-2 CARB compliant after market replacement. If the cost is close - I'd probably go for the OEM replacement unit. Check out the warranty on those aftermarket units. There may be some sort of 5 year or some mileage minimum warranty. Since it's a CARB mandated replacement - they're not allowed to give you a "tail-light" warranty. Verify with your states emissions rules and regulations.
    After the job is finished and if you opted for an aftermarket unit; I'd take it to a smog shop to make sure it passes inspection. Best to know now and get the shop to fix it correctly than find out a few years down the road. Ask me how I know about that one!!:whistle: Ended up taking that shop to small claims court for refund and reimbursement to get it redone correctly.
    Hope this helps......
    Allstate; the good hands people - unfortunately they are in your pockets and wallet.:(:eek::cry::LOL::ROFLMAO::whistle:
    linuxgod likes this.
  4. Air_Boss
    Air_Boss Senior Member
    4,167
    1,167
    New Yawk
    Three years ago at 110,000 miles, the cat on our 2005 Honda CR-V was stolen. Our insurance paid the claim for a Walker CARB compliant replacement.
  5. rjparker
    9,884
    6,092
    Illinois is not a carb state. On top of that, some carb states like Virginia have decided to disregard their carb state status which was great when it provided extra long standard warranties but not so great today if you are a politician.
    BiomedO1 likes this.
  6. BiomedO1
    3,154
    1,668
    SacTown, Ca
    If Ilinois is indeed NOT a CARB state; that dealership estimate was highway robbery!! Get several estimates at multiple muffler shops; the price will vary widely. Unfortunately, this is a pretty common thing. A tremor switch and CAT shield needs to be added to deter future incidents or just a simple alarm with a tilt switch - since thieves needs to jack up the car to get to the CAT.
    Ask about length of warranty on the job and if you have state mandated smog inspections; I'd get it checked out - to make sure the job was done correctly.
  7. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    Thanks. No they cut the recirc system. I mean it might be possible to loop the hose to bypass the need, assuming that doesn’t trigger a check engine light, but given the car only has 122k miles on it and is otherwise in good shape and it is insured I don’t really want to half nice person the repair.
    What aftermarket cats have folks had good luck with? I need more than the $500 walker cat provides. I’m also willing to fight with insurance to get one that will last for years… a 12 month solution is IMO a non-starter for a repair since everything was working fine before this and I’m reasonable confident the original would have still worked well for years.
    Photos of the carnage…
  8. BiomedO1
    3,154
    1,668
    SacTown, Ca
    Buy the OEM part and have a muffler shop install it. It's a bolt-on with two doughnut gaskets, need to by another down-stream sensor and the EGHE hose connections. Easy-peasy. about 1.5 hrs labor.
  9. rjparker
    9,884
    6,092
    Obviously you want oem if you can get it for the money they give you. However insurance companies know you are not a carb state and normally only price out aftermarket parts. If you find yourself in that position a Walker will work IF your car is not burning oil. 99% of the others will not work. It looks like the recirc system is still there if needed.
  10. ETC(SS)
    7,061
    If you insist on OEM parts, the above is good advice.
    I would NOT do this but rather I would get a quality aftermarket unit for about a third of the price.
    CARB compliance is not really at issue since the car is now 13 years years old - which means depending on how many miles a year it is driven you're probably going to be getting the Prius Death Rattle in a year or two anyway....or the replacement cat will be stolen.
    Why give them a new OEM unit to take off of a car that only has a few years left before the "change owner light" comes on?
    If I'm the 'good hands' people I'm only going to pay a claim like this ONCE, and I'm going to start thinking about an "it's not you......it's me" letter for the next incident.
    Good Luck!
    Drive Carefully!!
  11. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    Well shockingly to me, Allstate took a look today and approved the $4700 dealer estimate. All I owe is the $250 deductible.
    My agent says it’s considered no fault so it won’t affect my policy. Guess I’ll see if they drop me at renewal time in December though. Hopefully the fact that Allstate gets $10k/year from me for car + home owners insurance prevents that. In the last 15 years the only claim we’ve ever had was for a couple glass chip repairs
    next step one we get the car back will be to get a cat guard. I balked at the $480 dealer installed cost for that… pretty sure I can wrench that myself in the garage and the Miller guards look like they’re $160-220. Are those the preferred option? I see $90 eBay options but I assume those are thin (though maybe they’ll deter sufficiently anyway?) Also… aluminum or stainless steel… I’d assume the latter given aluminum is usually easy to cut and stainless will hold up better in Chicago salty winters but figured I should ask
  12. PTS
    PTS Member
    89
    39
    Austin, Texas
    2013 Prius v wagon
    Congratulations
  13. Paul Gregory
    Paul Gregory Senior Member
    1,976
    503
    Alberta
    2024 Prius Prime
    XSE
    Personally, I wouldn't replace it. I'd have the pipe repaired and anything else critical to running it.
  14. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    Do you live in a state that doesn’t do emissions testing? Straight piping it would guarantee it fails state emissions in December and leave my daughter without a valid registration.
  15. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    Thanks. Hopefully we can figure out a sufficient enough deterrent to prevent this from happening again…
  16. Paul Gregory
    1,976
    503
    Alberta
    2024 Prius Prime
    XSE
    That's right, I've never seen mandatory testing here.
  17. linuxgod
    linuxgod New Member
    Chicago, IL
    2013 Prius v wagon
    I think I’d be annoyed by a constant check engine light but if we lived somewhere without emissions testing I suspect my daughter would have done that and pocketed the insurance difference. Unfortunately Chicago tests every other year and you can’t renew your registration if you fail
  18. Paul Gregory
    1,976
    503
    Alberta
    2024 Prius Prime
    XSE
    You do what you have to do, and I'd do what I could do.
  19. Mendel Leisk
    40,983
    OP's got comprehensive insurance. His daughter's Prius v had an OEM catalytic converter. Now, thanks to thieves, they have to settle for a, cheap, this'll do replacement catalytic converter, that'll maybe only last a few years? That doesn't seem fair. Would a Toyota dealership even install aftermarket??
    Addendum: ok, water on the bridge, OP's insurance came through.
  20. Paul Gregory
    1,976
    503
    Alberta
    2024 Prius Prime
    XSE
    They never should have allowed China to corner the market on rare metals.
