Gen 3 ECM replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by IwasBirchyFirst, Aug 27, 2025.
  1. IwasBirchyFirst
    IwasBirchyFirst Junior Member
    27
    Dallas, TX
    I'm struggling to remove this module. Back bracket is trivial. I can't even see the bolt for the front bracket. Inverter coolant hoses and at least three harnesses are in the way, but I've nudged them enough to be able to see it. Nothing.
    I've tried loosening the two screws from the bracket to the module, but they stuck tight. I may have to grind off the heads and extract the remnants. Philips screws, hard to get leverage and to keep pressure on the driver. Even tried a Visegrips on the screwdriver shaft.
    Advice or even a pic of the bracket after extraction of the ECM would be helpful.
  2. Tombukt2
    12,908
    2,318
    I no longer have the Gen 3s but that thing comes right up out of they're . Need to take off the plug on top to
  3. Brian1954
    Brian1954 Senior Member
    2,167
    843
    South Central PA, USA
    It sounds like you will soon have two 2010 Pruii that will not be functional per the three different threads that you started. You definitely don't know what you are doing!
    Edit. Removed two redundant words in my first sentence.
    #3 Brian1954, Aug 27, 2025
    PriusCamper likes this.
  4. IwasBirchyFirst
    27
    Dallas, TX
    I already have that.
  5. IwasBirchyFirst
    27
    Dallas, TX
    Got it! Took two ppl, holding stuff out of way, and better light. I used Visegrips to break the screw heads free.
      File size:
      83.1 KB
  6. Brian1954
    2,167
    843
    It's likely to be worse after you try to "fix" it.
    Did you know that the engine control module (ECM) is very reliable and rarely goes bad? It is more likely that the throttle body is bad per the other thread that you started. https://priuschat.com/index.php?posts/3560048
    #6 Brian1954, Aug 27, 2025
  7. IwasBirchyFirst
    27
    Dallas, TX
    It ohm'd out at 3.6ohms. A spec from a different gen (2 I think) has max at 3.0, min much lower. I haven't found the repair docs for gen 3 yet, just the elec diagrams.
    Do you think that could cause the P2102 "Circuit Low" code? Is it that sensitive? I suspect it uses PWM, so maybe?
  8. ChapmanF
    18,101
    Brian1954 likes this.
  9. Tombukt2
    12,908
    2,318
    It's online free around . The steps for this should be on a video .I just changed the TB on a jdm engine to USA fed spec and all worked . My JDM TV was bad as shipped
