Sea-level doom from Antarctic melting
Discussion in 'Environmental Discussion' started by tochatihu, Sep 23, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,835
    450
    Alberta
    2024 Prius Prime
    XSE
    You wouldn't have to go back that far. I think they're finding evidence of a gigantic flood about 8000 years ago, that filled the basin that is now the Black Sea.
  2. Paul Gregory
    1,835
    450
    Alberta
    2024 Prius Prime
    XSE
    I think you might be off a bit; 700 million years ago, there were no dinosaurs or even any complex life.
  3. PriusTech
    PriusTech Member
    176
    89
    Reno
    66 million years ago the dinosaurs got hit with a meteor 6 miles in diameter going 65,000 mph. 112 mile diameter crater 19 miles deep. Covered with sediment today, discovered by oil exploration, the Chicxulub crater in Yucatan. 600 mph shock wave reached middle of the USA. 500 ft high tidal wave went all the way to Africa. Magnitude 10 earthquakes worldwide. Blast energy estimated at 72 trillion tons of TNT, 25 trillion metric tons of excavated material was ejected into the atmosphere by the blast . Molten rocks were splattered out into space and fell back to earth, some even escaped earth orbit. Firestorm burned 70% of plant life. Smoke and debris blocked sun for 5 to 10 years. 75% of animals extinct. Evidenced by a dark band of burn debris worldwide, the K-T boundary layer.
    #23 PriusTech, Aug 30, 2025 at 2:57 PM
  4. Paul Gregory
    1,835
    450
    Alberta
    2024 Prius Prime
    XSE
    I did not know that.
    PriusTech likes this.
  5. Mendel Leisk
    40,829
    Do you mean change to the tilt of the axis of rotation? I googled that the other day, and AI summary said it does change, mentioned glacier melt and intensive pumping of ground water reserves as factors.
  6. T1 Terry
    T1 Terry Active Member
    848
    434
    You don't think fact would get in the way of a good B/S story did you, never has before, doubt it will in the future.
    Those that believe and push these stories show a major flaw in their critical thinking education .....
    T1 Terry
  7. T1 Terry
    848
    434
    The shift in the magnetic poles has also been blamed, it causes the sun's active and calm cycles, maybe it could affect the earth's climate, or moving all the coal from one side of the planet to the other, only to burn it and make it lighter :confused: .... or is it the one thing they can measure, percentage of carbon and methane in the atmosphere and the corelation to rising sea temperatures and sea levels ....... but who would believe something that can actually be measure against wild theories born out of greed to not change the status quo and interrupt their money generating efforts they spent so much establishing and then denying they were causing any harm ..... sound familiar, sort of straight out of the tobacco industries' play book .... or is that still in denial as well .....
    Very hard to change anyone's deep down belief that they are smarter than everyone else ......
    T1 Terry
  8. Paul Gregory
    1,835
    450
    Alberta
    2024 Prius Prime
    XSE
    I doubt that all the resources the world could muster,
    would be capable of putting the world's climate into stasis.
