Sea-level doom from Antarctic melting
Discussion in 'Environmental Discussion' started by tochatihu, Sep 23, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    You wouldn't have to go back that far. I think they're finding evidence of a gigantic flood about 8000 years ago, that filled the basin that is now the Black Sea.
  2. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I think you might be off a bit; 700 million years ago, there were no dinosaurs or even any complex life.
  3. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    66 million years ago the dinosaurs got hit with a meteor 6 miles in diameter going 65,000 mph. 112 mile diameter crater 19 miles deep. Covered with sediment today, discovered by oil exploration, the Chicxulub crater in Yucatan. 600 mph shock wave reached middle of the USA. 500 ft high tidal wave went all the way to Africa. Magnitude 10 earthquakes worldwide. Blast energy estimated at 72 trillion tons of TNT, 25 trillion metric tons of excavated material was ejected into the atmosphere by the blast . Molten rocks were splattered out into space and fell back to earth, some even escaped earth orbit. Firestorm burned 70% of plant life. Smoke and debris blocked sun for 5 to 10 years. 75% of animals extinct. Evidenced by a dark band of burn debris worldwide, the K-T boundary layer.
    #23 PriusTech, Aug 30, 2025
  4. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I did not know that.
    PriusTech likes this.
  5. Mendel Leisk
    42,338
    Do you mean change to the tilt of the axis of rotation? I googled that the other day, and AI summary said it does change, mentioned glacier melt and intensive pumping of ground water reserves as factors.
  6. T1 Terry
    T1 Terry Senior Member
    970
    551
    You don't think fact would get in the way of a good B/S story did you, never has before, doubt it will in the future.
    Those that believe and push these stories show a major flaw in their critical thinking education .....
    T1 Terry
  7. T1 Terry
    970
    551
    The shift in the magnetic poles has also been blamed, it causes the sun's active and calm cycles, maybe it could affect the earth's climate, or moving all the coal from one side of the planet to the other, only to burn it and make it lighter :confused: .... or is it the one thing they can measure, percentage of carbon and methane in the atmosphere and the corelation to rising sea temperatures and sea levels ....... but who would believe something that can actually be measure against wild theories born out of greed to not change the status quo and interrupt their money generating efforts they spent so much establishing and then denying they were causing any harm ..... sound familiar, sort of straight out of the tobacco industries' play book .... or is that still in denial as well .....
    Very hard to change anyone's deep down belief that they are smarter than everyone else ......
    T1 Terry
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I doubt that all the resources the world could muster,
    would be capable of putting the world's climate into stasis.
  9. T1 Terry
    970
    551
    Keep in mind, A I just collects all the online data it can find and makes it's predictions from there. There are more armchair experts that make online posts than those who actually know what they are talking about.
    References to astrological measured changes would verify a shift of the earth's wobble that creates the season changes .... they seem to be rather thin on the reference list ......
    T1 Terry
  10. T1 Terry
    970
    551
    stasis
    /ˈsteɪsɪs,ˈstasɪs/
    noun
    formal•technical
    1. 1.
      a period or state of inactivity or equilibrium.
      "long periods of stasis"
    2. 2.
      civil strife.
    Civil strife is something the world can generate without much effort.
    Inactivity would be .... what exactly?
    So that leave equilibrium, how would that work, the climate in different regions of even a single country aren't in equilibrium, how could the climate in the whole world ever be in equilibrium? ....... it would certainly either end the ice caps and the permafrost, or we all freeze to death and there is no vegetation either, so we would starve if we didn't freeze ......
    Returning the climate to what it was previous to the industrial revolution, possibly achievable if the whole world was to work together, the likeliness of that ever happening ....... I believe no further comments are needed on that topic ... ;):rolleyes:
    T1 Terry
  11. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I have seen fantastic changes to the way we manage the environment over the last 50-60 years. That gives me great hope that we will address the problem of global warming by getting the carbon cycle under control.
    But by no means do I believe that we will be able to lock the climate into a static, unchanging state.
  12. T1 Terry
    970
    551
    The renewable powered carbon removal systems are already available, there is this one, and the saber method of converting hydrogen to methane saber method for converting hydrogen to methane - Google Search We already have the technology to converter methane to a liquid for transport, as well as storing hydrogen in ammonia hydrogen to ammonia conversion - Google Search for easy transport to eliminate burning fuels that produce carbon dioxide in the first place ..... but getting the will of govts to actually take any of these paths ..... yeah, never gunna happen
    There is even a method of converting carbon dioxide to hard carbon that could be either used for sodium ion battery use, or buried Decarbonisation tech instantly converts CO2 to solid carbon | Australian Research Council check the date, Jan 2022 .... heard anything about this idea from anywhere recently?
    T1 Terry
  13. ChapmanF
    19,015
    For what it's worth, I think sense 2 there is an example of an internet reference getting something exactly backward. I've never run across 'stasis' used to mean civil strife, and the idea would clash with the root meaning of the word.
    Webster's 3rd (which I still have on paper for when the SHTF) says this:
    3. a state of static balance or equilibrium among opposing tendencies or forces : QUIESCENCE, STAGNATION <at a point of ~ artistically and spiritually ... cannot develop any new creative activity — Harrison Smith>; specif : a state of stable and sometimes sterile equilibrium reached by a society : STAGNANCY <the essential danger of mass media ... lies in their ability to inflate existing consent to the point of a dull unanimity and so to achieve social and economic ~ — J. T. Klapper>
    So, roughly the opposite of civil strife, as you'd expect, from the root meaning of the word.
    I can see, on the other hand, how a period of 'stasis' could be followed by civil strife ....
    I wonder if the strange definition above might have come from some AI that slurped in a lot of writing where stasis was followed by strife, and kind of overlooked the one-follows-the-other part.
    #33 ChapmanF, Aug 31, 2025
  14. PriusTech
    264
    133
    Reno
    Here's what you're saying
    It's impossible for technology to advance further to a point where there's really cheap or even free energy
    Predatory capitalists that are worth $billions and have invested $billions and are making $billions from that investment wouldn't do whatever it takes to protect their business.
  15. bisco
    52,841
    i can believe that they would do whatever it takes, i just can't assign blame without proof
  16. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Some of the first submarines were powered by steam engines.
    The only limitations are our own paradigms.
  17. bisco
    52,841
    were they fully submersible?
  18. Mendel Leisk
    42,338
    Are the nuclear subs using steam turbines? A little different than an old-school locomotive, I appreciate...
  19. T1 Terry
    970
    551
    The first submarines, used pedal power I believe and was called the turtle pedal powered submarine used in the usa war of independence - Google Search
    I think I remember reading about a 3 person powered craft used in the civil war, also pedal powered
    The mini subs used in the war by the Japanese in Sydney Harbour, were battery powered Japanese midget submarine | Australian War Memorial
    T1 Terry
  20. bisco
    52,841
    lithium?
