Gen2 OBD2 app review
Discussion in 'Gen 2 Prius Technical Discussion' started by mr_guy_mann, Apr 25, 2022.
  1. priumium
    priumium Member
    104
    26
    Sweden
    It is not just possible, it’s also highly relevant I would say. This applies to all software. Updated apps are cared for by devs and improved.
    Many apps mentioned previously here are now abandonware, but still charge IAP. That’s not good for anyone.
    I also very much like that Carscanner has model profiles that anyone can update and contribute to. So if you know the adress of a sensor that’s lacking, it’s easily programmable to fetch that data. Highly recommended.
  2. priumium
    priumium Member
    104
    26
    Sweden
    (The CarScanner profile for Prius gen2 is actually very impressive, much more information than any other app I have evaluated. Some people (including reviewer?) does not select the correct profile and then end up with just basic OBD data…)
    #222 priumium, Aug 31, 2025
  3. ChapmanF
    18,078
    @mr_guy_mann, still have Car Scanner, able to comment?
    The review post from 3 years ago seemed to indicate not just a matter of individual sensor PIDs missing, so much as entire ECUs.
    priumium and Brian1954 like this.
  4. priumium
    priumium Member
    104
    26
    Sweden
    Interested for the reply. And with the latest version and the correct profile…
  5. priumium
    priumium Member
    104
    26
    Sweden
    My opinion is that this is the best for gen2 on iOS after testing many, many apps.
    What app do you recommend, ChapmanF..?
  6. ChapmanF
    18,078
    I haven't tested enough alternatives on gen 2 to be anyone you'd ask for a recommendation. mr_guy_mann has.
    The laptop I had Techstream on has let out the magic smoke, so lately I've been using the Autel AP200 based on the recommendation here, and I can confirm on my gen 3 it sees all ~ two dozen gen 3 ECUs and their data PIDs, and is able to do the most important things I used to do with Techstream.
  7. priumium
    priumium Member
    104
    26
    Sweden
    Ok. A lot of opinions about apps are confirmation bias and subjective. My focus has been to not lock up your app towards any special hw supplier or IAP with apps that then are left abandoned.
    (Clone the old ssd and apply image to a vm is my suggestion for your issue).
    I also have techstream on an old MacBook Air (intel..) and it works great.
    However, apart from programming smart keys, I would say with knowledge you can get any PID displayed in carscanner app if you know how-to.
    All other apps are locking these features behind pay walls. That is why I love and chimed in for Carscanner and recommend it to anyone with gen2 and a dongle (I use vlink) with iOS BT support.
    #227 priumium, Aug 31, 2025
  8. ChapmanF
    18,078
    That's my suggestion too. It's the shortage of round tuits that gets in the way.
    It is good to have an app with that flexibility—though with a dozen or two dozen ECUs in the car and each one having tens (some many tens) of PIDs, it can be an awful lot of work to configure such an app to be comparable to one that has them all out of the box.
    How practical that is kind of depends on what you want to use it for. If you want, for example, to display some preferred gauges while driving, it's not very hard to program in a dozen PIDs you want to see. That's what I've done with my ScanGauge II.
    If your car is malfunctioning right now and you want to start doing diagnosis right now, and you're not sure which PIDs are going to help before you see which ones are showing weird values, it never really feels like the time to be searching up programming details for a hundred PIDs.
    And even that assumes that the app will be able to establish comms with the specific ECUs in the car that have the PIDs you want to see. In gen 2 especially, where only some of the ECUs are on the CAN bus and others are on the BEAN or AVC-LAN and only can be reached by asking some other ECU with more than one network interface to relay messages back and forth, or by voltage-level signaling on Tc or Ts, that's where a lot of the apps fall short.
    It's easy to supply an app with a general way of entering PID info by ECU address, PID address, bit field, and arithmetic conversion, when all the ECUs are on a nice addressable bus where that works. Where that isn't the case, it's a lot harder to supply a general way to enter essentially new programming logic for whatever comm gyrations are needed to exchange messages with the harder-to-reach ECUs.
  9. priumium
    priumium Member
    104
    26
    Sweden
    True. That’s why the app is based on open modifiable profiles and not using IAP for every feature/monitor/ECU - as is much more common. Also it’s easy to get in contact with the developer which is a big plus in my book.
  10. ChapmanF
    18,078
    I'm interested in learning more about these open modifiable profiles. Is it possible to look at one?
    The website I found is carscanner.info. I assume that's the right one? I was able to find a "profile database changelog".
    I haven't (yet) found any individual profile to look at and see just how the communication with non-CAN-present ECUs would be coded.
    When you say the profiles are 'open', what precisely do you mean by 'open'? Are they available somewhere for inspection and reuse under an OSI-approved license?
    When you say the profiles are 'modifiable', what precisely do you mean by 'modifiable'? Who may modify them, and by what means? Editing a text file? Is there a document somewhere describing the syntax and semantics and capabilities?
    As @mr_guy_mann has not commented yet, maybe it would be helpful if you could post some screenshots of the current version showing the list of ECUs it can communicate with on gen 2. The review from 3 years ago said it worked for the ECM and the HV ECU, so I assume the current version still works for those two; it would be most interesting to see which of the other ten or twelve are now covered.
  11. rjparker
    10,090
    6,260
    I use Car Scanner Pro and find it convenient since the bluetooth adapter and phone are always in the car. The points are easily configured into graphs with multiple points overlayed if desired. Many "dashboard" templates are preconfigured and easily modified. Prius hybrid battery data is all there as well.
    However for bidirectional control and assurance that all points are working, I go with a hardwired PC laptop Techstream scanner or a dedicated Launch scanner.
    There are no standard bidirectional controls in Car Scanner, although "Custom Codings" apparently can be created and saved in the current 1.121.0 version.
    New features include configuring user and "dealer" configurations such as how the light and lock timings work, etc.
    Some of the basic ecm data points for the gen3 profile like engine water speed rpms are shown but don't work. Several messages to the development team provided a "it's there and works". Meanwhile the inverter pump rpm does function along with hundreds of other points from ~20 ecus.
    It is likely the developer has fine tuned gen2 points more than gen3's.
    One complication is the developer's attempt to cover all brands and models in one app. There has to be some that are more comprehensive than others.
    With that said, Car Scanner Pro's ability to see most points and dtc's make it worth having in the car.
    The newer Terminal and Custom Codes are supplemented with a long list of sensor IDs and an editor of sorts, all of which I have not tried.
    Example Sensor id list
    Custom Coding Editor
    Version
    Referenced Command PDF
    #231 rjparker, Sep 1, 2025
    priumium likes this.
  12. ChapmanF
    18,078
    That right there is what I'd like to see more about. The review three years ago confirmed usability with two ECUs. There's nothing in the screenshots above showing any others.
    The Custom Coding Editor screenshot shows something like I expected: some blanks to fill in that will be enough whenever the necessary communication can be accomplished by putting the right stuff in that particular selection of blanks.
  13. rjparker
    10,090
    6,260
    These are some of the ecus
  14. ChapmanF
    18,078
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    I just updated CarScanner (ver 1.121.0), and can't really see much difference from my earlier review.
    Connected to my 2006 via OBDLink MX+, and had it scan "all systems" for codes. It checked 131 possible ecu's and reported "no codes" but only had: OBD2, engine control #1, hybrid engine system, and HV battery as the ecu's detected.
    Going to "All Sensors" gives a data list for OBD2 - Toyota (but not Prius) specific ECM, and hybrid control - HV battery ecu.
    That's all I find "out of the box". Yes, you can get a bunch of ecu identifiers for many other systems, but no codes or data, so what's the point? If I'm overlooking something, please let me know.
    Maybe the custom coding option could let someone do lots more, but for me I'm going to stick with the other options such as Autel.
    Brian1954 likes this.
  16. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    About compatibility and OBD-II standard – Car Scanner ELM OBD2
    may give clues to the ODB11 standards car scanner works with.
    I'm seeing a LOT of added features iOS , windows, wifi etc. from the last time I visited the home page.
    I updated the app a couple years ago when I got a newer phone and car scanner initial scan found many more sensors in the Gen 4 Prime than the older version found.
    But looking at the direction the app devel is taking, if I really wanted to use the current version of the app ( even on the Prime ) I'd see how it behaves on a windows 10 lappy and probably not use it as often.
    There are lots of references to VW and another brand in the coding and services section of his web site.
    I found this bit of advice under the Purchase and restoration and transfering FAQ page that might be helpful if interested in troubleshooting the lack of hybrid ECU's detected on the initial scan.
    Purchase restoration and transfering FAQ – Car Scanner ELM OBD2
    4.
    I bought through Google Play, how can I restore my purchase?
    Just use the same account and install the program from Google Play. The Pro version activates automatically, or you need to click the “Restore purchases” button on the purchases screen. If the purchase does not recover, here are the possible causes and solutions:
    1) If you have several Google accounts, logged in Android settings, you should logout from all accounts, except the one, that you’ve used to make purchase. Activate Pro version and after that you can login again.
    2) If something blocks Internet connection (firewall, etc.) – disable it. Sometimes installing and enabling any free VPN app helps (I recommend Windscribe and free server in Romania).
    3) Check date, time and time zone settings in your phone settings. They should be correct!
    4) Enable “Show experimental features” in Settings -> Information
    5) Try to clear Google Play cache, Google Play Services cache and Car Scanner cache on your device (Android settings -> Applications -> Select app -> Storage -> Clear cache).
    6) Restart your phone.
    7) Reinstall the app.
    8) Try to clear Google Play cache on your device.
    If none of these methods worked, then send me the order number (you can find it in the purchase confirmation email from Google Play, it always starts with “GPA”) and a screenshot of the error message when trying to restore the purchase. It is very important to send both. Instead of the order number, you can write the e-mail address of your
    LIke the Toyota app sometimes the upgrade we get for our phones laptops pads etc. is more like a curse than a blessing.
  17. priumium
    priumium Member
    104
    26
    Sweden
    Thanks for the updated check @mr_guy_mann .
    Surely price and subscriptions fees should also be stated and be relevant on this subject?
    I use a vlink pro (25us) and carscanner eternal license (@10usd), I am much happier than with many other apps. Just the Emission monitors and non-continuous data seems to me to be unique compared to many many other cheap apps.
    I do know autel is considered ”better; but how much does an autel device and app and potential subscription cost? Just curious…
    Have you checked content of and have the gen2 profile selected and updated the profile for gen2 for CS? Just listing the battery resistance is not a common basic feature in my experience with the myriad OBD apps that exist now…
    (I use techstream 18 on a bootcamp mba 2018 to read all ECU data etc if needed.)
    #237 priumium, Sep 9, 2025
  18. vvillovv
    4,321
    1,509
    NY
    https://autel.com/c/www/mk1/3262.jhtml
    see also Autel AP2000 and AP 2500 newer versions.
    It's always nice to mention which Model / Year is being referenced in posts that are not Gen 2 Prius.
    It seems to me anyways that the more ECU's and sensors the newer cars get the further out of spec the apps get for the older model cars.
    Dr Prius and Hybrid Assistant are still pretty good as pack monitors, etc. in the older models, but lack a lot of other features, which may be why they still perform well at what they do offer.
    From what I've read in this thread the Autel apps mentioned above and many times in this thread appear to have great value and performance in Gen 2 and beyond.
    And it might also be worth the time it takes to search out - device age, OS version compatibility - for any app being installed on a piece of hardware.
    #238 vvillovv, Sep 10, 2025
  19. mr_guy_mann
    4,036
    1,965
    NJ-USA
    I picked up a 2010 Gen3 (needs a head gasket - no surprise) and tried Car Scanner Pro. It scanned 20 systems for codes - and "All sensors" pulled data for engine, hybrid systems, and ABS (brake control). Not bad I guess. You just need to understand any tool's capabilities & limits.
    On the same Gen3, the Autel AP200 can access 23 systems for codes and data, plus has several service functions. BUT you have to be able to login to your account (weekly?) before you can use it. No internet (or if autel's servers are down) then it won't work. There is no subscription fee for a single car brand (the first brand selected). Do your own research for costs as it changes from time to time.
    The AP2500 has similar-ish functions but appears to be aimed more at DIY crowd than technicians.
    The scantool behavior confirms my guess that it only uses CAN protocol to communicate. The Gen2 has ECM, hybrid control, and HV battery ecu's that can talk to a scantool on the CAN bus. All other ecu's use the SIL circuit (ISO9141-2 protocol) for diagnostics to the scantool.
    In contrast the Gen3 uses CAN for all ecu's, and it shows with increased scantool capability.
  20. priumium
    priumium Member
    104
    26
    Sweden
    Very relevant points.
    1. Why would any ”free” OBD app require a login / internet? (Rhetorical question… they will sell your lame data). IAP and license are bound to iCloud. I avoid any app with that req personally.
    2. Research deep on IAP lockdowns for basic and advanced functions.
    3. Compare OBD hw pricing. A 150usd dongle ought to be more capable, but that is not a fact generally applicable if reading data from different protocols is locked behind IAP.
    #240 priumium, Sep 15, 2025
