Frustrating And Elusive Electrical Drain
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SandyPrinus, Aug 28, 2025 at 5:03 PM.
  1. SandyPrinus
    SandyPrinus New Member
    Thursday
    Tempe, AZ
    I love my Base 2005 Prius. It has 250,000 miles on it, and aside from being a little hungrier for oil and gas than it used to be, it has had almost no problems, and only one I haven't been able to fix on my own (note: I am an amateur youtube mechanic at best). This issue, though, is driving me nuts, and it has me going through 12V batteries like AAAs. It started with what I considered to be a harmless ghost living in the radio, who likes to keep it on and listen for a little while after I turn off the car. The information display turns off and the controls stop working (besides the volume knob, which continues to function), but the sound continues for a non-specific amount time before suddenly stopping on its own. For a while I thought it was no big deal, as it always turned off eventually, but eventually I realized - usually via a dead battery at the end of a long shift - that even when the radio does turn off, there is still a power draw. I borrowed a friend's multi-meter as well as her electrical engineering background to try and diagnose it. We ripped apart the dash and I unplugged everything I could see, testing the drain with the multi-meter. There were lots of ~little~ drains - which isn't surprising given how long it's lived under the desert sun - but nothing big enough to account for the overall drain. If I unplug the fuses for the Radio / Information Display (I have already replaced the display once trying to fix this issue), or if I disconnect / reconnect the 12V battery, it stops draining (at least at a rate that I care about). Unfortunately, these fuses are connected to a great deal of things in the car, and I can't find the thing that matters. Intermittently, the apparently-classic "Audio Off" issue rears its head, the radio won't turn on at all, and I can breathe easy knowing the 12V battery is safe (for now). In between those periods of respite, I have to open the trunk and disconnect/reconnect the battery every time I leave the car. It's annoying, I'd like to fix it, and I haven't found anyone else either in person or online with a relatable experience, though I admit I may be barking up the wrong trees. If anyone has any advice, I'd love to hear it. Thanks.
    gdanner likes this.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,393
    713
    Southern California
    The normal draw with the car off is around 25 mA. Door open is 300 mA (any door or the hatch, and the dome light will be on).
    Open the hatch, trip the latch with a screwdriver, close all the other doors, and lock the car. Wait at least 10 minutes (30 minutes would be better). Put a DC clamp ammeter on the ground cable from the battery to the back of the car. Tell us how much current you see. (Then turn on the car, push the hatch button to open the latch, and close the hatch. Don't try closing the hatch without first opening the latch!)
    There is a known problem with the combination meter that can cause a 300 mA (if I remember correctly) drain. It has a circuit to keep it powered up for a short time after the car is turned off. If that circuit fails it can stay powered up all the time.
    Have you tried removing each fuse from the fuse box, one at a time, while measuring the parasitic current that remains (as above)? With any luck the majority of it will be on a single circuit.
  3. SandyPrinus
    Thursday
    Tempe, AZ
    Thanks for your comment! I'll try this out tomorrow and report back.
  4. dolj
    dolj Senior Member
    8,291
    4,232
    Wellington, New Zealand
    Similarly, there is a known issue where the JBL amp under the RH seat develops an always-on drain. The fix for this is to buy a good unit from a wrecker and replace the amp.
    rjparker likes this.
  5. pasadena_commut
    2,393
    713
    Southern California
    Also, when the radio problem is happening, does it still draw current if the OP turns off the radio (at its power button) before turning off the car?
    Is there anything plugged into the OBD2 port? If so, unplug it and see if the problem goes away. Parts of the OBD2 port are wired to the battery (at least on most cars, which is why there are "charge the battery through the OBD2 port" accessories for many 12V battery chargers). Some cars which were purchased used have trackers wired in above the OBD2 port. There have been cases reported where those trackers fail in such a manner that they cause a large power draw. In other cases they did so from the time of purchase.
    Are there any other known mods, especially an after market alarm system?
  6. douglasjre
    douglasjre Senior Member
    2,124
    705
    Null, NL
    YouTube search "parasitic draw test" w a multimeter. It's usually something you installed
  7. SandyPrinus
    Thursday
    Tempe, AZ
    At one point I actually took out the RH seat looking for this, but it turns out the base model doesn't have a dedicated amplifier - it's built into the head unit. I'm pretty sure I drove around with the head unit unplugged and it didn't fix the issue, but I could definitely be remembering wrong. This is a good lead, anyhow.
    I've done a bit of this, but it's been really tough to find out what specific component is causing the drain, especially since disconnecting the battery seems to diminish the amount of power being drawn. In other words, it seems like some component isn't turning off when the car turns off, but when I disconnect the 12V, it turns off and stays off until I turn the car back on. Forgive me if this is a dumb question, but is there a way to test parasitic draw *without* unplugging the battery?
    There is nothing plugged into the OBD2 port. None of the physical buttons on the radio work, including the power button (nothing at all happens when they are pressed), other than the tuning and volume knobs.
    #7 SandyPrinus, Aug 29, 2025 at 1:26 PM
  8. pasadena_commut
    2,393
    713
    Southern California
    Yes, measure the voltage drop across the fuses in the fuse box. Most car fuses have little wires that extend from the blade up to the top of the fuse and are exposed there. Car fuses have defined (quite small) resistances and you can look up those values.
    If the parasitic current I is going through a fuse with resistance R then it will produce a voltage V between those two points. When the current is an amp or more that will produce V of a few millivolts, which can be measured with a good quality voltmeter. However if the drain is on the order of 100 mA the voltage might be only 0.5 mV which is going to be just on the hairy edge of what one could measure with most voltmeter's 0.2V range. The multimeters which can read smaller voltages are bigger and tend to be really expensive. For instance, a Keithley 197, which would be over $200 for a used one, new it would be at least $1000.
    One can use a table that shows the expected voltage drop for various currents for different size fuses:
    https://caravanchronicles.com/wp-content/uploads/2018/10/fuse-voltage-drop-table.pdf
    This is one of those instances where the source of a big current is much easier to find than the source of a small one.
    Anyway, this sort of voltage measurement will not usually cause any change in the underlying circuit, so one could test every fuse in the box without causing the parasitic current to go away.
    #8 pasadena_commut, Aug 30, 2025 at 1:52 PM
  9. douglasjre
    2,124
    705
    Null, NL
    Measure voltage drop across fuses and put the readings into a chart
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,002
    1,936
    NJ-USA
    As others have mentioned, measure the voltage drop across each fuse. You need a multimeter that can read down to 0.1mV in the millivolt range.
    I open the driver's door to access the underdash fuse box but you have to trip the latch shut (and hold any "door open" switch - or remove it). Also open the hood for the engine compartment fuse box. Let the car sit around 15 minutes to go "to sleep". No lights on the dash.
    Now measure voltage drop across each fuse. You need to get good contact with the meter probes. (Yes, it's a complete PIA to contort yourself to reach under the dash - oh well) Look for a steady, repeatable voltage reading. Most everything should be 0.0mV. Write down your results.
    There might be one or two at 0.1mV, really anything more than that is suspect.
  11. pasadena_commut
    2,393
    713
    Southern California
    I think there is a pretty good chance that 17 year old fuses would have at least a little dirt or corrosion on top of those two tiny metal pads. So it might be necessary to "dig" a little with the probe tips to get through that and down to clean metal to allow a measurement as small as 0.1 mV.
  12. gdanner
    gdanner Member
    125
    48
    Central Illinois
    Although checking for a voltage drop of a few mV across a fuse will reveal circuits which have a substantial current drain, keep in mind that fuses are essentially "short circuits" until they blow (which transforms the fuse into an open circuit).
    A much more sensitive measurement can be taken by removing the fuse and temporarily connecting a multimeter set to the "amps" scale in its place. With this setup all of the current flowing in the circuit goes through the multimeter. This makes a precise current measurement possible.
    It's best to make the initial measurement using a multimeter with a 10A range (or larger).
    Next, if the current drain measures <1A with the meter on the 10A range then it is safe to select a range of 2A or even 200mA on the multimeter.
    For extra protection add a fuse of your own choice in series with the multimeter. I use a 1A external fuse.
    Note: Many multimeters have a 2A fuse inside the case. So adding an external fuse of 1//2 that rating (1A) prevents accidently blowing the fuse inside the multimeter.
  13. pasadena_commut
    2,393
    713
    Southern California
    The OP noted that if the current stops it stays stopped. So pulling a fuse and putting in the ammeter instead will not work once the car is already off - the parasitic drain will always be off. I guess it would work though if this was done and then the car started. Since that would almost certainly blow the fuse on the meter one would have to put a shunt wire around it, start the vehicle, stop the vehicle, remove the shunt wire, and then look at the current. Kind of a lot of work to do one circuit at a time.
    There are specialized devices for this sort of work. Pull the fuse, plug it into the device, plug the device in where the fuse was. Now it shows the current through that circuit - whether or not the car is on or off. But again, it must be installed before the car is turned off. Here is one made by Ansbell:
    (go to Amazon, look up B0F4JZXRJB)
    This particular one only goes down to 10 mA.
    Another class of devices for this purpose look like:
    https://www.aeswave.com/fuse-amp-loop-with-voltage-tap-p9653.html
    The current can be measured by placing a clamp ammeter around one of the wires.
    Finally, on some cars one can gain access to the wires under the fuse box. When that is possible one can put a clamp ammeter on them one at a time. I suspect that this isn't generally very useful though because the wiring harnesses will have been designed to make those wires as short as possible, so there may not be room enough to place the ammeter.
  14. Hayslayer
    Hayslayer Member
    283
    161
    I've never needed to do this and never tried, but out of curiosity, what are the chances you could just use a good multimeter on a low range current scale and place it across the fuse test points as if taking a voltage reading? Wouldn't it form an alternate/parallel current path? If 2 amps are passing through the fuse, you touch the meter leads to the test points on the fuse, some portion of that 2 amps (depending on the resistance of the meter) would now flow through the meter, providing a current reading value. I may have to try this tomorrow. Put the car in ready and try it across the AM2 fuse since that would be powering the inverter pump, just to see if my fluke meter gets any reading at all.
