Frustrating And Elusive Electrical Drain
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SandyPrinus, Aug 28, 2025.
  1. SandyPrinus
    SandyPrinus New Member
    Tempe, AZ
    I love my Base 2005 Prius. It has 250,000 miles on it, and aside from being a little hungrier for oil and gas than it used to be, it has had almost no problems, and only one I haven't been able to fix on my own (note: I am an amateur youtube mechanic at best). This issue, though, is driving me nuts, and it has me going through 12V batteries like AAAs. It started with what I considered to be a harmless ghost living in the radio, who likes to keep it on and listen for a little while after I turn off the car. The information display turns off and the controls stop working (besides the volume knob, which continues to function), but the sound continues for a non-specific amount time before suddenly stopping on its own. For a while I thought it was no big deal, as it always turned off eventually, but eventually I realized - usually via a dead battery at the end of a long shift - that even when the radio does turn off, there is still a power draw. I borrowed a friend's multi-meter as well as her electrical engineering background to try and diagnose it. We ripped apart the dash and I unplugged everything I could see, testing the drain with the multi-meter. There were lots of ~little~ drains - which isn't surprising given how long it's lived under the desert sun - but nothing big enough to account for the overall drain. If I unplug the fuses for the Radio / Information Display (I have already replaced the display once trying to fix this issue), or if I disconnect / reconnect the 12V battery, it stops draining (at least at a rate that I care about). Unfortunately, these fuses are connected to a great deal of things in the car, and I can't find the thing that matters. Intermittently, the apparently-classic "Audio Off" issue rears its head, the radio won't turn on at all, and I can breathe easy knowing the 12V battery is safe (for now). In between those periods of respite, I have to open the trunk and disconnect/reconnect the battery every time I leave the car. It's annoying, I'd like to fix it, and I haven't found anyone else either in person or online with a relatable experience, though I admit I may be barking up the wrong trees. If anyone has any advice, I'd love to hear it. Thanks.
    gdanner likes this.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,069
    956
    Southern California
    The normal draw with the car off is around 25 mA. Door open is 300 mA (any door or the hatch, and the dome light will be on).
    Open the hatch, trip the latch with a screwdriver, close all the other doors, and lock the car. Wait at least 10 minutes (30 minutes would be better). Put a DC clamp ammeter on the ground cable from the battery to the back of the car. Tell us how much current you see. (Then turn on the car, push the hatch button to open the latch, and close the hatch. Don't try closing the hatch without first opening the latch!)
    There is a known problem with the combination meter that can cause a 300 mA (if I remember correctly) drain. It has a circuit to keep it powered up for a short time after the car is turned off. If that circuit fails it can stay powered up all the time.
    Have you tried removing each fuse from the fuse box, one at a time, while measuring the parasitic current that remains (as above)? With any luck the majority of it will be on a single circuit.
  3. SandyPrinus
    Tempe, AZ
    Thanks for your comment! I'll try this out tomorrow and report back.
  4. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Similarly, there is a known issue where the JBL amp under the RH seat develops an always-on drain. The fix for this is to buy a good unit from a wrecker and replace the amp.
    rjparker likes this.
  5. pasadena_commut
    3,069
    956
    Southern California
    Also, when the radio problem is happening, does it still draw current if the OP turns off the radio (at its power button) before turning off the car?
    Is there anything plugged into the OBD2 port? If so, unplug it and see if the problem goes away. Parts of the OBD2 port are wired to the battery (at least on most cars, which is why there are "charge the battery through the OBD2 port" accessories for many 12V battery chargers). Some cars which were purchased used have trackers wired in above the OBD2 port. There have been cases reported where those trackers fail in such a manner that they cause a large power draw. In other cases they did so from the time of purchase.
    Are there any other known mods, especially an after market alarm system?
  6. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    YouTube search "parasitic draw test" w a multimeter. It's usually something you installed
  7. SandyPrinus
    Tempe, AZ
    At one point I actually took out the RH seat looking for this, but it turns out the base model doesn't have a dedicated amplifier - it's built into the head unit. I'm pretty sure I drove around with the head unit unplugged and it didn't fix the issue, but I could definitely be remembering wrong. This is a good lead, anyhow.
    I've done a bit of this, but it's been really tough to find out what specific component is causing the drain, especially since disconnecting the battery seems to diminish the amount of power being drawn. In other words, it seems like some component isn't turning off when the car turns off, but when I disconnect the 12V, it turns off and stays off until I turn the car back on. Forgive me if this is a dumb question, but is there a way to test parasitic draw *without* unplugging the battery?
    There is nothing plugged into the OBD2 port. None of the physical buttons on the radio work, including the power button (nothing at all happens when they are pressed), other than the tuning and volume knobs.
    #7 SandyPrinus, Aug 29, 2025
  8. pasadena_commut
    3,069
    956
    Southern California
    Yes, measure the voltage drop across the fuses in the fuse box. Most car fuses have little wires that extend from the blade up to the top of the fuse and are exposed there. Car fuses have defined (quite small) resistances and you can look up those values.
    If the parasitic current I is going through a fuse with resistance R then it will produce a voltage V between those two points. When the current is an amp or more that will produce V of a few millivolts, which can be measured with a good quality voltmeter. However if the drain is on the order of 100 mA the voltage might be only 0.5 mV which is going to be just on the hairy edge of what one could measure with most voltmeter's 0.2V range. The multimeters which can read smaller voltages are bigger and tend to be really expensive. For instance, a Keithley 197, which would be over $200 for a used one, new it would be at least $1000.
    One can use a table that shows the expected voltage drop for various currents for different size fuses:
    https://caravanchronicles.com/wp-content/uploads/2018/10/fuse-voltage-drop-table.pdf
    This is one of those instances where the source of a big current is much easier to find than the source of a small one.
    Anyway, this sort of voltage measurement will not usually cause any change in the underlying circuit, so one could test every fuse in the box without causing the parasitic current to go away.
    #8 pasadena_commut, Aug 30, 2025
  9. douglasjre
    2,250
    751
    Null, NL
    Measure voltage drop across fuses and put the readings into a chart
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    As others have mentioned, measure the voltage drop across each fuse. You need a multimeter that can read down to 0.1mV in the millivolt range.
    I open the driver's door to access the underdash fuse box but you have to trip the latch shut (and hold any "door open" switch - or remove it). Also open the hood for the engine compartment fuse box. Let the car sit around 15 minutes to go "to sleep". No lights on the dash.
    Now measure voltage drop across each fuse. You need to get good contact with the meter probes. (Yes, it's a complete PIA to contort yourself to reach under the dash - oh well) Look for a steady, repeatable voltage reading. Most everything should be 0.0mV. Write down your results.
    There might be one or two at 0.1mV, really anything more than that is suspect.
  11. pasadena_commut
    3,069
    956
    Southern California
    I think there is a pretty good chance that 17 year old fuses would have at least a little dirt or corrosion on top of those two tiny metal pads. So it might be necessary to "dig" a little with the probe tips to get through that and down to clean metal to allow a measurement as small as 0.1 mV.
  12. gdanner
    gdanner Member
    140
    Central Illinois
    Although checking for a voltage drop of a few mV across a fuse will reveal circuits which have a substantial current drain, keep in mind that fuses are essentially "short circuits" until they blow (which transforms the fuse into an open circuit).
    A much more sensitive measurement can be taken by removing the fuse and temporarily connecting a multimeter set to the "amps" scale in its place. With this setup all of the current flowing in the circuit goes through the multimeter. This makes a precise current measurement possible.
    It's best to make the initial measurement using a multimeter with a 10A range (or larger).
    Next, if the current drain measures <1A with the meter on the 10A range then it is safe to select a range of 2A or even 200mA on the multimeter.
    For extra protection add a fuse of your own choice in series with the multimeter. I use a 1A external fuse.
    Note: Many multimeters have a 2A fuse inside the case. So adding an external fuse of 1//2 that rating (1A) prevents accidently blowing the fuse inside the multimeter.
  13. pasadena_commut
    3,069
    956
    Southern California
    The OP noted that if the current stops it stays stopped. So pulling a fuse and putting in the ammeter instead will not work once the car is already off - the parasitic drain will always be off. I guess it would work though if this was done and then the car started. Since that would almost certainly blow the fuse on the meter one would have to put a shunt wire around it, start the vehicle, stop the vehicle, remove the shunt wire, and then look at the current. Kind of a lot of work to do one circuit at a time.
    There are specialized devices for this sort of work. Pull the fuse, plug it into the device, plug the device in where the fuse was. Now it shows the current through that circuit - whether or not the car is on or off. But again, it must be installed before the car is turned off. Here is one made by Ansbell:
    (go to Amazon, look up B0F4JZXRJB)
    This particular one only goes down to 10 mA.
    Another class of devices for this purpose look like:
    https://www.aeswave.com/fuse-amp-loop-with-voltage-tap-p9653.html
    The current can be measured by placing a clamp ammeter around one of the wires.
    Finally, on some cars one can gain access to the wires under the fuse box. When that is possible one can put a clamp ammeter on them one at a time. I suspect that this isn't generally very useful though because the wiring harnesses will have been designed to make those wires as short as possible, so there may not be room enough to place the ammeter.
    gdanner likes this.
  14. Hayslayer
    Hayslayer Active Member
    539
    331
    I've never needed to do this and never tried, but out of curiosity, what are the chances you could just use a good multimeter on a low range current scale and place it across the fuse test points as if taking a voltage reading? Wouldn't it form an alternate/parallel current path? If 2 amps are passing through the fuse, you touch the meter leads to the test points on the fuse, some portion of that 2 amps (depending on the resistance of the meter) would now flow through the meter, providing a current reading value. I may have to try this tomorrow. Put the car in ready and try it across the AM2 fuse since that would be powering the inverter pump, just to see if my fluke meter gets any reading at all.
  15. pasadena_commut
    3,069
    956
    Southern California
    The resistance is highest for the low range current scale. The device is trying to scale the voltage into a macroscopic range, so if I is small then R must be large. But if R is large most of the current will go through the fuse, where the resistance is low. I am going to try to work this problem but if I go off the rails I'm preemptively blaming it on the late hour.
    Anyway, here is the data sheet for a very good multimeter (much better than anything I own):
    (this link doesn't work here, take the space out and it should)
    https ://http://www.grainger.com/ec/pdf/Fluke-Digital-Multimeters-Detailed-Specifications-Sheet.pdf
    look up the burden voltage and note that in each case the xV/xA value just works out to Ohms: 100, 1.8, or .03 for the 600/6000 microA, 60/400mA, and 6/10A ranges respectively.
    Then look at the voltage drop table for let's say a 15A fuse at 15A, that is 0.078 volts. R=V/I = .078/15 = 5.2 mOhms. The resistance isn't exactly constant on fuses, but let's just say that it is. The ratio of current through the fuse divided by current through the ammeter would be in the three cases ((V/Rfuse)/(V/Rammeter)-> Rammeter/Rfuse) and : 100/.0052, 1.8/.0052, and .03/.0052, or 1923, 346, or 5.77. In all cases most of the current goes through the fuse. Let's say we were looking at 0.5A of parasitic draw through that fuse. That is set by the rest of the circuit, adding a tiny bit of resistance in parallel with the fuse isn't going to make a significant difference. Using the approximation that the current through the fuse is always much larger than through the ammeter we can just use that ratio to get ballpark. In the three ranges the ammeter would see 0.5/1923, 0.5/346, and 0.5/5.77, or 260 microA, 1.4mA, 87mA. The 600/6000 microA ranges could definitely measure 260 microA, same for 60/400mA and 1.4mA, and 6/10A and 87 mA.
    So yes, this could work, but to make any sense of the readings one would need to know the resistance of both the fuse and the ammeter in the range used. I'm not sure what an autoranging ammeter would do in this situation, hopefully throw an error, because the numbers it sees when switching ranges indicate that it is strongly perturbing the circuit. An ammeter that lets its current range be specified (as in locked) might be needed.
    Oh, one slight problem. If the fuse blows while this is going on 100% of the current will go into the ammeter. The 600 microA range won't be happy with 0.5A.
    #15 pasadena_commut, Sep 1, 2025
    gdanner likes this.
  16. Hayslayer
    539
    331
    Honestly, the fuse voltage checks still look like the easiest way to do it. Think my brain was addled, it was a long day. The test points are there for a reason, it works.
    there's plenty of good videos showing how to do it, with charts showing how to interpret the results based on fuse type and amp rating.
    douglasjre likes this.
  17. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    No this won't work. The amp meter has an internal resistor that is dropping voltage which is converted with ohms law to current for display. Virtually all the current would go through the fuse.
    That is true of any parasitic drain situation.
    It would help to know how many milliamps or amps you measured with this happening. The battery should be able to supply the "normal" 10-30 ma for two to four weeks. Discharging after a "shift" of 8-12 hours requires a high rate of discharge which is easily measured.
    When you had the ee helping you, she isolated it to the radio fuse(s) according to your first post. Which fuse when removed stops the drain? There are at least three fuses feeding the mfd radio, eg the Panel, ACC and Dome fuses. Each also supplies power to other things.
    At that point you have to start disconnecting each load one by one while monitoring the drain.
    To know which devices are involved and where to disconnect, there are detailed drawings available online for a cost from Toyota or from a service like All Data.
    I would connect a simple in-series ampmeter at the 12v batteries ground cable. A $6 Harbor Freight meter is good enough. A pair of external wires could bring the meter to the dash or engine compartment. I would do this in the ignition on mode (not Ready) unless the problem requires Ready to occur.
    #17 rjparker, Sep 1, 2025
  18. pasadena_commut
    3,069
    956
    Southern California
    After doing all those calculations last night I woke up later realizing that with a DC clamp ammeter all one needs to measure the current through a fuse is a piece of wire with a probe on each end. Put the wire through the ammeter, place it someplace out of the way where it will stay put, zero it, then touch the probe at each end of the wire to the metal pads on the top of the fuse. "All" of the current will go through the wire, because its resistance is going to be in microOhms whereas the fuses will be in milliOhms, and the meter will show that current. Best part, one could just move from fuse to fuse, do the whole box very quickly. Worst part, while the probes are on there is no fuse in the circuit (not counting the 100A one at the battery), so if by pure bad luck something on that circuit shorted to ground it might burn things out.
  19. rjparker
    11,125
    6,980
    Texas Hill Country
    You can buy fuse and relay adapters to do the same thing. But if it's already narrowed down to the radio fuses) you have to go further downstream of the obvious fusing.
    #19 rjparker, Sep 1, 2025
  20. douglasjre
    2,250
    751
    Null, NL
    What Chinese aftermarket device is doing it?
