MAF Sensor—How Cheap Can I Go?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Too Many Prii, Aug 30, 2025.
  1. Too Many Prii
    Too Many Prii Junior Member
    24
    The Lone Star State
    My 2008 Prius with 173,000 miles needs a new MAF sensor. The check engine light has been coming on sporadically for a couple of months. I cleaned and reinstalled it, and reset the code, but to no avail.
    A new sensor from Toyota is $140, and $90 from AutoZone. I picked up a “Ynovvo” branded sensor off Amazon with good ratings for $23. I haven’t installed it yet so could return it if the community convinces me it is asking for trouble to use it.
  2. Hayslayer
    Hayslayer Member
    327
    180
    Did you clean the mass airflow sensor wires that are buried down in the housing or just the amber temperature sensor bulb that is out in the open?
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,407
    2,384
    Taylors, SC
    I'd only go with genuine Toyota.
    Too Many Prii and Mendel Leisk like this.
  4. priumium
    priumium Junior Member
    49
    Sweden
    Have you tested it yet..? MAF sensors are temperature (bulb) and air-flow meter inside the housing with two wires comparing data. Go cheap, if fails, go less cheap. ;p
    Tombukt2 likes this.
  5. rjparker
    9,884
    6,092
    Toyota or you will be sorry. Most get a few days to months out of aftermarket maf sensors before the fault returns and a mechanic diagnoses a bad maf sensor. Toyotas seem to be sensitive to maf sensor quality but most oem sensors last decades.
    Order online for $111 shipped to your door. Labor day sale from Toyota Corp and selected online Toyota dealers.
    Part 22204-22010
    A few reviews of a best selling aftermarket maf, remembering most buyers review immediately and not down the road.
    IMG_9595.jpeg IMG_9596.jpeg IMG_9597.jpeg IMG_9599.jpeg IMG_9600.jpeg IMG_9598.jpeg IMG_9601.jpeg
    #5 rjparker, Aug 30, 2025
    Too Many Prii likes this.
  6. PriusCamper
    PriusCamper Senior Member
    12,351
    5,015
    Pacific Northwest, USA
    I'm in 100% agreement... All the OEM people have this bizarre cult like Dogma of paying a fortune for parts that might work just as well for 10% of the cost. What's more you're doing a service to the PriusChat community by testing the cheapest possible sensor out!
    I know I've always tried to buy the absolute cheapest part I can find and it almost always turns out well and the rare times it doesn't I return it and get my money back, if it didn't take too long to fail. Then I buy a slightly less cheap one.
    Don't listen to all the people that are wasting their money by being a part of an OEM cult.
    priumium and Too Many Prii like this.
  7. bisco
    51,535
    wouldn't a salvage work?
  8. Too Many Prii
    24
    The Lone Star State
    I thoroughly cleaned the hidden wires. I was thinking of going it again to be sure, but now wanting to make sure it's reliable and low drama for my SO.
  9. Too Many Prii
    24
    The Lone Star State
    Right, just a Wheatstone bridge, plus an intake air temperature sensor, right? So point of failure could be the heated wire or the intake sensor resistor. I have not tested it, and not well enough informed to know if a reading is out of spec. Probably easier to just replace it.
  10. Too Many Prii
    24
    The Lone Star State
    Yeah, fair. Full disclosure, there was a cheaper one on Amazon I steered away from. So it's definitely justified to buy a cheap part that fails sooner (another 50K miles?) and then buy another one. It depends on risk tolerance. Luckily my SO is an engineer, so risk tolerant. That, and this is a very easy part to replace.
  11. Too Many Prii
    24
    The Lone Star State
    Maybe, but history of the part is unknown, and this is a pretty cheap part. I'll save salvage for other parts.
  12. Too Many Prii
    24
    The Lone Star State
    Thanks for all that. There are good reasons to go OEM, despite the ridiculous price. I may well follow your leads, which I greatly appreciate.
    Georgina Rudkus likes this.
  13. dolj
    dolj Senior Member
    8,343
    4,256
    Wellington, New Zealand
    Who's got time for all that these days? If you have, then good for you – go at it. Not only do I not have time to monkey with cheap aftermarket parts, but I don't have the time to do the same job multiple times. While changing the MAFS is not the most time-consuming or difficult job, I still only want to do it once.
    The problem with that is you cannot be guaranteed you will get the same quality even from the same seller. These automotive parts are all fluid. It's kind of like buying from a dollar store. They never have the same thing twice.
  14. priumium
    49
    Sweden
    The OEM seem especially overpriced for this part. The ”quality aftermarket” brands are a third of that price, ie Delphi and similar. I do not recommend buying any part from temporary/unknown brands on Amazon/temu etc.
    I would try salvage, it seems based on one number that Toyota uses the same exact part on many, many models. I recently bought one at salvager for 10 euro from a lowish mile Corolla when I was there, just to have a spare.
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,020
    1,949
    NJ-USA
    What is the car doing that leads you to replacing the MAF? They do fail but that's pretty rare for Toyota.
    I want to check power, ground, and signal circuits at the MAF connector (& the connector terminals for damage-looseness). Then see what a scantool reports for MAF readings.
    Here's a thread that has "known good" MAF readings under different ICE operating conditions.
    https://priuschat.com/index.php?posts/3395501
    priumium likes this.
  16. pasadena_commut
    pasadena_commut Senior Member
    2,464
    735
    Southern California
    Toyota 22204-22010
    OEM list is $189.94
    OEM at Longo Toyota is $148.45
    https://parts.longotoyota.com/oem-parts/toyota-mass-air-flow-sensor-2220422010?c=bD0xJm49U2VhcmNoIFJlc3VsdHM%3D
    RockAuto has a Denso for $112.79 (probably identical to the OEM) + $7 shipping.
    RockAuto has a Cardone remanufactured for $79.39. (Remanufactured here probably means they just cleaned it.)
    RockAuto has one made by SKP for $23.89. (SKP, is that short for SKiP?)
    The OEM one is listed as fitting 115 different models. So surely one could fine one in the junkyard. Maybe not - they don't have very many of the vehicles in that list of 115 in the closest LKQ yard and many of those are badly smashed in the front so a functional MAF from them is doubtful. Anyway LQK lists an "air flow meter" for $50.69 (including 90 day guarantee)+entrance fee.
    I would probably buy the Denso.
  17. dolj
    dolj Senior Member
    8,343
    4,256
    Given that the OP is in Sweden, this information is of limited use to him.
    I agree, this is the same strategy I would use. I always try and find a discounted "dealer" price, which can be the difference between stupidly expensive to reasonably priced, to compare to the aftermarkets.
  18. rjparker
    9,884
    6,092
    I wish the Lone Star State was in Sweden.
  19. pasadena_commut
    2,464
    735
    Southern California
    It would make for a very peculiar cuisine. Dinner might start with jalapeno poppers and pickled fish appetizers, followed by a main course of BBQ brisket meatballs and lingonberry jam.
  20. priumium
    49
    Sweden
    And topped of with sour/rotten herrings on a bed of hot turkey stuffing! Mmmmm..
