Prius intermittent temp light when driving uphill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Vinny85, Sep 1, 2025 at 2:00 AM.
  1. Vinny85
    Vinny85 New Member
    Today
    Sacramento
    Hi everyone i have a 2011 prius that has about 250k miles on it. I have had the car for about 10 years no major issues. I replaced the water pump, thermostat, had the headgasket changed as a preventive maintenance once i got to 240k as i want to keep the car for awhile
    I notice the the car makes noise like there is air trapped in the coolant system. I can recreate the sound when i brake hard. I have monitored the temp levels and they stay around 192-196 hwy temps and uphill if i floor it i can get the temps to 206+ as it climbs
    Is this normal or should i be worried about the air noise in the coolant and the overheating light on long uphill drives?
    51,388
    i'm no expert, but i would be worried. idk what temp sets the light, but it can't be a good thing
  3. Brian1954
    Brian1954 Senior Member
    1,948
    770
    South Central PA, USA
    Did you install a Toyota OEM water pump or an aftermarket pump?
  4. Gokhan
    Gokhan Senior Member
    5,857
    2,311
    Paramount CA
    Certainly not normal with the noise and coolant running too hot.
    Brian1954 likes this.
