Transmission worries
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TrishM, Sep 3, 2025 at 1:37 PM.
Tags:
  1. TrishM
    TrishM New Member
    Wednesday
    GA
    I am the second owner of an 09 Prius. It has 123k miles on it. Today I accidentally drove it for several minutes while it was in Park (I think I must have accidentally hit that button while driving.) It is not making any unusual noise nor are there any warning lights. How much did I potentially damage the transmission and what should I do proactively for repairs?
  2. Brian1954
    Brian1954 Senior Member
    1,960
    773
    South Central PA, USA
    I do not think that you caused any harm to the transmission. @ChapmanF will be able to answer.
    TrishM likes this.
  3. Tombukt2
    12,578
    2,234
    Can't drive and Park maybein zB mode . You've hurt nothing. It's all pretty stout in there.
  4. ChapmanF
    17,653
    Can you give details of what made you think it was in Park?
    The car evidently didn't think it was in Park, because if it had, it wouldn't have gone anywhere.
    So, something else is what was happening. But I can't really speculate on whether the something else did or didn't do any damage, without a better idea what the something else was.
  5. TrishM
    TrishM New Member
    Wednesday
    GA
    I was driving and noticed a lack of power, and that made me look at the dashboard. The P was highlighted. I quickly shifted into drive and the power issues vanished. I assumed I had accidentally hit the Park button while driving, but I was tired so I really have no clue.
    There has been no weird noise and no warning lights on the dash. I made an appointment to get it checked out next week just to be safe.
    Y'all have been giving me some peace of mind so I appreciate your comments.
  6. hurricos
    hurricos Junior Member
    39
    Burlington, Vermont
  7. T1 Terry
    T1 Terry Active Member
    862
    441
    If the vehicle senses it is moving through the wheel speed sensors, the Park pawl will not engage .... if it did, the sudden stop when the park pawl engage would probably snap a driveshaft or CV joint .... I've exploded one of those on the Taxi Prius trying to get out of way of oncoming traffic, it hit the bitumen and bang clunk clunk clunk as the balls fell out, and no drive anywhere :eek: Flat tow to the workshop so I could replace the driveshaft :rolleyes:
    T1 Terry
  8. dolj
    dolj Senior Member
    8,294
    4,234
    Wellington, New Zealand
    Surely you just use the joystick to select either D or N (has to be held at N for some 2-3 seconds) in such circumstances. It wouldn't be good practice to hit the P button while going at any speed, regardless of the in-built protections of doing so, which might allow it.
  9. TrishM
    TrishM New Member
    Wednesday
    GA
    I have read that on these cars you should have the transmission fluid changed every 30k miles. This true? I couldn't have that done on my old hybrid (Ford CMax) as it was sealed.
    Tombukt2 likes this.
  10. dolj
    dolj Senior Member
    8,294
    4,234
    Some people suggest doing the first change at 30,000 miles, then at every 60,000 miles thereafter.
    There is no mandated Toyota oil change interval for the transmission. However, it is widely accepted that the oil should be changed on a schedule, like the one above.
    TrishM likes this.
  11. Tombukt2
    12,578
    2,234
    Yes ford made sure that game couldn't be played . Others too . I don't partake personally.
  12. Tombukt2
    12,578
    2,234
    When I initially receive car . And maybe 60 K after .
