Transmission worries
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TrishM, Sep 3, 2025.
Tags:
  1. TrishM
    TrishM New Member
    GA
    I am the second owner of an 09 Prius. It has 123k miles on it. Today I accidentally drove it for several minutes while it was in Park (I think I must have accidentally hit that button while driving.) It is not making any unusual noise nor are there any warning lights. How much did I potentially damage the transmission and what should I do proactively for repairs?
  2. Brian1954
    Brian1954 Senior Member
    2,684
    1,072
    South Central PA, USA
    I do not think that you caused any harm to the transmission. @ChapmanF will be able to answer.
    TrishM likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    Can't drive and Park maybein zB mode . You've hurt nothing. It's all pretty stout in there.
  4. ChapmanF
    19,022
    Can you give details of what made you think it was in Park?
    The car evidently didn't think it was in Park, because if it had, it wouldn't have gone anywhere.
    So, something else is what was happening. But I can't really speculate on whether the something else did or didn't do any damage, without a better idea what the something else was.
  5. TrishM
    TrishM New Member
    GA
    I was driving and noticed a lack of power, and that made me look at the dashboard. The P was highlighted. I quickly shifted into drive and the power issues vanished. I assumed I had accidentally hit the Park button while driving, but I was tired so I really have no clue.
    There has been no weird noise and no warning lights on the dash. I made an appointment to get it checked out next week just to be safe.
    Y'all have been giving me some peace of mind so I appreciate your comments.
  6. hurricos
    hurricos Junior Member
    74
    24
    Burlington, Vermont
  7. T1 Terry
    T1 Terry Senior Member
    970
    551
    If the vehicle senses it is moving through the wheel speed sensors, the Park pawl will not engage .... if it did, the sudden stop when the park pawl engage would probably snap a driveshaft or CV joint .... I've exploded one of those on the Taxi Prius trying to get out of way of oncoming traffic, it hit the bitumen and bang clunk clunk clunk as the balls fell out, and no drive anywhere :eek: Flat tow to the workshop so I could replace the driveshaft :rolleyes:
    T1 Terry
  8. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Surely you just use the joystick to select either D or N (has to be held at N for some 2-3 seconds) in such circumstances. It wouldn't be good practice to hit the P button while going at any speed, regardless of the in-built protections of doing so, which might allow it.
  9. TrishM
    TrishM New Member
    GA
    I have read that on these cars you should have the transmission fluid changed every 30k miles. This true? I couldn't have that done on my old hybrid (Ford CMax) as it was sealed.
    Tombukt2 likes this.
  10. dolj
    dolj Senior Member
    8,646
    4,397
    Some people suggest doing the first change at 30,000 miles, then at every 60,000 miles thereafter.
    There is no mandated Toyota oil change interval for the transmission. However, it is widely accepted that the oil should be changed on a schedule, like the one above.
    TrishM likes this.
  11. Tombukt2
    13,861
    2,519
    Durham NC
    Yes ford made sure that game couldn't be played . Others too . I don't partake personally.
  12. Tombukt2
    13,861
    2,519
    Durham NC
    When I initially receive car . And maybe 60 K after .
  13. TrishM
    TrishM New Member
    GA
    Thanks to everyone who responded, I truly appreciate the input. This place is a great resource.
  14. pasadena_commut
    pasadena_commut Senior Member
    3,065
    951
    Southern California
    With a dealer? Please, not a dealer. They will always find something that you need to do (but don't).
    All that needs to be done is to hook the car up to an appropriate code reader and maybe drive it around a little. If there are no codes, no odd sounds, and no odd motions while driving, then there is no current problem.
    It may be that the OP's vehicle could use a transmission fluid change. Don't pay a dealer for that. Really any mechanic should be able to handle it. It is slightly inconvenient to do it in a driveway with jacks and a socket set, but in a mechanic's garage with a lift it would take what, 30 minutes?
    TrishM likes this.
  15. TrishM
    TrishM New Member
    GA
    Nope, can't afford a dealer. Got my own mechanic.
  16. bisco
    52,855
    fluid change should be around $150.
  17. hurricos
    74
    24
    Burlington, Vermont
    A few things:
    - I don't do it often. I usually request R instead, which instantly puts me in N at speeds over ~7mph.
    - It is most important that I can fluidly and directly command the car where it needs to be for me and other road-goers to be safe. How I achieve the safe physical driving patterns is less important than achieving them quickly and reliably.
    - It takes, as you say, 2-3 seconds to shift to N. Those seconds involve my hands not on the steering wheel, and my foot remaining over the gas pedal, focusing on keeping the accelerator where it needs to be to ask for output torque near zero to roll at my current 25-35mph.
    - There are many signals that the Hybrid Control ECU could misinterpret to do bad things. Even if the Hybrid ECU sends the transmission control ECU the park enable signal, the pawl would not be able to seat on the moving output gear over the quarter-second or so it usually mates, and would probably set a C2301.
    I trust Toyota not to install a button mere inches from the wheel, implemented in a way that it would unambiguously harm you and/or the vehicle if pressed. That's the conceit of the original post, and why I mentioned my occasional use-case. OP, you're fine.
    TrishM likes this.
  18. TrishM
    TrishM New Member
    GA
    I think the design sux, so I had no such trust.
    However, I have been convinced that whatever weirdness occurred, it did not damage my transmission, which was my concern.
    hurricos and bisco like this.
