Windshield shade suggestions
Discussion in 'Gen 5 Prius Accessories and Modifications' started by AgentPTFC, Jul 1, 2025.
  1. AgentPTFC
    AgentPTFC Member
    59
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    The windshield shade that I used with my last car has more of a rectangular shape that doesn't seem to fit the more square shape of the prius due to the long raked windshield. There is some exposed dash towards the front if its pulled up enough to be held in place by the visors.
    Curious what sun shade those here are using to get the best coverage on the windshield.
  2. pascalvin
    pascalvin Junior Member
    22
    2024 Prius Prime
    XSE Premium
  3. jtchinoy
    jtchinoy Member
    Hayward, California
    2024 Prius
    I use this one.
    Not the most compact when folded up, but does a great job covering the windshield and folds up easily.
  4. Xse
    Xse Member
    74
    31
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
  5. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
  6. PrimeDan
    PrimeDan Junior Member
    22
    Philly Suburbs
    2024 Prius Prime
    SE
    I prefer the folding version of the AutoHeatShield model TT-928.
    It's pricey at $71 but I've been very happy with the accordion fold (compared to rolling the others). Heat rejection is also excellent in my experience.
    #6 PrimeDan, Jul 2, 2025
  7. otatrant
    otatrant Active Member
    349
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    PrimeDan likes this.
  8. otatrant
    349
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    The KMF sun shades arrived. A couple thoughts after a day of use.
    1. It is nice to be able to fold up the windshield sunshade.
    2. It is probably overkill to put up the sunshades on all of the side windows everyday but they do fit well and stay in place.
    3. The hatch glass sunshade I will probably use regularly and it fits well too and will stay in place when tucked in.
    The sun shades come with a couple of pouches for storage. Overall I am happy with it so far and prefer it to the Automate because it fits the windshield better, stays up close to the glass and is easier to store.
  9. AgentPTFC
    AgentPTFC Member
    59
    40
    PNW
    2025 Prius Plug-in
    XSE Premium
    Figured i would update this. After looking around at options I decided to try something cheap. I had to make some modifications for it work the way I wanted. The thinking behind it seems sound. Block the sun before it gets in the car. It seems to do the trick. It still is fairly warm inside but definitely seems to have reduced the temp. And the piece of mind that the uv rays arent hurting the dash or the camera pod at the top of the windshield. Long term reliability remains to be seen so well see.
    VelvetFoot likes this.
  10. ChapmanF
    18,587
    I'm pretty sure I found mine in a generic auto parts store, and checked that it claimed to fit my Prius year.
    The one I found is the style using fabric with a spring wire around the edge; grab two opposed sides and give a little twist and it loops itself up to a fraction of the size just like that, and stashes easily beside a seat or wherever. To deploy, just unstash and let go, and it sproings back out to full size.
    The one that was advertised as fitting my Prius was the first I've seen to be made of two such panels. Stowing it is just a matter of sliding one panel over the other and then doing the little twist so they both fold up. Deploying is just letting them sproing out, then sliding the two panels apart to cover the whole windshield.
  11. Antonbr
    Antonbr New Member
    Richmond, VA 23235
    2024 Prius
    Have a
    Covercraft UVS100 Custom Windshield Sunscreen for 2023-2026 Toyota Prius & 2023-2024 Prius Prime (Hybrid & PHEV) - Silver
    coming 8/29. Just concerned about it fitting around the rain sensor and safety sensor. Will give an update. Is the folding type and is expensive. Saved money purchasing on Amazon.
  12. Antonbr
    Antonbr New Member
    Richmond, VA 23235
    2024 Prius
    Does this sunshade clear both the main sensor and the rain sensor?
  13. Antonbr
    Antonbr New Member
    Richmond, VA 23235
    2024 Prius
    Does the center cutout allow for both the main sensor and the rain sensor?
  14. jtchinoy
    jtchinoy Member
    Hayward, California
    2024 Prius
    Yes, it clears all the accessories in the middle of the window.
    Antonbr likes this.
  15. Antonbr
    Antonbr New Member
    Richmond, VA 23235
    2024 Prius
    Thanks for the feedback!
  16. Bechi
    Bechi Junior Member
    37
    US East Coast
    2025 Prius
    Limited AWD-e
    I just received my new Covercraft sunshade yesterday and it's a great fit as usual, albeit an expensive one! Amazon currently has the best price.
    GcinFl likes this.
  17. JimLudden
    JimLudden Member
    89
    36
    Taos, NM
    2024 Prius Prime
    I use my old sunshade by clipping it above the trunk-space cover. It does reflect some sun coming in the rear window and helps keep the car cooler. Took months before I could find a front windshield reflector, but have one now that fits perfectly.
  18. LadyG955
    LadyG955 New Member
    MA
    2026 Prius
    Limited AWD-e
    I ordered this one, I used this brand on my last car and it was great quality
  19. Djyoshi626
    Djyoshi626 Junior Member
    34
    LA
    2024 Prius
    That looks pretty slick! How does it look like from a wider angle? Does it flop around at all?
    I got the Intro Tech Ultimate Sun Shade and it looks very similar to yours as I have 2 sides (one reflective for heat and the other is matte like to keep in heat during winter).
  20. Antonbr
    Antonbr New Member
    Richmond, VA 23235
    2024 Prius
    I have tried virtually all the shades on here and only two were sized properly to allow for the rain sensor,
    Automate Custom Fit Windshield Foldable Sunshade for 2023 2024 2025 Toyota Prius, Prius Prime Hatchback, Compact Block UV Protector Dual-Purpose (Link in a pervious post by another member above) and Windshield Sun Shades, Car Window Shades and Car Window Covers by HeatShield: The Original Windshield Sun Shade I kept both but by far prefer the Automate, the folding option is much easier option to deal with and the fit is better since the corners don't fold down. Buy with confidence!
    dabluesman likes this.
