Suspension upgrades worth it for handling?
Discussion in 'Prius v Accessories and Modifications' started by Carpetfuzz, Sep 6, 2025.
  1. Carpetfuzz
    Carpetfuzz New Member
    Ohio
    2016 Prius v wagon
    Hi everyone, I have a 2016 Prius V. I am wondering if it's worth it to upgrade stuff like shocks, springs, and sway bars to help with body roll and handling. I am basically looking to rice my car, but not sure if I should just get lowering springs and call it done, or if I should go all in on new suspension to try and reduce body roll, since I drive the thing like a hot hatch. Thanks for any info.
  2. Tombukt2
    12,923
    2,322
    You've got no power to really suspend? Body roll is the only thing fun about the car dang . 120hp give or take and 4K pounds .
  3. Air_Boss
    Air_Boss Senior Member
    4,196
    1,182
    New Yawk
    The TRD rear bar plants the car, makes it more stable in crosswinds and track better on the highway.
    Xterra72 likes this.
  4. Carpetfuzz
    Ohio
    2016 Prius v wagon
    That's great to know. Might be my first upgrade then!
  5. Mendel Leisk
    41,383
    Gotta ask: what’s the miles and how long have you had it?
    Carpetfuzz likes this.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,461
    2,421
    Taylors, SC
    When I got my 2012 Prius v in February 2012, I was so surprised to find out how flexible the entire body was.
    Even my 1998 Mazda MPV minivan which I had previously was better planted on the road.
    Through many trials with my dad's friend, he experimented and developed many chassis stiffening methods and eventually came up with the setup which I have today.
    I've had this setup for over 9 years and have been completely satisfied. Toyota eventually adopted multiple chassis braces to stiffen the Gen 4 Prius and beyond.
    Adding a rear sway bar would be only effective if the chassis is stiffer. If no stiffeners are added, the flex would still be evident and felt.
    Xterra72 and Carpetfuzz like this.
  7. Tombukt2
    12,923
    2,322
    Vo used all that at TRD in the 90,s good stuff I guess . I kind of like the handling like the Citroen that soooooft mushy feel it's perfect for a city driver . The Prius with 8 inches of suspension travel hale yeah. I mean I'm into stol aircraft things like that . So banging my kidneys for switch backs is not really a thing anymore .
  8. Carpetfuzz
    Ohio
    2016 Prius v wagon
    142,000 miles, and I've had it for about a year and a half. I love it, and I knew what I was getting into getting the slowest heaviest Prius ever but I wish I didn't have to go full throttle to feel a little acceleration lol.
  9. Carpetfuzz
    Ohio
    2016 Prius v wagon
    Okay good to know, so stiffeners, then a rear sway bar, then lower it.
  10. Georgina Rudkus
    3,461
    2,421
    Taylors, SC
    I tried and ditched rear sway bar, finding that the chassis braces did the job better.
    Another thing I got was a full sized spare and the 18lb. two ton Walmart Hyper Tough trolley jack.
    The jack fits perfectly in the foam storage well space underneath the lift up panel.
    The extra weight actually help even out the front heavy bias of the car, while improving handling.
    Tombukt2 and Carpetfuzz like this.
  11. Georgina Rudkus
    3,461
    2,421
    Taylors, SC
    Yeah, the chassis is overly flexible.
  12. Mendel Leisk
    41,383
    Late in the day, but I’d concentrate on EGR cleaning. See top two links in my signature. (On a phone turn it landscape to see signatures)
    also timely to change the engine water pump.
  13. Carpetfuzz
    Ohio
    2016 Prius v wagon
    Yep, that comes before anything. It just did "the thing" (the death rattle) for like 5 seconds a few days ago, that was the first time. I am going to jump on the issue, thanks for advocating and for the resources.
  14. Mendel Leisk
    41,383
    Keep an eye on fluid level in the reservoir then. Sounds like early stage, coolant getting by the head gasket. If the EGR's never been cleaned it's typical time to start those symptoms.
    Yeah first priority at this time would be head gasket diagnosis, then EGR cleaning. The latter is needed for sure, but it will not "reverse" a head gasket starting to leak.
    Borescope inspection of the combustion chambers, preferably first thing in the morning after driving the previous day, and preferably with the cooling system pressurized, to exacerbate leaking. A borescope that can look "over it's shoulder" is preferable.
    There's a couple of head gasket related links in my signature as well.
    For pressurizing the cooling system, removing the engine coolant reservoir cap and replacing with a one-hose stopper connected to a pressure source is one way to go. A crude gizmo I've cobbled, yet to use for this application though:
  15. Air_Boss
    4,196
    1,182
    New Yawk
    If the chassis doesn’t flex going up on the jack, and it doesn’t, then it doesn’t flex under driving loads, either.
    Of course I may be lucky to have a well-constructed 2012 v Five chassis.
  16. Mendel Leisk
    41,383
    Our 2010 hatchback has very noticeable front-to-rear deflection of the underside when jacking up the front end, at least a couple of inches.
  17. Georgina Rudkus
    3,461
    2,421
    Taylors, SC
    All structures flex. Some more than others.
    Just because you can't see it, doesn't mean it does not exist.
  18. Air_Boss
    4,196
    1,182
    New Yawk
    Yes, all chassis flex, to some degree, yet when the chassis is placed in a jig and torqued, as occurs when jacking from the side, using the front or rear of the sill jack points, and there is no notable front to rear flex, the degree of flex is not particularly significant. Nor is it notable on the road, where the TRD rear bar reduces crosswind effects on the suspension.
  19. Georgina Rudkus
    3,461
    2,421
    Taylors, SC
    Anyone having any knowledge of basic mechanical engineering know the difference between brittle fracture.
    If a structure under load oes not flex, it will fail through fracture.
  20. Air_Boss
    4,196
    1,182
    New Yawk
    The purpose of suspension is partially to alleviate loads that could drive chassis strain, be that due to torque under power, braking, cornering, or road surface features. Any street chassis will have an almost infinite s vs. n cycle endurance limit, with expected driving loads, typically tested and measured using a six-axis chassis testing rig. Absent manufacturing defects or abnormal loads, one would not expect to see brittle fracture of a street car chassis
