1. Gino Veltri
    Gino Veltri Member
    413
    40
    So the AC in my 2009 prius seemed to go out, then i read somewhere that if you kick the passenger side under the glove box it will start. Ill be damned if that worked for several months, not everytime, but whenever it went out all i had to do was kick. Now the AC seems to be working but with diminished airflow and an audible increase in noise from the blower motor. Does anyone have any idea what going on with this?
  2. Tombukt2
    13,306
    2,398
    When you say the air conditioner went out you actually mean the air blowing out the vent stopped so you're kicking under the glove box nets you kicking s plastic housing that houses you're fan . So now you'll pull the fan maybe see all the carbon and replace maybe you kicked the plug to death ?
  3. bisco
    52,304
    the poor glovebox
  4. spdracrm3
    spdracrm3 Member
    58
    47
    estacada or
    Replace cabin filtet
    SM-G960U ?
  5. ChapmanF
    18,469
    A motor that's commutated with carbon brushes eventually becomes unreliable when the brushes are worn down and not contacting the commutator very well. Smacking the motor works for a while to get it to spin.
    The fix is just replacing the motor, except for folks who want to try opening it up and finding compatible replacement brushes.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    So, if "the A/C goes out" means that there was no airflow (the blower motor is inoperative), then kicking the dash makes sense.
    The motor can have a bad spot on the commutator where the brushes don't conduct electricity. If-when it stops there, it can't start up again. Kicking things can jar the motor and move it enough to let the brushes contact "clean" metal on the commutator.
    Once it's spinning, momentum carries it past the bad spots. Until things get really worn. Then it can get noisy and slow.
    But all of this is a guess. You would have to do testing to confirm this. Or just replace the motor if that's your thing.
  7. Tombukt2
    13,306
    2,398
    You keep kicking that metal motor against that plastic housing you May break and boy will ya have fun then
  8. rjparker
    10,419
    6,525
    99% it is your blower motor which is relatively easy to change from the passenger footwell. There is a snap in black cover first, a two screw ecu second, a five screw white blower housing next then the three screw motor.
    The new motor comes with the blower wheel. You can buy cheap aftermarket motors at local auto supplies for less the $50; it was used in many models. A better solution is the oem Denso part.
    Denso Blower Motor Sub-Assembly with Fan Part Number: 87103-47050
    Removing the glovebox is optional but you should change or clean the cabin filter.
    Top tip: When reinstalling the white blower housing be sure to route the motor cable in the slot in the back of the housing. Otherwise you will pinch the cable and may not be able to start the rear housing screws.
    #8 rjparker, Sep 8, 2025
    frodoz737 likes this.
