Prius Prime 2017 oil filter
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by sylvaing, Sep 11, 2025.
  1. sylvaing
    sylvaing Senior Member
    1,210
    514
    what filter do I need to do an oil change on my 2017 Prime? And do I need a new drain plug washer?
    Thanks
  2. Blueness
    Blueness New Member
    Farmington, NM
    2018 Prius Prime
    Looks like 04152-YZZA6 for the filter.
    Definitely needs a new washer, however I'd pick up a new drain plug too.
    FuelMiser likes this.
  3. Mendel Leisk
    41,865
    Repair Manual instruction attached. Seeing how your oil filter is the permanent housing style, it’ll be the “B” case, 18 ft/lb torque.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,270
    878
    Monument, Colorado USA
    Yep and you'll want one of the Toyota filter wrenches for that plastic filter casing, they can be difficult to remove. (And be careful removing the old filter inside of it and putting in the new one...it's pretty easy to break those little metal parts inside that....ask me how I know!)
    FWIW, a new oil drain bolt can be found on Amazon...I keep some on hand for our 9 vehicles when they need it.
    (Search for Dorman 090-038.1 Oil Drain Plug Standard M12-1.25, Head Size 14Mm Compatible with Select Models)
    BiomedO1 likes this.
  5. BiomedO1
    4,090
    2,140
    SacTown, Ca
    Lube the O-rings during reassembly and DO NOT over tighten the drain plug. Common noob mistakes that'll cost you more time and money. Use a torque wrench - old-timers like me have calibrated hands that know, 'ball-park' how much pressure to put on those bolts and filters. Since your green and learning; best not to break things and get discouraged.
    YMMV
  6. Mendel Leisk
    41,865
    I"m using a Honda oil filter socket (commonly called an "oil filter wrench", is what it is). It's heavy gauge, stamped steel, got it around 1990, more-or-less indestructible. It's compatible with Toyota, Mazda as well as Honda. Dealership parts departments may have it in stock, or can get it in.
  7. sylvaing
    1,210
    514
    Thanks all. It's been decades since I have crawled under a car to do an oil change lol. I bought ramps to change the coolant last week (was an easy job) so I said to myself, instead of paying $100+ for an oil change, having time has I'm retired, might as well put these ramps to use. Changing the oil now means next spring for the next oil change so I won't have to deal with changing oil in the winter! Although it's been years on my CARS, I do the oil changes on my tractors (garden and TLB) and my two ATVs so I'm not 'all that green' lol.
  8. sylvaing
    1,210
    514
    Thanks. Having a 3D Printer, I'll try this first, much cheaper :)
    Customizable 14-flute Oil Filter Wrench by Broken3ways - Thingiverse
    I bought these plugs and washers (5 of them)
    Hmm, the Amazon link doesn't show :-( But it's like you mentioned above (Dorman 090-038 Oil Drain Plug Standard M12-1.25, Head Size 14Mm Compatible with Select Models, 5 Pack)
    #8 sylvaing, Sep 12, 2025
  9. Mendel Leisk
    41,865
  10. sylvaing
    1,210
    514
    Yeah, I'll give it a try. PTEG and 100% infill can be strong. Will it be strong enough, we'll see lol.
  11. Mendel Leisk
    41,865
    Well, the one I linked is $26 USD and change, unbreakable.
  12. sylvaing
    1,210
    514
    Question, the oil was changed last Spring. I did 5380 km since then and my fuel consumption during that period is 1.4L/100 KM (I use Trip B for that). Knowing that the consumption when the engine is running continuously is 5.6L/100 KM, it means the engine ran for only about 1350 KM. Yes the oil is 6 months old and will need changing, but is worth to change the filter? Yes, I won't drain as much old oil as if I removed the filter but again, that's not much old oil. Again, is worth it to change the oil filter?
    PS. I ended up buy a 65 mm 14 sides filter tool at Canadian Tire for $8.99. It fits perfectly. I wasn't worth the trouble to print one for that price...
    #12 sylvaing, Sep 15, 2025
  13. Mendel Leisk
    41,865
    So Spring of 2025? For 4th gen Prius, either hybrid or plug-in variant, Toyota Canada says 12 months or 16k kms, whichever comes first. So you're officially good to Spring of 2026, unless you surpass 16K kms.
    t's al little harder to find this information now: unlike past years, there's NOTHING in the Toyota Canada publication included in the glove box, regarding service intervals, commencing with 2016 model year Prius.
    If you go here, enter your stats, then your kms/months, and it'll tell you (sort of), what needs doing, spec'ing Service #1, #2, or #3. To summarize, the first few:
    8k kms or 6 mo: Service #1
    16k kms or 6 mo: Service #2 <oil/filter change
    24k kms or 6 mo: Service #1
    32k kms or 6 mo: Service #3 <oil/filter change
    40k kms or 6 mo: Service #1
    Somebody ambitious could go through this, label all the specific services by row, and the kms/months by columns, something like this:
    The subject of extending the oil change interval for the plug-in's often comes up. Still with gen 4 going to yearly or 16k kms (per the States), it's not that onerous?
    I would change the oil pan drain bolt washers. Getting my oil filters at a dealership, they used to charge me a buck or two more for them, but just a couple of days ago, I noticed no mention on the bill, and there was a washer thrown in with the filter. :)
    #13 Mendel Leisk, Sep 15, 2025
  14. sylvaing
    1,210
    514
    I had just drained the oil so I proceeded with the oil/filter change. The sticker from my last oil change said to replace this month so I went with that.
    I had to put an extension to my wrench handle to break loose the filter housing. I don't know how much torque they used to install it last time but for sure it wasn't 18 ft.lb lol. I was afraid to break the plastic housing. For sure if I had printed a tool, it wouldn't have survived the force required to remove it. It was so hard to remove that I had trouble to remove the tool from the housing afterward.
    PS. For those not aware, you can make a makeshift handle extension by using a deep socket just big enough to fit at the end of the handle (mine was 15 mm) and insert the longest extension you have in that socket. It gave me an extra 6" to my 12" handle.
  15. Mendel Leisk
    41,865
    Who put that on? Even Toyota dealerships get “interpretative”.
  16. sylvaing
    1,210
    514
    My local mechanic.
    I checked the schedule you posted and indeed, it's 12 months. But they also recommend changing brake fluid every 48K km/3 years? That seems a bit excessive...
    #16 sylvaing, Sep 18, 2025
  17. Mendel Leisk
    41,865
    It may be. I’d consider it though. There’s info on it in my signature* IIRC. Should not cost more than $150 CDN, at dealership. Except in today’s “financial climate”, they’ll often try for more. But ask them, who knows.
    I’ve DIY’d a couple of times now, and dealership did it once, early on, in conjunction with brake booster recall.
    and checking about a week back, see it’s been 6 years for ours lol. Just picked up a couple of pints of Toyota DOT3. :)
    * (on a phone turn it landscape to see signatures)
  18. sylvaing
    1,210
    514
    I used my KINGBOLEN BF 200 Brake Fluid Tester and the water content is very low. I also used my Phoenix Systems 8006-B Double-Ended Brake Fluid + Coolant Test Strips and again, all is within acceptable range. I won't bother changing the brake fluid until at least next spring. Next fluid change will be the transaxle fluid change.
  19. richard203
    richard203 Member
    278
    61
    SF
    is there metal oil filter housing for the prime?
  20. Mendel Leisk
    41,865
    Toyota changed the filter style, from permanent canister to spin-on, somewhere in model year 2017 IIRC. Definitive way to find out would be to look. The permanent housing style is plastic.
