What to do with my 09 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by cipsaz187, Sep 3, 2025.
  1. cipsaz187
    cipsaz187 Member
    148
    42
    11 years of ownership, 145k miles, clean and reliable car. The engine and trans are rock solid as far as I can tell, but here is what I am getting now...
    Chirping noise while driving or idling, it doesn't matter, every 7-10 seconds. It used to be only while opening the door or braking. Sounds like the brake actuator might be the culprit.
    I got the CEL after changing the 12V battery in May. Stopped by AutoZone to get it checked.
    P1121- the 3 way coolant valve might be the one to replace?
    C1241- not sure about this one...
    These codes aren't really related to a brake actuator issue.. Also the hybrid battery is on the edge too. Overall, I am looking at the hefty bill here. Drive it, sell it or fix it? I am looking forward to fixing it.
  2. priumium
    priumium Member
    106
    26
    Sweden
    That last sentence makes it easy to choose: Fix it!
  3. 97trophy
    97trophy Junior Member
    Only owned ours for a year and it does the same. Previous owner said it had done that for years.
    Keep it. Too many good things about these cars to outweigh your few issues.
  4. bisco
    51,854
    '09 is a beast, just broken in at 145k. i'd do whatever it takes, even if i didn't want it, it's worth a fortune on the market in decent condition.
    sydney2008 and priumium like this.
  5. bisco
    51,854
  6. Moving Right Along
    Moving Right Along Senior Member
    720
    576
    I don't know about the C1241 code, but P1121 is indeed the 3 way coolant valve. It cost me a bit over a thousand to fix that issue at a dealership.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,591
    768
    Southern California
    The 3 way valve is a bit of a PITA to replace, but it isn't roughly $800 in labor of a PITA.
    That said, the engineer who put it where they did should be flogged. It is hard to maneuver it out or back in going either up or down because there is so little space available in that location. It isn't a large valve, they could have tucked it in down near the bottom of the thermos bottle and then it would have been easy to service. Toyota "fixed this" in the next generation by eliminating both the thermos and the valve.
  8. ETC(SS)
    7,138
    Easiest question today!
    HOW MUCH do you suppose car payments, sales taxes, and registration fees and additional insurance would be for the replacement????
