What to do with my 09 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by cipsaz187, Sep 3, 2025.
  1. cipsaz187
    cipsaz187 Member
    150
    43
    11 years of ownership, 145k miles, clean and reliable car. The engine and trans are rock solid as far as I can tell, but here is what I am getting now...
    Chirping noise while driving or idling, it doesn't matter, every 7-10 seconds. It used to be only while opening the door or braking. Sounds like the brake actuator might be the culprit.
    I got the CEL after changing the 12V battery in May. Stopped by AutoZone to get it checked.
    P1121- the 3 way coolant valve might be the one to replace?
    C1241- not sure about this one...
    These codes aren't really related to a brake actuator issue.. Also the hybrid battery is on the edge too. Overall, I am looking at the hefty bill here. Drive it, sell it or fix it? I am looking forward to fixing it.
    suzietapper likes this.
  2. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    That last sentence makes it easy to choose: Fix it!
  3. 97trophy
    97trophy Junior Member
    Only owned ours for a year and it does the same. Previous owner said it had done that for years.
    Keep it. Too many good things about these cars to outweigh your few issues.
    52,863
    '09 is a beast, just broken in at 145k. i'd do whatever it takes, even if i didn't want it, it's worth a fortune on the market in decent condition.
    Danno5060, sydney2008 and priumium like this.
  5. bisco
    52,863
  6. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    I don't know about the C1241 code, but P1121 is indeed the 3 way coolant valve. It cost me a bit over a thousand to fix that issue at a dealership.
  7. pasadena_commut
    pasadena_commut Senior Member
    3,068
    954
    Southern California
    The 3 way valve is a bit of a PITA to replace, but it isn't roughly $800 in labor of a PITA.
    That said, the engineer who put it where they did should be flogged. It is hard to maneuver it out or back in going either up or down because there is so little space available in that location. It isn't a large valve, they could have tucked it in down near the bottom of the thermos bottle and then it would have been easy to service. Toyota "fixed this" in the next generation by eliminating both the thermos and the valve.
  8. ETC(SS)
    7,566
    Easiest question today!
    HOW MUCH do you suppose car payments, sales taxes, and registration fees and additional insurance would be for the replacement????
  9. cipsaz187
    cipsaz187 Member
    150
    43
    Alright, here is the update:
    3 way coolant valve has been replaced at the local shop for around $550. Problem solved.
    Now, a couple months later the dashboard lit up with the ABS, VSC, Brake. They warned me about the ABS module and advised to keep driving until the lights show up. Well, here I am. The brakes do work fine, though. I wonder how long can everything work correctly?
  10. PrimalPrius
    PrimalPrius Member
    138
    America
    When did they warn you about the ABS module? what about it specifically? This happened during the 12V battery replacement visit? If so, that warning the shop gave you MAY not mean anything because a weak 12V battery can cause the ABS warning light to come on with code C1241-Low battery positive voltage. IF that's what happened, the shop should have known or been able to figure out that this was related to the bad battery. (Could be that they have a policy to mention anything brakes related for liability reasons, i have no idea).
    Your 12V battery was changed in May? Have you had any 12V battery issues as in needing a jump start or a charge?
    You need to find out what the code is. Don't let what I wrote above cause you to ignore it.
    #10 PrimalPrius, Feb 11, 2026
  11. cipsaz187
    cipsaz187 Member
    150
    43
    They warned at the time of coolant valve replacement. It was cycling frenquently, now it cycles every 2-3sec. The 12V battery has been replaced last year.
  12. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
    It is a leap to assume C1241 based on the frequent cycling of the 'ABS module'.
  13. PrimalPrius
    PrimalPrius Member
    138
    America
    I agree, in my opinion also it would be*. But I don't think that OP posted anywhere that the shop claimed that?
    (*Aside from some outlier case in which a fault is causing it to cycle very frequently and over time it drains the battery voltage of a parked car sufficiently low).
  14. ebikeman
    ebikeman Member
    121
    Northwest
    If your ABS, VSC, and Brake light came on and it's a legit brake Module, you brakes are not working fine. If you ever brake hard, especially at high speed, you may crash. Your front, rear, maybe one wheel will lock up and could sent you out of control.
    The brakes normally will keep you in control while braking. Now, you can have irregular braking with one wheel braking hard, the other not working, then switch which one works.
    Please be careful.
    P.S. Speaking from a near death experience while driving with a bad brake module.
    ebm.
  15. suzietapper
    suzietapper Junior Member
    New Jersey
    My 2008 has 341,200 miles as of 2/25/26 - I have owned this car from the beginning (for almost 18 years) .... needs some cosmetics that are happening this weekend. I dread getting ever parting with this gem. What is the word on the Prius today?
  16. Moving Right Along
    739
    596
    When I was looking at car reviews and trying to determine what would be my next car, I saw a few Corolla reviews saying it’s a good car, but you might as well spend a little more and get a Prius. Then I looked at Camry reviews and thought the Camry is better in almost every way than a Prius and they cost about the same, so I bought a Camry.
    Now that Toyota is making everything a hybrid, I don’t see the point of the Prius. It’s not really a special car anymore. If you want a cheap hybrid, get a Corolla. If you want a midsize hybrid, get a Camry. If you want a taller hybrid, get a RAV4. The only way the Prius makes sense is as a plug in hybrid. All the other ways it used to be special are gone.
  17. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    You are at the point where a brake booster and hybrid battery are in your near future. Brake boosters don't immediately go into the low stopping power failsafe mode but its the next step which could be tomorrow or a month from now.
    Sure you could put $3500-$4500 into it and keep motoring which is maybe six months worth of new car payments.
    My take is the Corolla hybrid is the closest to an early Prius in terms of ride, mpg and lower price. A Camry is nicer with a better ride for just a little more. A new Rav4 is almost Lexus quality for more. All give you full safety features your gen2 could only dream about and could be worth the price of admission in an accident situation.
  18. suzietapper
    New Jersey
    THANK YOU SO MUCH for your reply - sorry its taken me this long to respond ..... now I'm at $349,900 and my dash and stuff is having issues. I appreciate your insights.
    THANK YOU SO MUCH ! I'm at 349,900 and big problems seem imminent - I appreciate you.
    #18 suzietapper, Jul 3, 2026
  19. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Here's an option
  20. suzietapper
    New Jersey
    OMG - that is hysterical .... Thanks for suggesting a truly American alternative .... but I couldn't possibly send my little miracle car to such a fate !!! This video has helped me come to my senses and given me some great ideas for letting my friends write a farewell message on my car before I donate it..... THANKS SO MUCH
    THANK YOU SO MUCH .... SO GLAD I ASKED THIS CHAT FOR INSIGHTS ..... I'll most likely do Toyota hybrid again - all the best to you.
    #20 suzietapper, Jul 5, 2026
    douglasjre likes this.
