Replacement OEM hybrid battery going bad after only 2+ years??
Discussion in 'Gen 2 Prius Main Forum' started by GreenMeanie, Sep 15, 2025.
  1. GreenMeanie
    GreenMeanie Junior Member
    42
    My Gen 2 2006 Prius is doing things similar to what it did when I had the original hybrid battery replaced in April 2023 when the car had 98k. The OEM replacement hybrid battery has a 3-year warranty and it's been not quite two and a half years. The car is now at 111k. The dashboard lights up completely with a steady beep, and then suddenly goes away and the car is ready to go. This has happened 4 or 5 times in the last few weeks, both in garage and in parking lot, so doesn't seem to be heat-related.
    Would it be normal for a hybrid battery to start going out so quickly, and if not, what else might this be? They want $200 to run a diagnostic and they can't guarantee anything because the car isn't giving the warning all the time. I'm worried it could be something cost-prohibitive on a 19 1/2- year-old car.
    51,851
    those don't sound like battery symptoms, try an auto parts store for a free scan, and see what they come up with.
    it would not be common for an oem battery, but very common for aftermarket.
    which is it?
  3. GreenMeanie
    42
    Sorry, it's OEM. I edited original post to clarify.
  4. bisco
    51,851
    i edited mine as well. the dealer should refund the $200. if it is the battery, ask them.
    but try my recommendation above first.
  5. GreenMeanie
    42
    Would you recommend getting the Dr Prius app and a reader and testing hybrid health myself? Also, can an auto parts store read anything if there is no error occurring at that time?
  6. bisco
    51,851
    it depends, some codes are stored and some are not. dr. prius is fine if you want to make the investment, or you can get a full prius reader for around $60. i think. i will look for the link.
  7. GreenMeanie
    42
  8. bisco
    51,851
  9. rjparker
    10,099
    6,263
    The dashboard (combination meter) on gen2s have been known to go bad. There are aftermarket repair services available or even diy but diagnosis with codes comes first.
    Most auto supply scanners can't read hybrid codes.
  10. GreenMeanie
    42
  11. Hayslayer
    Hayslayer Active Member
    390
    219
    most likely a brake system pressure issue.
    Tombukt2 likes this.
  12. Brian1954
    Brian1954 Senior Member
    2,162
    841
    South Central PA, USA
    Yes, that is the correct one.
  13. GreenMeanie
    42
    Ok, ordered it. Thank you all, even to the person who now has me freaked out over a potential brake issue.
    I'll come back with findings later this week.
    bisco and Brian1954 like this.
  14. Hayslayer
    390
    219
    Not meant to freak you out, but your symptoms match.
    Put your car in READY and wait for the engine to do its warmup and then shut off.
    Press the brake pedal a couple times and listen for a loudish but not loud humming noise coming from the other side of the firewall. You may need to do it a few times to get used ID-ing the noise. That is your brake actuator assembly (motor) pumping up the pressure in your brake fluid accumulator. Once you hear it start running, release the brake and don't pump it anymore. The pump should run within ~ 3-4 pumps of the brake pedal, it should run for a few seconds and then turn off. It should then stay off for hours if in good condition and the brakes are not pressed. If you hear it start again, then you have leakage in the system. This leakage is internal to the assembly and does not result in drips, just loss of pressure in the accumulator. This usually results in the actuator running about every 10-15 seconds to raise pressure, even if you don't press the brakes. Sometimes, it takes too long to raise the pressure, hence the loud beep, etc. Once pressure reaches minimum, the beep stops, etc.
    If you calms you any, I have a 2007 in the family that's been driven for the last 3 years with the same exact symptoms and it's still going strong. Actuator cycles every 9 seconds, for 3 years and about 40k miles so far. The beep happens about once every week or two. I just haven't gotten around to insisting on it being replaced
    #14 Hayslayer, Sep 15, 2025
  15. GreenMeanie
    42
    @Hayslayer, thanks, that calms me some. Any idea if the tester I have arriving this week will be able to identify that problem?
  16. Tombukt2
    12,908
    2,318
    That ap200 will test everything you need to test and probably more than you want to so just wait to get load up software choose Toyoda as primary. And let it rip. If what you receive is red white and black and not all white Apple looking send it back it should look like picture above.
  17. Hayslayer
    390
    219
    I don't know for certain. I've never used it.
    Now for the good news!!! I received a message this morning that it happened again on the 2007 when the car was started for going to work. I'm having them get the car over to the house this evening so I can connect my techstream computer. I'll get a list of any codes that may have popped up, just for you, so you'll have something to compare to!!
  18. GreenMeanie
    42
    Yay, thank you! I just tried the test a little while ago, and heard the noise, heard it stop, and then before I even put the car in gear to go, I heard the noise again. It's kind of a low humming purring sound, right?
    I should be receiving the tester tomorrow, so I'll confirm then. Then the question is, how much it's going to cost. I have a trusted regular mechanic that I would prefer to use versus dealership.
  19. Tombukt2
    12,908
    2,318
    About three 3:50 for a used part. And around 500 labour
  20. GreenMeanie
    42
    Ok, thank you. That I can live with. Curious, though; what's the part?
