Replacement OEM hybrid battery going bad after only 2+ years??
Discussion in 'Gen 2 Prius Main Forum' started by GreenMeanie, Sep 15, 2025.
  1. dolj
    dolj Senior Member
    8,437
    4,288
    Wellington, New Zealand
    Actuator Assembly, Brake - Toyota (44500-47141). This part number replaces 44500-47140.
    The new (online) price for this part from Olathe Toyota is currently $1,209.83, which is discounted from the MSRP $1,627.04 (25.6% discount of $417.21)
    I'm not sure what's up with the website. It says this part is OEM Toyota Actuator Assembly, Brake For 2006-2009 Toyota Prius, but then over on the right, it says this part does not fit your vehicle. It is definitely the correct part number for a 2006 Prius.
  2. rjparker
    10,119
    6,280
    Hoover has good prices
  3. Hayslayer
    Hayslayer Active Member
    393
    223
    So the diagnostics came back with a C1256, which is accumulator low pressure. Exactly as expected. The alarm was only for about 2 seconds and then cleared. The car is functioning just fine.
    These are available online new from Toyota dealers for $1200ish. If I planned to keep the car, I would spend the money on a new one. You don't want to pay labor twice or more if a used one doesn't work correctly. Doing the job right takes a bit of time as there's also specific brake bleeding procedures and some minor programming to do. Anyone can do it half-assed and skip steps because "i don't think it's needed". Two days later you have a bunch of chirping from the brake system because all the air wasn't removed. There's only one right way to do it.
    Toyota 44500-47141 ACTUATOR Assembly, Brake
    • Production Date: 11/2005-03/2009
    • Fitting Vehicle Options: NHW20
    #23 Hayslayer, Sep 16, 2025
  4. Tombukt2
    12,924
    2,322
    Brake actuator big hunk of aluminum
  5. GreenMeanie
    GreenMeanie Junior Member
    42
    Oof! A bit pricey. I should be able to run test tonight or tomorrow, so I can see if codes match.
  6. GreenMeanie
    42
    Ok, so I got the reader and plugged it into the car. I have all the software downloaded. It says that it pairs with my phone, and the green light turned to solid blue. I was finally able to run the autoscan. It scanned through a long list of things, ticking up the percentage the whole time, and it got to 100%. Then, I got this error message about abnormal VCI function. I've done this three times and keep getting it. I also got the error message about communication status. I attach screenshots of both here. There's a green check mark by the VCI, and a steady blue light on the device. Thoughts?
  7. rjparker
    10,119
    6,280
    I might try it in Ready which will give you 13.5 to 14vdc.
  8. Hayslayer
    393
    223
    If it's looking for Ignition-On, that is 2 presses of the power button with your foot NOT on the brake pedal.
    There are some ecu's (out of the typical 16 in the car) that don't always communicate properly when the car is in READY state.
  9. GreenMeanie
    42
    Aha! Ok, it wanted two presses, and I made a little bit of progress. But now it says there are no error codes! This was when I used the autoscan option. See attached. Now should I try it in Ready state?
  10. rjparker
    10,119
    6,280
    If you power cycled the 12v, codes may have reset.
    I borrowed an AP200 from a guy and tried it on my Prius v. I also read no codes but it has no symptoms. No problem using it in Ready.
    You want to be sure you are asking for all ecus, in my case it was 20.
    You get a list like this
    A screen capture pdf
    #30 rjparker, Sep 18, 2025
    Brian1954 likes this.
  11. GreenMeanie
    42
    Okay, I got the diagnostics run, but it does not seem to be great news. I attach a screenshot. Everything after number 11 was no fault. The only thing I was not surprised to see was the tire sensor problem because those sensors are screwed up.
    When I tried to go farther and click the arrow on each diagnostic, however, the device kept getting unpaired from my phone. So I couldn't do more. I will keep trying to see if I can get further. But this seems like a lot of faults...
  12. GreenMeanie
    42
    So, I have been able to get actual codes. Here they are, system by system:
    System 3, ABS/VAC/TRAC: Code C1256
    System 6, Hybrid control (note, both of these say "History" beside them--assuming this is from when I had my hybrid battery replaced): P0607 and B2799
    System 8, Cruise control: P0607 again, but here, it's marked as "Current"
    There are also errors for the tire pressure monitor system and the air conditioning system.
    Sounds like Hayslayer is correct, in that it's the brake accumulator system. Going to take it to my trusted local mechanic to see about a fix. I'm just not ready to give up on it yet and get a new one. At least that's what I'm thinking today...
    I thank all of you for your invaluable advice, and feel free to offer any additional nuggets of info as you see fit.
    --Meanie
  13. Brian1954
    Brian1954 Senior Member
    2,180
    854
    South Central PA, USA
    The fix for the C1256 code is very expensive. Report back when you get more information from your mechanic.
  14. GreenMeanie
    42
    Well, I just called my mechanic, and he's never heard of the brake accumulator system, so I don't take that as a good sign.
    Guess I'll try a dealership now...
  15. bisco
    51,884
    it's just a fancy brake actuator, same replacement process as standard. but some mechs are scared of hybrids.
    they'd rather do the same old thing day after day. hybrids scare them, and they're busy enough, or too busy.
  16. GreenMeanie
    42
    I had actually said brake actuator to him first, and he'd never heard of that. Then I corrected myself to accumulator, and he also drew a blank. So yes, maybe he just doesn't want to deal with it.
    Anybody happen to know of a good local mechanic in the San Diego area?
  17. bisco
    51,884
    if you google it, a few come up. i would look at reviews, and get a few quotes
  18. GreenMeanie
    42
    Just spoke with SD Hybrids. $2500 for OEM parts and labor. Ayiyiyi.
  19. bisco
    51,884
    that's pretty much the going rate, maybe even a little low. these cars do not save money, they save gas and pollution.
  20. Brian1954
    2,180
    854
    That is a pretty good price. If you have time, call a few other places to compare.
