2020 Alignment Specs
Discussion in 'Prime Technical Discussion' started by CP1, Sep 4, 2025.
  1. CP1
    CP1 Junior Member
    Iowa
    Does anyone have the alignment specs for a 2020 Prime?
    Thnaks!
  2. RayEarlStoddard
    RayEarlStoddard New Member
    Earth
    2022 Prius Prime
    Owner of a very respectable shop told me,
    “On rear drive cars, caster is more important than camber. On FWD cars, camber is more important than camber.
    Unrelated, at a Moog/Monroe seminar I was told by an instructor, to set the toe to 0 degrees. I raised my hand and said “ what models, what years?” To which he replied “ all models, all years”.
    I was surprised but restrained myself. Make of these stories what you will.
  3. RayEarlStoddard
    Earth
    2022 Prius Prime
    Correction: on FWD, camber is more important than caster.
  4. Mendel Leisk
    41,643
    I would think it’s the same as any 4th gen.
  5. PixelRogue
    488
    86
    US
    Hello all,
    Just had an alignment and after everything has been aligned, learning there is a 'camber' issue that falls outside the scope of the alignment and the shop said I had to talk to a store manager when they are back in the shop. They mentioned aftermarket kits. Fair amount of digging online and maybe more confused then when I learned of the need.
    2021 Prime
    I am handy enough around cars, have a torque wrench and such. Is this something easy enough for a first-timer, or not worth the effort and hire a shop to fix?
  6. PixelRogue
    488
    86
    US
    Update:
    Shop service manager (non-toyota) is saying there are no specs, and an after-market kit would cost hundreds to purchase and install with zero guarantee and even a new one would not be adjustable, recommending rotating tires slightly more often than normal.
    Seems a bit fishy.
  7. Mendel Leisk
    41,643
    Hmm…
  8. PixelRogue
    488
    86
    US
    Thank you @Mendel Leisk (saw that elsewhere and didn't look hard enough in the doc for rear camber.)
  9. PixelRogue
    488
    86
    US
    Rear right camber shows -2.3%.
    In addition to saying 'no specs' shop is saying not a big deal, simply rotate tires a little more often...(?)
