Urgent Help Needed!
Discussion in 'Gen 2 Prius Technical Discussion' started by Duncwarw, Jul 8, 2025.
  1. bisco
    52,093
    still sounds like the battery to me. any trouble codes?
  2. Brian1954
    Brian1954 Senior Member
    2,304
    919
    South Central PA, USA
    The drive shaft between the engine and transaxle could be broken. There have been reports of this happening a couple of times in this forum.
  3. Duncwarw
    Duncwarw Junior Member
    Capital Region, NY
    I'll check with Techstream tomorrow but the 12v is new and on a trickle charger and the HV battery is fully charged too.
  4. Duncwarw
    Capital Region, NY
    Interesting. I don't see how that could be the problem though.
    The car was in use daily and I thought I'd install new sparkplugs and injectors and it hasn't really run since.
    Over my troubleshooting attempts to get it to run though, the HV battery went badly depleted which led me to pulling it, removing bus bars, charging all modules and replacing a few after multiple discharge/recharge efforts.
    Thanks for the info though, I'll research the driveshaft thing.
  5. rjparker
    10,238
    6,393
    There is a spring loaded damper that slips and makes the awful rattling while misfiring. It could be broken and has happened before as Brian noted.
    If the above was allowed to happen many times as the hv battery drained, the damper springs could have failed. Rare but possible. Even more unusual would be something jamming the engine as a result.
    I suspect a very basic fault happened when you took a good running engine and changed coils and injectors. Maybe a pulled wire on the coil wiring harness or a cracked insulator on the plugs. Backtracking then would have been a good move. That problem is probably still there.
    I must say that was a good move although who knows what the parts car had for a hv battery.
    Codes could tell the story.
    #25 rjparker, Sep 17, 2025
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,062
    1,981
    NJ-USA
    Put a wrench or socket on the crankshaft pulley bolt and see if the engine can be turned a few revolutions in the clockwise direction. (with everything turned off)
    What codes are present (you mentioned VSC light)?
  7. pasadena_commut
    pasadena_commut Senior Member
    2,699
    806
    Southern California
    Transmission in Neutral first?
  8. ChapmanF
    18,316
    Prius has a funny transmission. It is always inherently in neutral unless the car's high-voltage electronics are making it be otherwise.
    When the car is turned off, you can turn the engine easily with a wrench on the crankshaft pulley any old time (unless something is b0rked).
    You can't push the car before shifting out of Park, just because the parking pawl prevents that.
  9. Duncwarw
    Capital Region, NY
    Good to know. I just dragged the parts Prius out of my way.
    I'll try to remember that the next time I have to move a "good" one. Too many cars...
  10. Hayslayer
    Hayslayer Active Member
    419
    246
    Why do you feel the engine is fine? Have you tried spinning it by hand?
    Your symptoms sound exactly like a locked engine. Saw that only one time when a 2008 was run with low oil until she locked up, and stayed locked up.
  11. mr_guy_mann
    4,062
    1,981
    NJ-USA
    No. Turning the engine causes MG1 to move through the planetary gearset.
  12. ChapmanF
    18,316
    ... which, just to be clear, means you don't have to do anything special first before turning the engine, because MG1 is just a rotor that's free to spin when the car isn't on and electrically constraining its motion.
    In a conventional car with, say, a manual transmission in neutral, turning the engine would cause the transmission input shaft and countershaft to turn. So, either way, you're spinning a few extra kg of metal things, but nothing that would make your engine-turning test difficult.
  13. pasadena_commut
    2,699
    806
    Southern California
    True, but the repair manuals all make a point to put it in neutral because manual cars are usually parked in first or reverse. I suppose if the car is up on lift points with the wheels dangling one could still turn the motor in gear, and also turn the drive wheels. Probably not though if it was on the sort of lift where the wheels still bear the car's weight, or on the ground, and the parking brake set.
  14. ChapmanF
    18,316
    In post #32 I intended to (and think I did) describe "a manual transmission in neutral". When a manual transmission is in neutral and you turn the engine crankshaft, you're also turning the transmission's input shaft and countershaft, but not the output shaft, so the wheels don't have to move. Yes, with the manual transmission it's up to you to make sure it is in neutral first so you can do that.
    In a Prius transaxls with the car off, when you turn the engine crankshaft, you're also turning the transaxle input shaft, planet carrier and sun gear, and MG1 rotor, but not the output shaft, so the wheels don't have to move. You don't have to do anything special first, because this 'neutral' condition is the Prius transaxle's natural state, any time the high-voltage electronics aren't making it do something different. (It can, in fact, be in Park, with the parking pawl holding the output shaft from turning, rather than Neutral with the parking pawl withdrawn, but that only affects whether you can roll the car, not whether you can turn the engine.)
  15. mr_guy_mann
    4,062
    1,981
    NJ-USA
    Think of it this way. The Prius uses a planetary gearset, which has three "elements" (ring gear, sun gear, and planetary carrier). If you "hold" any one element, and put torque into a second (input), you spin the third (output).
    When the car is in park, the drive wheels and MG2 are locked. In ready mode, the ecu can command MG1 to spin (input) in order to start the ICE (output).
    If the car is powered off, moving the ICE (input) just causes MG1 to spin freely (output).
