Turtle light appeared on the instrument cluster...
Discussion in 'Generation 1 Prius Discussion' started by War_Destroyer, Jul 29, 2025.
  1. War_Destroyer
    War_Destroyer Junior Member
    35
    Los Angeles
    2002 Prius
    My little brother told me that a turtle light had appeared and that the car became sluggish, and that it disappeared while he was parked relaying that information to me. He was able to drive back home without issue. When he got home I scanned it with Torque Pro but there weren't any fault codes recorded? What do you guys think?
  2. ChapmanF
    18,071
    Yes, gen 1 had a turtle light, which would come on in circumstances where the car was reducing demand on the battery to protect it. Circumstances where the battery was extra hot or extra cold would be examples. I got it one time while driving slowly up the narrow road from the base of the New River Gorge Bridge.
    The light comes on to caution you that you might not get as much zip as you're used to if you goose the go pedal. As soon as conditions are comfortable again, the light goes back out, and you have the accustomed zip again.
    mroberds and ammdb like this.
  3. ammdb
    ammdb Active Member
    277
    111
    Indianapolis
    I'm guessing he was driving in hot weather. The traction battery has a fan which pulls room temperature air from the cab, but under some conditions the turtle light comes on if the battery is too hot or cold. The only time I saw the Turtle was when temps reached -30F.
    mroberds likes this.
  4. VintagePrius
    VintagePrius Junior Member
    UK
    1998 Prius
    The Turtle will also come on if one (or more) of the HV battery modules drops below or goes above its normal operational range—hard acceleration or heavy regen can sometimes cause this, especially if there's a failing module or if the modules are out of balance. If it starts doing this regularly then you should try and get a scanner that can record the module voltages while driving. That way, if it's modules out of balance and you're electrically inclined, you can maybe balance the pack manually before it gets too bad and ev range falls and mpg suffers.
  5. dabard051
    dabard051 Tinkerer-in-Charge
    258
    97
    Rochester, NY USA
    2002 Prius
    Apparently, Gen I TurtleMode does NOT set any fault codes (DTC) for Techstream to pick up, even when lit.
    PrimeDan likes this.
  6. ChapmanF
    18,071
    I am sure that the turtle light does come on for the reasons given in the owners' manual and reviewed upthread in post #2.
    I am not sure that the turtle light comes on for reasons other than those.
    The car does monitor for voltage / charge state / IR imbalances between modules, and has trouble codes and a red triangular light for reporting those.
  7. VintagePrius
    UK
    1998 Prius
    My thoughts here…
  8. ChapmanF
    18,071
    That's a quote from a longer post that advances a claim that the owners manual doesn't go into all the reasons.
    My thoughts on whether the claim is well-supported can also be found in that thread.
  9. mroberds
    mroberds Member
    143
    58
    2001 Prius
    I got a turtle light exactly once, so far. It was in 2007 or 2008, in the summer. The car sat outside in hot weather, 95 to 100 F, all day, and I got the light when I went to drive home in the evening. I don't remember how long it lasted, but I think it went out on the drive home (about 10 miles). I think I ran the A/C in the car, which also supplies the traction battery with cool air.
    In July, 2010, the battery failed - one module went bad.
    I've never scanned a car with the turtle light on, so I don't know if it sets a DTC, or is otherwise available in Techstream. As above, Toyota calls it the "output control warning light".
    I do have one screenshot of the live data HV Battery ECU, and the only thing on there that it *might* be is called "normal status" - it's a yes/no value. It might be on one of the other live data screens, though.
