Lithium or sodium for replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drmax, Aug 4, 2024.
  1. ChapmanF
    17,713
    i see what you did there
  2. Paul Gregory
    Paul Gregory Senior Member
    1,887
    471
    Alberta
    2024 Prius Prime
    XSE
    I think I might wait before investing in a new battery pack. We seem to be in the nascent stages of what might be a quantum leap in battery technology. Or not, but in any case, it could be a major mistake to buy in at this stage.
  3. T1 Terry
    T1 Terry Active Member
    890
    457
    It's either old skool tech, run at half it's operating capacity to give the maximum headroom to allow minimum cell management using a chemistry that can handle being over capacity charged short term with out failing completely ...
    or
    High tech advanced battery design that requires continuous cell level monitoring and balancing, because it doesn't have the ability to handle over capacity charging of any cell. This would involve a feed back loop that could control current in both directions, sensing any cell that is under performing and using that as the basis of the whole pack performance.
    The way that last problem is dealt with in more modern battery design, is multiple cells in parallel to build the base capacity, then these groups in series to build voltage. This way, the BMS only has to monitor a single parallel group, any under performing cell is balanced out by the other cells in parallel .... I.E. a single cell in a 4 cells in parallel group drops to 50% capacity, the effect on the over all battery is only a 12.5% loss in capacity, not the 100% loss if it had been a single cell design.
    A good active cell balancing system could minimise the loss in capacity even further, by splitting the capacity of the remaining series groups and supplying that back to the weak cell group when ever the voltage differential became apparent.
    T1 Terry
  4. Grit
    Grit Senior Member
    6,563
    4,222
    Wilkes Land
    Yes, send me $100 via cash app
  5. T1 Terry
    890
    457
    Ahhh, but would you just spend it on more drugs? ;):ROFLMAO:
    T1 Terry
  6. ASRDogman
    ASRDogman Senior Member
    7,405
    3,859
    Is it sodium money?? :eek::rolleyes::whistle::whistle:
  7. T1 Terry
    890
    457
    That would be just rubbing salt into the wound :D
    T1 Terry
    ASRDogman likes this.
  8. ASRDogman
    7,405
    3,859
    That is a good one! Very salty!
    Salt, is GREAT!
  9. Paul Gregory
    1,887
    471
    Alberta
    2024 Prius Prime
    XSE
    Sodium is not salt, it is a metal.
    Sodium chloride is a salt, one of many salts.
    A salt is an acid combined with a base.
  10. ASRDogman
    7,405
    3,859
    Salt Sodium Salt Sodium Salt Sodium Salt Sodium Salt Sodium
    It's the same thing, but it's different.
    It's different, but it's the same....
    Actually, Sodium ion....
    Complain Complain Complain....
  11. Paul Gregory
    1,887
    471
    Alberta
    2024 Prius Prime
    XSE
    I'm no psychologist, but something is wrong...
  12. ASRDogman
    7,405
    3,859
    That's the first step....
