Easiest & Quickest method for Balancing Hybrid battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by meyouall, Sep 17, 2025.
  1. meyouall
    meyouall Junior Member
    Rotterdam
    I tried to find the answer through searching but failed.
    - Which balancing method can one use to easily and quickly (not days/weeks) balance hybrid battery pack after one or two cells are replaced?
    - I have seen videos of hybrid automotive where he uses 3 methods— Prolong charger, equalizer cables and the method with two bars (all + on one side and - on other). Unfortunately his Prolong charger isn’t available in the EU. The other two methods is equalizing, not balancing; right?
    - If you recommend some sort of grid charger, please mention its name and would it do the job all at once— meaning the whole pack or will have to do it per block/module?
    I get an error code which says that block 4 is weak. It could be one cell in that block or both cells, I haven’t checked it yet.
    The Prius concerned is from 2006. 330k km. Based in the Netherlands.
    Thank you!
    52,220
    you should be able to find a grid charger like prolong available in the eu. or you can build one.
    Brian1954 likes this.
  3. dolj
    dolj Senior Member
    8,494
    4,313
    Wellington, New Zealand
    There is no such thing. Restoring a failed pack takes time. How much time? It depends on the extent to which the battery has degraded. A simple, straightforward reconditioning cycle based on time, with no indication of errors, takes five days with a grid charger, if you want to sleep while doing it. With no sleep, you might do it in three days. ;) It takes considerably longer using a one or four-channel NiMH hobby charger.
    Correct. It is a process that has demonstrated no measurable benefit, so it is a waste of time.
    You mean one or more cells within one or both modules in block 4, yes. Inevitably, you will need to replace one or both modules using a reasonably (if not perfectly) matched module. Matching the replacement module to the remaining existing modules (in terms of capacity) is the real secret to having a reliable repair.
  4. meyouall
    Rotterdam
    Building one is out of the question. No experience!
    If you know a good one online, please share a link.
  5. meyouall
    Rotterdam
    - Do you know which charger can make the process shorter?
    - I thought as the builder of the prolong charger Jose would know very well what he is doing. Apparently not?!
    - See the attachment for the exact error code. If i’m not wrong each block contains two cells. If it says block 4 is weak then one or both of those cells are weak right?
  6. douglasjre
    douglasjre Senior Member
    2,198
    731
    Null, NL
    They won't stay balanced. Buy a new pack. Pay once cry once
  7. dolj
    dolj Senior Member
    8,494
    4,313
    You could make your own charger and pump a higher current into each module. This will make the process go quicker, but you also risk damaging more modules. If you end up needing to replace more than three or four modules in a pack, you should consider buying a new pack—pay once, cry once. Unless, of course, you find it fun to take the pack out of the car multiple times, replace modules, balance the pack, and reinstall it over the course of a year.
    Your understanding is slightly off. Each block contains twelve cells. These twelve cells are arranged in two modules, with each module containing six cells.
    Yes, within block 4, it could be that one or more cells in either or both modules have failed.
  8. ilbdarned5
    ilbdarned5 Junior Member
    Blanchard, Oklahoma
    Watch this video, it tells you what you need and how to do it.
  9. highmilesgarage
    highmilesgarage Active Member
    488
    180
    Kansas City
    if you're a DIY you could just try replace it with modules available online (eBay or 2nd life) I bought a grid charger from Venice Hybrid, they have one specifically for Prius (actually this can be DIY too but I want to fix the car quick and not experiment) The grid charging process doesn't really balance them but it just equalizes the voltages on all the modules within the .3v difference between modules. I think "balancing" is more of making their capacities all equal which requires time and money (proper equipment) You could get lucky and make it work. For me another module failed after 2 yrs and I'm able to replace it with the same process.
    after 2 yrs
    here's the inside of the Venice hybrid charger.
  10. douglasjre
    2,198
    731
    Null, NL
    I giggle every time I hear about this balancing act. Won't matter how you balance em...if they're mismatched by lifecycle then they'll be mismatched as they charge up a d discharge down....while in use....every. Single. Time. Unfortunately I've t reached my limit for how many users I can block (1,000) so now I read these messages from new users who subscribe to these misadventures
  11. highmilesgarage
    488
    180
    Kansas City
    it's really a question of long term fix vs short term fix.. most of the videos in youtube don't have any long term updates.. they are mostly for views. You could buy new which is a long term fix but cost a lot of money or buy reconditioned which is also a short term fix or DIY which also cost you money and time and questionable longevity (might be bad tomorrow, next week, month or years... depends on your luck)
  12. rjparker
    10,369
    6,491
    You will notice this guy has a large stock of modules and it takes time and money to get results which are not 10% as reliable as new oem.
    Prius Hybrid Battery Reconditioning "How To Properly Repair A High Voltage Nickel Metal Hydride (NiMH) Battery Pack For Hybrid Vehicles"
