Black Front Grill (Not Silver)
Discussion in 'Gen 5 Prius Accessories and Modifications' started by ORWolf, Oct 30, 2024.
  1. Teez
    Teez Junior Member
    37
    Toronto
    2025 Prius Plug-in
    SE
    Just wondering how the wrap is holding up and looking after highway driving ect? I had another car that I painted the grill black and I constantly had to touch it up because of chipping from rocks and debris hitting it. Does the wrap hold up well from rocks hitting it and chipping?
  2. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Where'd you get that done? I'm assuming you're in the Portland area? If so I might take mine over to get the same.
  3. MScelery
    MScelery Junior Member
    83
    24
    Mississippi
    Can someone link me to the etsy black emblem referenced in this thread? I’m having a debate between buying and LE and and XLE, because of the same issues of wanting all black. Would love a nightshade, but none in my area.
  4. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Finally got around to dealing with this. I got a Nightshade grille from Toyota , got that ppf'd , and installed it today. Pretty easy job overall just take your time with the clips. Also swapped the chrome cowboy hat badge to a black one from the Etsy guy.
    RollingPanda, MScelery and otatrant like this.
  5. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    https://www.etsy.com/shop/Zappliances
    The adhesive sticker on the one I got wasn't great so I changed it out for some vhb.
  6. MScelery
    83
    24
    Mississippi
    Is the nightshade grille a different part # than the base model grille?
  7. bob12345
    bob12345 New Member
    25
    Knoxville, TN
    2024 Prius Prime
    SE
    I purchased a nightshade edition grille for my SE trim vehicle and no fitment issues. PN: 53112-47370, Grille, Radiator, Lower.
    mva and otatrant like this.
  8. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Yes, it's 53102-47260 (with fog lights)
    That's 1 pc all soft black plastic right? I actually bought that same one by mistake the first time ordered. This isn't the nightshade grille, I think it's for 2026 LE/SE. The nightshade is 2 pieces with a painted glossy black insert it in the middle and it's about twice the $$$.
    #28 PhoS, Sep 21, 2025
  9. bob12345
    bob12345 New Member
    25
    Knoxville, TN
    2024 Prius Prime
    SE
    Yes, flat black plastic, not sure I would call it soft plastic though. When I used Toyota's site and a VIN of a nightshade edition Prius, the 53112-47370 PN appeared as a match. I see now the PN you provided is a glossy black and the actual lower grill of the nightshade edition. After seeing the price difference now between the flat vs glossy, I am glad I accidentally stumbled upon the LE/SE grille (no foglight cover). At least now there are two PN's drivers have a choice to choose from and both options still better than the bright Silver Gray color grille. I did find this video helpful in taking off the front bumper.
    MScelery likes this.
  10. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    That is the same way I ended up with that version, I searched for 2026 Nightshade. The Toyota parts site doesn't allow you to specify variants just off a vehicle search but if you notice the in the diagrams at the bottom there are several pages which show the different versions it just doesn't allow you to select them individually. "Soft plastic" is maybe too specific sorry I work with plastics every day but it is a different composition than the 2 pc versions.
  11. MScelery
    83
    24
    Mississippi
    Just in case anyone else wants to be an idiot like me…
    I ordered the LE front bumper thinking the black part that I needed to replace the silver part on my limited would just pop out.
    It doesn’t.
    Unless I’m missing something, if you want black AND want to keep the fog lights or whatever they are, only option is the Nightshade part.
  12. RyanGphoto
    RyanGphoto New Member
    Tampa, FL
    2025 Prius
    Anyone have a nightshade part # that works with the Limited model? I too would love the black grille for a limited.
    Thanks
    Ryan G
  13. Hammersmith
    Hammersmith Senior Member
    2,326
    2,379
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    53102-47260 - works with anything except an LE or SE. It might even work with an LE or SE if you swap over the fog light covers, but I can't guarantee that.
    If you wait until Black Friday, you should be able to get it for $142 at someplace like Lewis Toyota(autoparts.lewistoyota.com) or Premier Toyota(autoparts.premierautoplex.com). Both are genuine Toyota dealerships that are part of the autoparts.toyota.com network. There are other dealerships in the network that are closer to you that might have the same discount(look for 31% off or better). Free shipping for orders over $75, and possibly no sales tax applied if the dealership is in a different state than the shipping address.
    VelvetFoot likes this.
  14. Hammersmith
    2,326
    2,379
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just a reminder:
    53102-47220 - XLE/LTD
    53102-47230 - SE
    53102-47240 - XSE/XSE+
    53102-47260 - Nightshade
    53112-47370 - LE
    I think you can make a higher trim grille work on an LE/SE, but maybe not the other way around. We'd need to get an LE or SE owner that's taken apart their grille to chime in. If the fog/accent light covers are molded into the grille, then you can't use an LE/SE grille on an upper trim, but you still should be able to use an upper trim grille on an LE/SE if you also buy 81481-47110(RH fog lamp cover), 81482-47110(LH fog lamp cover), and six 90167-50063 screws. The covers screw into the grille right where the fog/accent lights would go, and then the whole thing gets screwed into the bumper cover just like the original.
    otatrant likes this.
  15. VelvetFoot
    VelvetFoot Active Member
    1,231
    480
    New York State
    2026 Prius
    For an LE/SE, would painting it be out of the question?
    A rattle can job might not turn out that great, but it is down low where nobody looks close, and even chips or drips might not be super noticeable.
    I realize that taking it to a body shop would likely be as expensive as new parts, but you wouldn't have to mess with fog/accent light covers, with more certainty it would work, at this point in time.
  16. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    The gray insert can be removed pretty easily from the 2pc grille for painting. It would probably cost you $400-600 so it's not really worth it over getting Nightshade.($190) I highly recommended PPF as that part eats rocks and it will be ugly very fast. I only have 25k on my car and my gray grill looked like I drove though a gravel pit. The paint quality on Toyotas is pretty embarrassing these days..
    RyanGphoto likes this.
  17. MScelery
    83
    24
    Mississippi
    How does the grey piece get removed? I accidentally ordered the LE grille to use to replace the silver one on my limited thinking I could just pop out the “middle” piece to not lose my fog lights, but I’m not seeing anywhere that the middle piece comes out of the larger piece.
  18. Hammersmith
    2,326
    2,379
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm just curious, can you confirm that the fog light covers are molded into the LE grille and not separate pieces that are screwed into it?
  19. MScelery
    83
    24
    Mississippi
    I’ll go look
  20. MScelery
    83
    24
    Mississippi
    I’m not seeing any type of cover or plate with screws or clips for the fog lights. Also included an image of the back side of the grille so those trying to swap from silver to black can see that the center piece (unless I’m missing something) isn’t swappable.
