P0560 troubleshooting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cincy14, Sep 20, 2025.
  1. cincy14
    cincy14 Junior Member
    Johnsville, OH
    I have code P0560 that I’m not sure how to proceed with. I’ve seen a couple other threads that mention checking the engine ecu / ecm. The ecu fuse is good and I have 13-14 volts at the fuse terminal. Once I figured out where the ecm e7-6 pin was, I’m only getting 0.2 volts there but it is difficult to get a good connection with my multimeter. I did measure 13-14 volts on pin e7-5. While I was behind the glove box I checked the cabin filter and found a mouse nest that’s probably been there a while since I haven’t checked it in a couple years. Where should I check for wire damage causing the low voltage? I don’t see any damage from mice behind the glove box.
    I also found the diagnostic instructions for this code that say to check the HV fuse and the battery ecu. The HV fuse is good and I have 13-14 volts at the fuse terminal but I have not dived into the battery ecu yet. Could a battery ecu problem cause the ecm low voltage?
    Any help is much appreciated. The car does drive normal.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,062
    1,981
    NJ-USA
    So, you should google "how to backprobe a connector". This can show how to get a good voltage reading without damaging the terminal.
    If you do not have 12V "battery voltage" at the red wire for E7-6, then you have an open circuit somewhere. You need to physically inspect the wire harness from the ECM back through the firewall, to the engine fusebox.
    The wiring diagram shows a single wire from connector 3I-5 all the way to the ECM. 3I is on the bottom of "unit B" inside the engine fuse box.
    If you have confirmed power at both legs of EFI fuse, then I would check for 12V at 3I-5.
    Sometimes I consider running a new - separate wire (called an overlay) to bypass a faulty circuit, but I usually want to find the point of failure. There could be damage to other wires as well.
  3. mr_guy_mann
    4,062
    1,981
    NJ-USA
  4. cincy14
    Johnsville, OH
    Thanks @mr_guy_mann I will update when I get time to investigate more
  5. cincy14
    Johnsville, OH
    I was able to get a better back probe of terminal e7-6 and I’m getting 3.5 volts. There’s no obvious sign of wire damage around or behind the ecm or along the firewall but visual inspection is limited. Would removing the wiper cowl allow better access to the harness? How difficult is it to inspect connector 3I on the back of the fuse box? It looks like removing a couple screws will allow it to pivot up.
  6. ChapmanF
    18,316
    3I is on the bottom of one narrow, removable, four-fuse module in the fusebox. You spread some clips apart and that module lifts right out, and the wires plugged into 3I, 3J, and 3K come right up with it so you can access those plugs. No need to take apart the fusebox itself.
  7. cincy14
    Johnsville, OH
    Another update. I attempted removing the C module in the fuse box but could not get it to come out enough to inspect the connectors. I pulled the B module beside it out some but that didn’t help. I checked the E7-6 voltage many times while moving the module and the harness around but it stayed steady around 1 volt. I don’t think the issue is at the 3I connector since moving it around should have made the voltage worse or better. I did notice the voltage dropped to 0.5 after removing and replacing the EFI fuse and then slowly increased to a little over 1 volt, which was strange. The only part of the harness I can’t see is on the drivers side behind the inverter so I think my next step is to remove the cowl.
  8. ChapmanF
    18,316
    They should pull out farther than that. :confused:
    I worked on one once (I was trying to pull out the fusible link assembly, long white thing, kinda works the same way) and the wires to it had become extra stiff. (I don't think that's something that happens to copper, but to the plastic insulation.) I had to work it up in stages, where I'd pull up as much as I could, set some kind of clamp to hold it there while I went and did something else for 20 minutes or so, come back and repeat ....
  9. cincy14
    Johnsville, OH
    Ok I tried again and got the C module out enough to take the 3I connector off. There’s nothing wrong with the connector or the wires underneath the module. The voltage on the output of the C module is good. I suspect the problem is in the harness along the firewall somewhere.
