Replacement OEM hybrid battery going bad after only 2+ years??
Discussion in 'Gen 2 Prius Main Forum' started by GreenMeanie, Sep 15, 2025.
  1. ChapmanF
    17,735
    When you're talking gen 2, the actuator and the accumulator are built into the same single assembly you can buy, so it isn't very critical which word you use, you get the same part.
    In other generations, not so much.
  2. rjparker
    9,872
    6,088
    It is called a "Brake Actuator" by Toyota and sometimes simply "Master Cylinder".
    I am sure he has heard of that.
    The part price a week ago shipped was $982. Somebody who works on Toyota and has their Techstream scanner could do it in four hours. You do the math.
  3. dolj
    dolj Senior Member
    8,326
    4,251
    Wellington, New Zealand
    I don't believe the brake actuator and master cylinder are the same thing.
