Prius Prime Recommended Service
Discussion in 'Prime Main Forum (2017-2022)' started by richard203, Sep 18, 2025.
  1. richard203
    richard203 Member
    275
    60
    SF
    i was wondering what should i do, previous owner did not do any maintenance at all. the car have 180k miles. I am planning to do the following maintenance
    Tranny Fluid change
    Brake fluid Change
    Oil/filter Change
    Spark Plug Change
    Coolant/Inverter Fluid Change
    Water PUmp - ??
    Thermostat - ??
    PCV valve - ??
    let me know if i miss any other stuff
  2. notspam3
    notspam3 Junior Member
    49
    22
    Toronto
    2024 Prius Prime
    XSE Premium
    I'd first change the motor oil and filter, then I'd start looking to trade for a new set of wheels instead of flushing more money down the toilet.
  3. bisco
    51,975
    what year is it?
  4. richard203
    richard203 Member
    275
    60
    SF
    maybe if you don't got have anything good to say u can maybe don't contribute.
    2017
  5. bisco
    51,975
    i would do everything in the maintenance schedule. have you looked at the owners website to see if any dealer services were ever performed?
  6. Mendel Leisk
    41,488
    Attached is a summary of the gen 4 Prius maintenance schedule, based on Toyota USA’s Warranty and Maintenance Booklet. If missing that booklet can be downloaded from Toyota Tech Info website, under the Manuals tab.
    are you intending to DIY all or some?
  7. notspam3
    49
    22
    Toronto
    2024 Prius Prime
    XSE Premium
    You can lead a horse to water...the truth hurst sometimes don't blame the messenger
  8. richard203
    richard203 Member
    275
    60
    SF
    ya ima diy most of it
  9. richard203
    richard203 Member
    275
    60
    SF
    do you know if the gen4 Prius is same as gen2 and gen3 wheres the cat is very popular and get stolen? If so I might get a cat shield
  10. bisco
    51,975
    toyota has reduced precious metals with each generation. what thieves know, and how often gen4 cats are stolen may prove difficult info to find.
    some here have added a shield. if it is still bad in san fran, it might be a good idea.
    on the other hand, if the cat has not been replaced, and the exhaust coolant heat exchanger starts leaking, you have to replace the cat as a unit.
  11. richard203
    richard203 Member
    275
    60
    SF
    just finished changing out the spark plug today. the 3rd spark plug have some oil on it. Next will change out the tranny fluid and change out the coolant fluid. do these car need to change out the pcv valve like the gen2?
  12. Mendel Leisk
    41,488
    Wouldn't hurt. New PCV valve from dealership parts department is around $10 USD. That said, I've only ever removed them, sprayed carb cleaner through, gave them a shake, applied thread sealer and reinstalled. Could be the internal spring weakens though, and replacement is cheap.
    You might be able to access it from below, it's same location as gen 3 which I've done. Other'n that you'd need to remove intake manifold. Wouldn't hurt to do that and clean the throttle body while it's off. You can likely do that without removing the throttle body's coolant hoses.
  13. richard203
    richard203 Member
    275
    60
    SF
    just cleaned the TB, MAF sensor and changed out the coolant and realize they gived me the wrong coolant. They gived me the red ones instead of the pink one. they going to exchange it back and give me the correct color. will update after i redo it again.
  14. richard203
    richard203 Member
    275
    60
    SF
    Any1 know what’s this do?
  15. bisco
    51,975
    looks like a charge timer, but idk
  16. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    To the OP. You are doing what you are supposed to do. Don't worry about those who are trying to scare you. Prius is one of the most reliable, efficient and affordable cars on the market. 180k miles on a 2017 Prius is nowhere near where you need to worry about it.
    I bought a 2010 Gen3 prius at 142k miles, enjoyed it for 7 years. And sold it at 207k to a friend who already put 20k miles in a few months. The car is running like a champ. In my 7 years of ownership, I did most of the maintenance myself. I enjoyed every minute of it.
    I am now driving a 2017 Gen4. I love it. Good luck and drive safe.
