1. Joe Mascitti
    Joe Mascitti New Member
    Atlanta, Ga
    Hello all
    My wife’s 2013 Prius just developed a p2616 code which is cam sensor. I replaced the cam sensor, reset the code. She drove it for a bit and it reappeared.
    Wiring looks good
    what next?
    thank you
    51,901
  3. Brian1954
    Brian1954 Senior Member
    2,194
    862
    South Central PA, USA
    Double check the code you are reading. I think P2616 is not a valid code for a 2013 Prius.
    What scanner are you using?
    #3 Brian1954, Sep 27, 2025
  4. ChapmanF
    18,160
    P2616 isn't in the 2010 repair manual PDF that floats around the internet, but it's possible Toyota could have added it in a later year.
    All P2 codes are standardized by SAE, and in a list of those codes it has the fortune cookie "Camshaft Position Signal Output Circuit High".
