2008 won't start after sitting for 2 weeks. CM, ECU, or Hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusOwner428, Sep 17, 2025.
  1. PriusOwner428
    PriusOwner428 Junior Member
    68
    IL
    OK thanks. I think this helps me get a better understanding. I think what you're calling IG ON is what I'm calling ACC. It's what you get when you push the power button once or twice without depressing the brake. It powers your radio, windows and cigarette lighter sockets correct? So with the hybrid battery not being the culprit it's looking more likely like a mouse.
  2. ChapmanF
    17,757
    The "once or twice" matters, actually. Once is called ACC, twice is called IG ON.
    ACC powers the infotainment stuff and the power sockets. IG ON powers all the things (but doesn't start the engine or bring the hybrid system online). To get the hybrid system online and drive the car, you go READY (push the button with the brake pressed).
    PriusOwner428 likes this.
  3. T1 Terry
    T1 Terry Active Member
    914
    466
    The fuse is in that orange plug. Check for continuity between the two big terminals on the orange safety plug, it you have continuity, the fuse is ok, time to expose the battery and start checking voltages.
    The delay between the ign sequence being engaged and the ready light coming on is the system waiting for precharge resistor to bring the voltage up to the same level either side of the contactors, then they will engage ..... the clunk clunk sound heard in the left corner behind the rear seat.
    I think the next step is to expose the contactors and associated gear (BMS or battery computer as Toyota call it, the precharge resistor and some associate wiring) check the voltage between the battery side of the negative contactor and the battery side of the positive contactor, that will tell you if the modules in the battery pack are at least charged enough to bring the precharge circuit to attempt to charge the capacitors in the motor inverter, if it can't do that, nothing much will work except for all the 12v appliances .....
    Here is the Google AI overview of how to expose the hybrid battery
    AI Overview
    +2
    To access the Prius Gen 2 battery contactors, you must first open the trunk, then remove the trunk liner and cargo tray to reveal the high-voltage battery. You'll need to remove the safety plug and then carefully remove the battery cover by taking out the 10mm bolts or clips to expose the high-voltage battery and its junction block assembly, where the contactors (including the pre-charge contactor and the negative and positive contactors) are located.
    Step-by-Step Guide
    1. Open the Trunk: Open the trunk of your Toyota Prius.
    2. Remove Interior Panels: Remove the trunk liner, cargo tray, and any other panels blocking access to the hybrid battery.
    3. Locate the High-Voltage Battery: The high-voltage battery will be visible in the rear of the vehicle.
    4. Remove the Safety Plug: This is a crucial safety step. Locate and remove the orange-colored service plug (or safety plug) by turning its lever and pulling it out, which will kill the high voltage.
    5. Remove the Battery Cover: Take off the battery cover by removing the 10mm bolts or clips that secure it.
    6. Access the Junction Block: Once the cover is off, you will see the junction block, which contains the contactors. You will see the positive contactor, the negative contactor, and the pre-charge contactor (located under an orange bracket).
    Important Safety Information
    • Always Disconnect the 12-Volt Battery First:
      Before you even think about the high-voltage battery, you must disconnect the negative cable of the 12-volt battery to prevent accidental power surges.
    • Use Insulated Tools:
      Always use insulated or coated tools when working near high-voltage components to minimize the risk of shock.
    • Be Aware of High Voltage:
      The high-voltage battery contains dangerous levels of electricity, so exercise extreme caution and ensure all power is safely disconnected before proceeding.
    There are You Tube videos on removing the battery, but if you watch some, you will see how to gain access to it and remove the covers required to access the contactors
    T1 Terry
  4. dolj
    dolj Senior Member
    8,343
    4,256
    Wellington, New Zealand
    It could be a thing to do at some point, but right now it is premature and is almost certainly a distraction for the OP for the reasons ChapmanF mentioned in post #40
  5. PriusOwner428
    68
    IL
    Thanks Terry. I will look through this tomorrow morning - long unproductive day today.
    The consensuses right now is that it's not the hybrid battery (or at least it's not the primary culprit). The car will not even go into ACC or IG ON mode. So not even the 12V appliances are working - and yet the 12V battery is definitely OK. The leading theory right now is a mouse ate one of my wires.
  6. PriusOwner428
    68
    IL
    Well it's done & that fuse is definitely OK.
  7. ChapmanF
    17,757
    No. It isn't. When a person takes a wild guess how something might work and then dresses the guess up in tech-speak, that's just the way it comes out. I'm sorry, but c'mon.
    Of the three contactors, SMR1, SMR2, and SMR3, SMR1 controls the precharge resistor. Precharging begins when you hear SMR1 and SMR3 close together. There is no precharging happening before that.
    The precharge resistor is sized so that once SMR1 and SMR3 close, the capacitors in the inverter take only a tiny split-second to charge. The point is to just slightly blunt the otherwise massive current spike that would happen without precharging. The length of that 'delay' is only such that what you hear from the contactors (SMR1&3 closing, SMR2 closing, SMR1 opening) just sounds like a ragged clickety-click instead of one unison click.
    The delay that you notice before any of that happens is the car's ECUs waking up from sleep (if you weren't already IG ON first), running through pre-READY checks, and agreeing that the car is ok to make READY. If it is, then the HV control ECU goes ahead and activates the three contactors, in the above sequence, verifies the right voltage reaching the inverter, and you're in business.
      File size:
      7.1 KB
    #47 ChapmanF, Sep 28, 2025 at 10:44 AM
