2013 Prius Wobbles at certain POWER settings
Discussion in 'Gen 3 Prius Technical Discussion' started by Abraham Vines, Sep 28, 2025 at 10:27 AM.
  1. Abraham Vines
    Abraham Vines Junior Member
    Charlotte
    Hello all!
    I recently just put a new head gasket on my Prius. I replaced the EGR cooler and valve and PCV with all new components. Also cleaned every component that came off while doing it. The vehicle has 260,000 miles on it. It is worth mentioning that I have had all four tires replaced recently with a balance and a recheck of the balance. The symptom of the wobble feels very similar to a tire imbalance, except it doesn’t have anything to do with the vehicle speed, but only specific power settings.
    I have been driving it for 500 miles now but ever since I have changed the gasket I have had a “wobble” at speeds approximately from 30 miles an hour onward ( ONLY when the engine is on ie. not while in EV mode) at approximately 1/4 throttle demand and a little over half throttle demand Regardless, if the vehicle is accelerating or decelerating ( at those power settings). It does happen at all speeds like I mentioned.
    There is no rattling associated with the wobble. The engine starts and runs great!
    I have my suspicions on what it is, but I want to hear what other opinions are.
    thanks in advance!
    AJ
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    770
    303
    Maine
    got me, I do not have a clue.
  3. bisco
    51,533
    sometimes tyres are defective
  4. Abraham Vines
    Charlotte
    I changed the front tires with a pair from my parents Prius with no improvement
  5. bisco
    51,533
    switch them to the back
