2013 Prius Wobbles at certain POWER settings
Discussion in 'Gen 3 Prius Technical Discussion' started by Abraham Vines, Sep 28, 2025.
  1. Abraham Vines
    Abraham Vines Junior Member
    Charlotte
    Hello all!
    I recently just put a new head gasket on my Prius. I replaced the EGR cooler and valve and PCV with all new components. Also cleaned every component that came off while doing it. The vehicle has 260,000 miles on it. It is worth mentioning that I have had all four tires replaced recently with a balance and a recheck of the balance. The symptom of the wobble feels very similar to a tire imbalance, except it doesn’t have anything to do with the vehicle speed, but only specific power settings.
    I have been driving it for 500 miles now but ever since I have changed the gasket I have had a “wobble” at speeds approximately from 30 miles an hour onward ( ONLY when the engine is on ie. not while in EV mode) at approximately 1/4 throttle demand and a little over half throttle demand Regardless, if the vehicle is accelerating or decelerating ( at those power settings). It does happen at all speeds like I mentioned.
    There is no rattling associated with the wobble. The engine starts and runs great!
    I have my suspicions on what it is, but I want to hear what other opinions are.
    thanks in advance!
    AJ
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    got me, I do not have a clue.
    52,737
    sometimes tyres are defective
  4. Abraham Vines
    Charlotte
    I changed the front tires with a pair from my parents Prius with no improvement
  5. bisco
    52,737
    switch them to the back
  6. Abraham Vines
    Charlotte
    Did that with same symptoms
  7. Abraham Vines
    Charlotte
    UPDATE:
    in an effort to diagnose what this wobble is, I started with the low hanging fruit. Since I changed the EGR cooler and EGR valve to brand new units, I decided to eliminate those out of the equation by unplugging it. Lo AND BEHOLD, IT WORKED! Of course, the car instantly gave me a check engine light.
    Now there is no wobble from any power setting. Again, there was no knocking or pinging or any type of poor engine running indication, other than it felt like the tires were unbalanced.
    I will contact the Toyota that I got these new parts from and talk to them about it.
    Brian1954 likes this.
  8. bisco
    52,737
    could a bad bearing make it wobble?
  9. bisco
    52,737
    isn't there a balance wheel on the front of the crankshaft that looks like a pulley?
    harmonizer or some such
  10. ChapmanF
    18,917
    What is the misfire margin shown on a scan tool at times when the 'wobbling' is occurring?
  11. Abraham Vines
    Charlotte
    I didn’t even know that that could be measured! When I have access to such a tool, I will figure out what it is. Did you read my post about the EGR update?
  12. Abraham Vines
    Charlotte
    Also, For those researching this problem in the future. I have come to understand that if you put a new EGR valve in, you must relearn the ECU by doing a EGR adaptation in order to calibrate All the necessary equipment. I am 98% sure that this is going to fix my issue. I will follow up after this weekend when I have access to the proper scan tool.
  13. ChapmanF
    18,917
    I'm not aware of such a procedure. Can you indicate where you learned of it?
  14. ASRDogman
    ASRDogman Senior Member
    8,004
    4,064
    If you put the updated egr valve in, and you had the older one, then you have to do the
    software update for the new valve.
    If you already had the newer valve, AND the software update, you only need to change the valve,
    there will not be anything to "relearn". And what other equipment are you referring too?
  15. ChapmanF
    18,917
    Even the software update dogman mentions is one that is mentioned in at least two different service bulletins, one having nothing to do with a new EGR valve, and one having nothing to do with a new intake manifold. The updated EGR valve is a little bigger physically—the service bulletin explains how to untape and rearrange the wiring harness a little to reach the connector—but is still a simple six-terminal stepper motor and doesn't respond differently to the ECM's output pulses than the old one.
    I've had the firmware update done (even without an updated valve or manifold) and the only engine behavior change (that I notice, anyway) is a slightly higher idle RPM below 35℃ coolant temperature. That's an old-school remedy for rough running after start (we used to do it with our right feet on the go pedal until the engine had warmed up some) and, as both service bulletins that mention it have to do with cold-start rough running, I expect that's why they mention the update.
    That update is chronologically later than the one that fixed the backfire-blowing-hoses-off bug, so I assume that fix is also in it, and I also hope (but don't know for sure) that it includes the water pump control improvement they announced (only in Europe) for head gasket longevity. Those were big reasons I asked for the update.
  16. Abraham Vines
    Charlotte
    OK guys, I’m sorry that it has taken me so long to get back with everyone! Everyone who said that you don’t need to re-learn the EGR is correct. That was not an option. The long of the short of the story , I took it to Toyota and they could not find anything wrong with it. Even after describing in detail and test riding with the mechanic.
    after getting it back home and doing an oil change, I decided to get down into it. I took the intake off and cleaned out the EGR ports on the intake. They were very gunked up. After mounting everything back and test driving it, the issue has gone away. it was just the EGR ports on the intake.
    Brian1954 and frodoz737 like this.
  17. Brian1954
    Brian1954 Senior Member
    2,632
    1,040
    South Central PA, USA
    Did you clean the EGR ports on the intake manifold when you had it off? If so, how did you clean the ports? What did you do differently the second time you cleaned the intake manifold EGR ports?
  18. ChapmanF
    18,917
    Ah, yes, that's a classic cause of some misfiring noticed only at mid-loads.
    EGR isn't used (the valve is closed) at low loads/idle, and at high loads/open-throttle.
    The valve opens and some EGR is used at mid-loads between those extremes. So then if those intake passages are variously gunked up, there's different amounts of EGR getting to the four cylinders, with resulting misfiring / unbalanced running.
    Abraham Vines likes this.
  19. ASRDogman
    8,004
    4,064
    Glad you resolved the issue. It's always best to do the easy things first....
  20. Abraham Vines
    Charlotte
    I did clean the EGR ports on the intake manifold when I had it off the second time. The first time I honestly didn’t know that those did anything lol. I cleaned the rest of the intake, but I did not clean those ports the first time. I used brake cleaner and a small wire brush that would fit on my drill to get into each individual port.
