Rear trunk release button mod from inside.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Kaptainkid1, Jun 16, 2021.
  1. Stormy Steve
    Stormy Steve Junior Member
    Rockmart ga
    I'm learning how to use this site.
    I just realized you've tapes into the switch loop/in residential talk/ I've got to try this!!!!!!!!! If it works.My idea is to install a keyed lock/switch so I can open from outside.
    If this works/I want to have a keyed switch operate from the outside!
  2. teranaught
    teranaught Junior Member
    bremerton
    I did it too, but I put in 2 switches, and a string on the latch.
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,721
    402
    2013 Prius Plug-in
    If the rear hatch can be triggered with only 9v, I might have a way that you can trigger the rear hatch to open when the battery is dead using a 9v battery. where you put the battery connector is up to you.
  4. James Analytic
    321
    49
    Michigan
    Got me thinking. Man, might be a cool magnetic reed emergency switch for the lazy. Add like a 9V rechargeable battery with a charger to trickle charge and like with a magnetic reed switch to use in an emergency.
  5. bisco
    51,533
    great idea, and simple and easy to implement!
