Laminated Glass In Side Windows?
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Sep 30, 2025.
  1. VelvetFoot
    VelvetFoot Active Member
    613
    213
    New York State
    2026 Prius
    Waiting on an '26 DL, so I can't look at the glass cross section.
    It doesn't look too good for escaping if the side windows are laminated.
    Of course the windshield is laminated, but how about the hatch?
    The manual has the ever-popular "if equipped" footnote.
    What's the latest scoop?
  2. KMO
    KMO Senior Member
    1,954
    682
    Finland
    2023 Prius Prime
    The LE isn't fancy enough to have the laminated front side windows.
    From this thread, it seems that of the USA trims, only the Limited and XSE+ have them.
    Rear door windows and hatch glass aren't laminated.
    VelvetFoot likes this.
  3. VelvetFoot
    613
    213
    New York State
    2026 Prius
    Thanks. In any event, it would probably be good to verify on the actual car.
  4. VelvetFoot
    613
    213
    New York State
    2026 Prius
    I hadn't known this. The car manual turned me on to this, so it is indeed good for something!
  5. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    You won't break hardened glass unless your glass breaker is harder than the glass. It will just make a tiny divot in the glass instead. That's why those videos of cops trying to break car windows with nightsticks are so comical. Punks use a broken spark plug to shatter the glass when they break in.
  6. VelvetFoot
    613
    213
    New York State
    2026 Prius
    hardened=tempered, I believe, and that shatters. Laminated doesn't.
  7. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Tempering is the opposite of hardening. Heat-treating makes it brittle, and tempering makes it less brittle.
  8. ChapmanF
    18,138
    Some regional difference in usage, maybe?
    Where I am in the US, the two types of glass for automotive use have been known by the terms 'laminated' and 'tempered' ever since my childhood (and presumably before). 'Tempered' can also be seen in post #1 to be the term used by Toyota.
    What’s the Difference Between Laminated and Tempered Glass?
    #8 ChapmanF, Sep 30, 2025
  9. VelvetFoot
    613
    213
    New York State
    2026 Prius
    I just went to the garage and looked at my MINI glass.
    The front and rear side windows don't appear to be laminated by looking at the cross section.
    The markings of AS2, see below, would also indicate tempered, and not laminated.
    The rear hatch is also marked AS2.
    I could find no markings on the panoramic sunroof. They could be there, I just couldn't find them
  10. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Tempered glass is harder than raw glass, but it got that way from being tempered down from hardened glass. I'm not sure how this relates to laminated glass.
  11. ChapmanF
    18,138
    I suppose I was curious how 'hardened' got into the conversation, given that laminated and tempered are the two types used for auto glass, and the two types mentioned in the OP.
  12. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    The point was to correct the false statement that "tempered = hardened" glass.
  13. ChapmanF
    18,138
    The unexplained entrance of 'hardened' into the conversation, though, came in post #5, one post earlier than that "false statement".
    Trollbait likes this.
  14. Trollbait
    12,517
    The only google hits I get for harden glass involve Minecraft.
    Or they redirect to tempered glass, like Tempered glass - Wikipedia
  15. ChapmanF
    18,138
  16. VelvetFoot
    613
    213
    New York State
    2026 Prius
    What seems to be the case is that Toyota is reserving laminated glass for the high end models.
    And, while it may serve to help keep miscreants out, it also serves to prevent people from easily breaking a window to escape.
    Even a Good Samaritan, not a well prepared fire or police person, would have difficulty breaking through.
    I'm not sure I'm qualified to read into Toyota's motives, lol.
  17. Hammersmith
    Hammersmith Senior Member
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is one of the stranger tangents I've seen around here lately, but it seems like Paul is confusing hardening and tempering metals to tempering glass. Same word, different specific meanings depending on the industry.
    In metals, tempering removes much of the brittleness from the hardening process in exchange for losing a small amount of hardness. (just like Paul said)
    In glass, the tempering process puts one side of the glass in compression and the other in tension. The process makes it about four times stronger. It also mean that, when shattered, it breaks into the small fragments without overly sharp edges.
    Also in glass, I'm not seeing hardened glass as a commonly used term. It tends to be called tempered glass in the US and toughened glass in the UK. Not sure where Canada falls - sometimes they follow UK terminology and sometimes US.
    As for VelvetFoot's last post, the reason Toyota is using laminated glass in the front side windows instead of tempered in the top-trim Prius is for noise reduction. Pretty much all of the higher end brands use it(unless it's a race version of a car that uses tempered because it's lighter). I think one of the very top brands(Rolls, Bentley or Maybach) even used triple layer laminate at one time(3 layers glass, 2 layers plastic). Some countries mandate at least one window must be tempered for ease of escape in an emergency. Nearly certain the US is not one of those countries.
    If safety is a primary concern and you have laminated, just get one of the hammer-style car escape tools instead of the little ones. The hammer tip will still pop the glass like tempered, then you can use the head of the hammer to punch through the lamination and then work it in a circle around the outside edge of the window to clear it. Takes maybe 3 or 4 seconds more than tempered. The nice thing is that this style also works on windshields, which are all laminated glass by law.
    This is just an example of the type:
    Ready America Auto Emergency Hammer and Seat Belt Cutter 75403 - The Home Depot
    Winston Smith and VelvetFoot like this.
  18. VelvetFoot
    613
    213
    New York State
    2026 Prius
    Or this.
    Thing is, if a driver or passenger is trying to get out, there are positional limitations and possibly physical limitations imposed by the accident.
    Also, reading a response from Ready America on that product:
  19. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    #19 Paul Gregory, Sep 30, 2025
  20. ChapmanF
    18,138
    Hammersmith in the first paragraph of #17 may have guessed right.
