1. TwoPriusInTenn
    248
    65
    Tennessee
    I replaced the HV ECU in my daughter's 2008. We have done the 4 and 13 jumper wire trick, but still the engine will not start. Next step suggestions welcomed.
  2. Tombukt2
    12,698
    2,269
    spins but no start? Is it sposed to be starting running?
  3. Brian1954
    Brian1954 Senior Member
    2,017
    790
    South Central PA, USA
    Is this the same car that you created a thread about on September 6th?
    https://priuschat.com/index.php?posts/3563003
    #3 Brian1954, Oct 2, 2025 at 9:14 AM
  4. TwoPriusInTenn
    248
    65
    Tennessee
  5. saneesh8
    saneesh8 Member
    165
    Allen, TX
    TwoPriusInTenn likes this.
  6. TwoPriusInTenn
    248
    65
    Tennessee
    Thank you.
  7. TwoPriusInTenn
    248
    65
    Tennessee
    I have done a paperclip in pins 4 and 13 again. Dashlights flicker. Did this procedure for 30+ minutes and turned it off. Took out jumper and key. Waited 5 minutes. Inserted key and pushed start button. Lights are solid. Triangle is still there. No start.
    I did not replace the Engine ECU, just the HV ECV and converter/inverter.
    Should I call a locksmith and have the fob reprogrammed?
    #7 TwoPriusInTenn, Oct 4, 2025 at 12:32 PM
  8. TwoPriusInTenn
    248
    65
    Tennessee
    UPDATE: Current status- With car in ready. The engine fired with jumper in pins 4 and 13 and key fob in. Will not start without jumper. I will try a couple more times.
  9. TwoPriusInTenn
    248
    65
    Tennessee
    It's running!!! After about 4 tries. The fob is sync'd.
    Now it is displaying the following codes:
    C1310
    POA08-264
    POA08-591
    PXL_20251004_203733114.jpg PXL_20251004_191325920.MP.jpg PXL_20251004_191228904.MP.jpg
  10. ChapmanF
    17,806
    Yay progress!
    Search around for threads about your P0A08 and P0A09 codes. They pertain to a simple signaling circuit between the HV control ECU and the DC/DC converter, and there's information in other threads about troubleshooting that.
  11. TwoPriusInTenn
    248
    65
    Tennessee
    All solved! Final fix on the P0A08 and P0A09 codes. The 5 amp fuse located in the positive battery cable tested good, but wasn't long enough to make a good connection. All good - no triangle. No codes! Thank you everyone!
