Oil Change: Threaded Funnel, Jacking, Oil Use
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by VelvetFoot, Oct 6, 2025 at 9:35 AM.
  1. VelvetFoot
    VelvetFoot Member
    178
    43
    New York State
    2026 Prius
    So, while I'm impatiently waiting for my car to arrive, I watched a nice video by Viktor G Automotive that shows a threaded funnel. That's the first time I saw something like that! I think it's a great idea.
    He also touched on jacking a little and showed the front and side lift points. He felt the front was too recessed to easily lift it with a jack. (Of course, he has a lift, lol.). He prefers the reinforced pinch weld side locations (again, lift). Still looking for a low profile insert for a floor jack to mate to it.
    I also liked the tip about putting a little oil on the dipstick O-ring so it wouldn't stick.
    On a personal note, I like the exposed look of the engine compartment. You can see everything, versus my current MINI, which is totally ensconced in plastic. As I said before, it doesn't even have a dip stick, just a warning that comes on if the oil is low.
    Do the Gen 5 Prius engines typically use oil between 10,000 mile oil changes?
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,409
    2,386
    Taylors, SC
    I use a piece oi appropriately 6x9 inch frozen food package cardboard rolled into a funnel. It fits tightly and stays tight in the oil fill hole.
    It's basically free and totally disposable with no mess.
    For jacking, I use this custom pinch weld adapter.
    10,000 miles is too long.
    3,000 to 5,000 max.
    VelvetFoot likes this.
  3. VelvetFoot
    VelvetFoot Member
    178
    43
    New York State
    2026 Prius
    Nice! Nylon?
  4. Georgina Rudkus
    3,409
    2,386
    Taylors, SC
    Better than nylon. Ultra durable UHMW Spectra. Hard to cut with the pinch weld "knife edge" even with the car's weight landing on it.
  5. VelvetFoot
    VelvetFoot Member
    178
    43
    New York State
    2026 Prius
    Thanks. I'll be shopping around.
  6. Mendel Leisk
    41,022
    Here's an interesting funnel idea, fashioned from an empty oil quart bottle, with offset neck. Maybe requires particular thread style:
    (video starts at appropriate point)
    Still think you should persevere with making the front/rear jacking points work; rolling the front onto low-rise ramps as needed for initial clearance. I do that often, gets easy. The only car I raise from the side is a Tesla 3, 'cus Elon didn't think it needed front/rear jack points.
    xliderider likes this.
  7. xliderider
    xliderider Senior Member
    8,136
    3,274
    Honolulu, HI
    I used a screw in funnel for an oil change for the first time recently, it really is a great tool. Previously, I used a regular funnel, but it didn't go in very far due to all of the valve train parts under the fill hole, so the funnel tended to fall over to one side.
  8. VelvetFoot
    VelvetFoot Member
    178
    43
    New York State
    2026 Prius
    It's not like I don't have a bunch of funnels already, lol.
    For oil change, I'd use ramps. Tire rotations, side.
  9. BiomedO1
    3,183
    1,690
    SacTown, Ca
    Cut the bottom off a 2 quart plastic milk carton or a gallon milk carton it you have really bad aim.:D If you cut it just below the handle, you'll have a nice funnel handle too boot. Nice wide opening that won't bottom out onto your valve train and fill faster than a funnel.
    If you save the lid; it's a lot cleaner than a regular funnel, since you can cap-off one end and shove old rags in the other; for the next oil change.
    #9 BiomedO1, Oct 7, 2025 at 5:35 AM
    Trollbait likes this.
  10. Mendel Leisk
    41,022
