Engine shakes heavily during shut down
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A.J, Sep 21, 2025.
  1. A.J
    A.J Junior Member
    59
    Worldwide
    When i start my 136k miles 2010 Prius, it starts fine but i can hear a continuous low volume knocking.
    After working for about 20minutes switching between Hybrid and Combustion Engine a couple of times, it switches to combustion, increases the rpm and doesn't switch back to Hybrid.
    Coolant temperature would increase to 90-95 degree celsius and i see it boiling in the coolant tank.
    When i off the car, the combustion engine shakes heavily.
    Cylinder 3 and 4 misfire code come up sometimes.
    CONS:
    Car at 136000miles, Head gasket not yet changed.
    Changed EGR valve
    Changed Fuel injectors
    Cleaned egr cooler and intake manifold.
    PROS:
    I am not losing coolant.
    Checked cylinder valve via Borescope camera through spark plug hole and can see exhaust valves with heavy brownish build up.
    Engine cylinders has some burn/rust looking surface and like an oil in Cylinder 4. (see attached pictures)
    I want to know if this issue can be caused by a failed head gasket and if the cylinder build up is from same or something else.
  2. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    Check your coolant pump. Perhaps it has failed....
    Brian1954 likes this.
  3. A.J
    A.J Junior Member
    59
    Worldwide
    Shutdown Shake Video for context, just incase:
  4. michaud85
    michaud85 Member
    61
    47
    Salem
    If Your head gasket failed, bubbles in the coolant are from exhaust gasses in the coolant system.
    Borescope down the spark plug holes look at the tops of the cylinders. You might see a clean top on one which is a clear indication of a failed head gasket, maybe not since you are not losing coolant.
  5. A.J
    A.J Junior Member
    59
    Worldwide
    I also realize i do get p3020 error when this happen. Can a battery block 10 error cause such issue.
    I mean it seem this doesn't allow me accelerate properly after that error comes up, even after i clear it with Dr. Prius unless i shuts off and on.
  6. ASRDogman
    7,758
    3,967
    IF you get bubble in the coolant tank, the engine in ruined. It rarely gets that far with the Prius.
    Loosing coolant, knocking, missfire codes, are huge warning signs of a failed head gasket.
  7. A.J
    A.J Junior Member
    59
    Worldwide
    Thing is, i am not losing coolant, i can open coolant tank when engine is working. I So i am thinking perhaps the battery issue makes the engine keep working when it should have switched back to hybrid or something.
  8. ASRDogman
    7,758
    3,967
    Didn't you say the coolant light was coming on because the engine is overheating?
  9. A.J
    A.J Junior Member
    59
    Worldwide
    No, I monitored via Carista app and it's <95 degree celsius, never gets to 100 which is when the symbol do show in dashboard. So i am trying to change the block 10 battery, in other to check if that might be the issue.
    ASRDogman likes this.
  10. A.J
    A.J Junior Member
    59
    Worldwide
    Apparently, me clearing the error p3020 and continue driving without fixing the issue with the battery caused my engine to shake. Switching off the car and turning it back on without clearing the error makes the car work only on combustion engine and doesn’t shake when shutting down. It works normal.
    I will attend to the p3020 error later though because my MPG will suffer.
  11. Mendel Leisk
    41,822
    Continue to check the level frequently.
  12. DirkAshburn
    DirkAshburn Member
    158
    65
    Virginia
    On one of the Prius battery replacement video's out there it was noted that when they replaced the hybrid battery the engine shaking completely stopped. Could be related.
    A.J and Mendel Leisk like this.
  13. A.J
    A.J Junior Member
    59
    Worldwide
    Apparently, one of my HV battery ECU harness connector port was corroded. Had to raise the white clip up to check the port out, cleaned the corrosion and renewed the specific wire teeth.
    Also switched my Block 10 batteries to Block 1 and 2 respectively in other to track the specific battery with issues just incase.
    No more error after that.
    #13 A.J, Oct 11, 2025
  14. Mendel Leisk
    41,822
    Where in “worldwide” are you? Just curious if kicked up dust from road salt might be a factor in the pin corrosion.
  15. Brian1954
    Brian1954 Senior Member
    2,368
    953
    South Central PA, USA
    It is very difficult to clean all the corrosion off of the wire harness and battery smart unit connector. You may need to replace those parts so that the problem does not come back. Also, check for any moisture in the rear of the car and fix the leakage. This is a very common problem on a Gen 2 Prius but not as common on a Gen 3.
  16. A.J
    A.J Junior Member
    59
    Worldwide
    Haha, my car is actually Canadian, so that can be a thing.
  17. A.J
    A.J Junior Member
    59
    Worldwide
    I will be keeping watch. And yes i forgot to add, i did opened the ECU itself and cleaned it.
  18. Mendel Leisk
    41,822
    Lots of road salt then?
