Airlift for Inverter and Engine Coolant
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by ZachAZ, Oct 7, 2025.
Tags:
  1. ZachAZ
    ZachAZ New Member
    Tucson, AZ
    I couldn't find anything on here about using an airlift to fill your engine and inverter coolant on a 4th gen. I replaced my engine and inverter coolant last night and i used an airlift on both. It worked great. I had to add a little bit of coolant to the inverter when I turned on the pump with the Techstream, but it was mostly full. I also had to add a little to the engine, but again, just a small amount to top it off after running the engine in maintenance mode. 2017 Prime, in case you were wondering.
    Georgina Rudkus and bisco like this.
    51,899
    thanks, great info!
  3. mke039
    mke039 Junior Member
    Massachusetts
    Just bought an Airlift and did the same. Exceptional results.
    But did not solve the problem. I changed the thermostat as I get no heat from the ICE. Changed the coolant as well.
    Still no heat. I will throw a water pump at the problem next.
    Georgina Rudkus likes this.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,463
    2,424
    Taylors, SC
    Sure beats the time consuming and tedious Toyota specified revenue generating method that the stealerships use.
  5. Mendel Leisk
    41,413
    I did coolant changes on both circuits this fall, third gen but I believe similar, just following the Repair Manual procedure. With the engine, you refill to B line on reservoir (about an inch above full line), install the cap, run the car in maintenance mode till fully warm. During that time the level in reservoir slowly drops.
    learned a trick:
    I thought it had warmed sufficiently, coolant in reservoir had dropped “some”, so shut it down and crawled under (front was raised and under-panel removed to facilitate the inverter coolant drain), to reinstall the under-panel.
    I felt the large radiator hoses and discovered they were still stone-cold. I started it back up in maintenance mode, crawled back under, just lay there, occasionally checking those hoses. Eventually, presumably with thermostat opening, they went from cold to toasty. Done. :)
