Lexus GS450H
Discussion in 'Newbie Forum' started by PeteGS450H, Oct 7, 2025 at 8:44 PM.
  1. PeteGS450H
    PeteGS450H New Member
    Tuesday
    Daly City CA
    My 2007 GS450H is similar to a Prius except it has 40 battery blades whereas a Prius has 28.
    I have just installed 40 new blades in my GS450H. Pack looks good according to diagnostic (photo) but getting error code P0A0D. Safety plug was correctly installed but there is almost no voltage at the port.
    I have discovered there is almost no voltage at the battery terminals the safety port is attached to (photo). When I test these terminals independently they show 150V and 165V respectively. What could be wrong?
    Thanks
    51,590
    is the fuse inside the plug okay?
  3. Brian1954
    Brian1954 Senior Member
    2,024
    791
    South Central PA, USA
    There is nothing wrong with the hybrid battery. You are only seeing 2.4v on the meter because of where the positive and negative probes of the meter are connected to. Think about what you are measuring across those two terminals.
    #3 Brian1954, Oct 8, 2025 at 6:01 PM
