Car Scanner Pro app for Diagnostics
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A.J, Oct 10, 2025 at 4:00 AM.
  1. A.J
    A.J Junior Member
    Worldwide
    I see only few people talk about Car Scanner Pro app on here for Gen 2, so i am opening this thread to show how cool this app is for Gen 3 too.
    I got it yesterday and so far, it's amazing. If you have an experience with it, you can also share.
    PROS:
    -It has alot of sensor reading for Prius
    -Customisable Dashboard
    -Custom Action PID
    -Coding
    CONS: Electric Pump RPM reading isn't functional for me at time of writing.
    I can display upto 30 sensors and action on the app dashboard, which includes Engine, Battery, Distance since codes clear, warms up e.t.c
    Also create a custom action to clear DTC on the go without leaving the Dashboard screen. (04 is the custom command for ELM327 DTC code clearing)
    My current Dashboard look:
  2. rjparker
    9,916
    6,116
    Car Scanner coolant temp diagnostic aids
    Stuck Exhaust heat Recirc valve coolant temperature sensor in red
    Good exhaust recirc valve
    xliderider and Brian1954 like this.
  3. VelvetFoot
    VelvetFoot Member
    217
    New York State
    2026 Prius
    Text output works on CarPlay.
  4. Brian1954
    Brian1954 Senior Member
    2,029
    793
    South Central PA, USA
    CONS: It is not capable of communicating with all the ECUs in a Gen 3 Prius, but it comes very close. You just need to know its limitations. https://priuschat.com/index.php?posts/3564647
    It is a very nice app for most people to use. It is better than 95% of the scanner apps that are available. I like it very much.
  5. VelvetFoot
    VelvetFoot Member
    217
    New York State
    2026 Prius
    I'm curious how it compares with OBD Fusion, which also communicates to CarPlay?
  6. Brian1954
    2,029
    793
    I do not use the OBD Fusion app. Maybe someone else can answer your question.
    VelvetFoot likes this.
