how to disable the DCM/Telematics unit in the car
Discussion in 'Gen 5 Prius Technical Discussion' started by RandyPete, Mar 31, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    My two cents: I think it would be a bad idea, firstly because we need updates to the systems that are still a bit buggy. Secondly, if you pay good money for something, you should use it.
  2. soft_r
    soft_r Active Member
    183
    151
    Beverly Hills
    2024 Prius
    Does Toyota even deploy critical updates OTA? Is the DCM involved in that? As always if there is an update it can be done at the dealership via OBD2. Also the idea of silent OTA updates being applied is not a positive like you think it is. Changes can be made to my car by someone at Toyota without my knowledge or consent, and this is a good thing?
    "Secondly, if you pay good money for something, you should use it."
    And that's why in one of my earliest posts I mentioned, if you're not using any of the remote connect services (ie. you're not paying for any of them) then there's no need to have the DCM running.
    Anyway, autoharness house has rigged up some dongles to plug into the harness going into the DCM meaning you retain microphone and the one speaker that the DCM intercepts stays on while the unit has been unplugged. Toyota DCM/Safety Connect Bypass Harness - Fits 2020+ Toyota Vehicles
    VelvetFoot and kenmce like this.
  3. Dale Coba
    Dale Coba New Member
    2024 Prius Prime
    SE
    I found autoharnesshouse through a GR86/BRZ forum last week. Many GR86/BRZ owners are into modifying their cars and far more are interested in keeping their driving data to themselves.
    Emailed autoharnesshouse and got a prompt reply with the same link soft_r just posted. Arrives Thursday.
    Next challenge will be getting to and pulling the DCM connectors to install the bypass harness. As long as the DCM is fully unplugged, might as well leave it in case there's some future use. Thank you to cool_prius for the diagrams showing the relative location and R&R instructions.
    Does anyone have any actual experience they can share on getting to the DCM connectors *without* first removing the DCM?
  4. Blackat
    Blackat Active Member
    467
    326
    Colorado
    2023 Prius
    Limited AWD-e
    I wouldn't mind disabling but I just don't have it in me to go thru all that's necessary
  5. soft_r
    183
    151
    Beverly Hills
    2024 Prius
    Do take pictures of the actual disassembly and post if you don't mind.
  6. kenmce
    kenmce High Voltage Member
    1,546
    515
    NY
    I'll just drop this off here...
    Suit says that Toyota sold drivers data without permission
    soft_r likes this.
  7. vvillovv
    vvillovv Senior Member
    4,322
    1,511
    NY
    I'll acknowledge you here this time -
    - and kindly add you to my IGNORE list, again, with a, BIG thanks for all your wonderful contributions regarding my posts of late ! Guessing probably politically motivated at there core? DDS - TDS :ROFLMAO:
    congratulations !
  8. Mendel Leisk
    41,662
    Not sure how I’ve crossed you, but sorry. The “ignore” person I was referring to was soft_r.
  9. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    The allegation seems to be that a salesman at the dealership signed the owner up for Toyota's optional and opt-in insurance program without the owner's approval. The program does not turn on by default, it has to be intentionally activated.
    While the actions of that rogue car salesman were not good, it does not begin to compare to what GM was doing -- selling detailed driver location and behavior data of all their customers without approval or consent. https://www.reuters.com/business/autos-transportation/ftc-bans-gm-disclosing-driver-consumer-data-consumer-reporting-agencies-2025-01-16/
  10. VelvetFoot
    VelvetFoot Active Member
    875
    312
    New York State
    2026 Prius
    Old topic but interesting nonetheless. I'm hoping to get a new Prius in the near future.
    On the MINI forums, nobody is interested in this.
    I couldn't believe there was a cellular chip in my car when I bought it...unreal, I thought.
    I suppose the BMW forums would have been a resource.
    Too bad it can't be disabled through the OBDC port...or can it?
    Maybe there's some region where Toyota sells its products that doesn't allow this data gathering.
  11. VelvetFoot
    875
    312
    New York State
    2026 Prius
    Started reading the manual.
    The section on Vehicle Data Recording on page 7, is quite scary from a privacy point of view.
  12. soft_r
    183
    151
    Beverly Hills
    2024 Prius
    VelvetFoot likes this.
  13. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    Isolationist.
  14. VelvetFoot
    875
    312
    New York State
    2026 Prius
    I got the car.
    Pressed the SOS button.
    Lady on the line 'waived' connections.
    Light on SOS button subsequently went off, and pushing the button does nothing.
    Nothing else Toyota Connect works.
    Still, makes you wonder how it 'automatically' gets the time, lol.
    I have the dongle, but I'm torn.
    It only has 200 miles on it, and to start taking it apart already...
    I haven't even touched the noisemaker.
  15. networkingdude
    networkingdude New Member
    Nova Scotia
    2024 Prius Prime
    XSE
    It gets the time from a gps module and not over the cell network.
  16. VelvetFoot
    875
    312
    New York State
    2026 Prius
    GPS is in the head unit?
    Could also use satellite radio.
    I wonder if HD FM radio can provide time?
  17. PriusAwd101!
    PriusAwd101! New Member
    East Coast
    2025 Prius
    I've gone to the trouble of registering on this forum for this simple reason that my city commuter vehicle is pretty much done after 350k.
    So then, a guy at work in the security field clued me in on the new cars, whether FordSync or anything else ( he's disabled everything in his truck ) He says they all have this insecure crap on it that I don't want.
    Its simple, from our phones to our PC's, many thousands have done and are doing what others have done on this forum, we are leaving the system that makes money off of us by selling our data.
    I'm glad this thread exists. Soft_r, my thanks to you -
    And to the folks at Toyota that peruse this forum, this person just sold a Prius, but it's going to have all your crap utterly and permanently disabled.
    My hope is that eventually US privacy laws will catch up to and exceed European standards.
    soft_r and others, don't let the sb's get you down, they'll catch up eventually, they know not what they do.
  18. Dany Dan
    Dany Dan Junior Member
    Québec, Canada
    2024 Prius Prime
    SE
    To deactivate the Prius tracking, modify the Toyota server URL in the hidden menu of infotainment.
    Do not forget to note the URL in case you want to reactivate it.
    See the 3 photos and the URL is surrounded in red.
    To access the hidden menu, here are the instructions: (YouTube has videos that show the procedure)
    1. Ensure that the vehicle is stopped.
    2. Turn the ignition switch to ON.
    3. Turn off the audio of the radio and display receiver assembly.
    4. Turn off the screen from the settings screen.
    5. Perform the "Flick from left to right" operation five times on the multi-display shown in the figure. [Figure just shows a long swipe]
      1. Tip: Performing flick operations may cause messages, etc. to appear on the screen, but disregard these and continue performing the flick operations.
    6. Flick the multi-display 5 times from right to left as shown in the illustration.
      1. Tip: Make sure to complete the operation within 15 seconds of performing the initial flick from left to right.
    7. When diagnosis starts, the service menu screen is displayed.
    Tip: If diagnosis does not start due to a failed operation, turn the display on then off and perform the procedure from the start.
    (Only turning the audio of the radio and display receiver assembly from off to on is not a valid method)
      File size:
      85.2 KB
      File size:
      73 KB
      File size:
      53.9 KB
  19. VelvetFoot
    875
    312
    New York State
    2026 Prius
    Does this actually work with the Gen 5? Have you actually tried it? I haven't seen any mention of it, on this forum anyway.
  20. shouser
    shouser Junior Member
    Southern Maine
    The 10 flicks worked to display the service menu on my 2026 Prius.
    And in case someone from Toyota is reading. I did not change any settings nor navigate to anything that would void my warranty. I immediately exited the service mode I accidentally found myself in while reading Internet comments :)
