how to disable the DCM/Telematics unit in the car
Discussion in 'Gen 5 Prius Technical Discussion' started by RandyPete, Mar 31, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,154
    564
    Alberta
    2024 Prius Prime
    XSE
    My two cents: I think it would be a bad idea, firstly because we need updates to the systems that are still a bit buggy. Secondly, if you pay good money for something, you should use it.
  2. soft_r
    soft_r Active Member
    180
    145
    Beverly Hills
    2024 Prius
    Does Toyota even deploy critical updates OTA? Is the DCM involved in that? As always if there is an update it can be done at the dealership via OBD2. Also the idea of silent OTA updates being applied is not a positive like you think it is. Changes can be made to my car by someone at Toyota without my knowledge or consent, and this is a good thing?
    "Secondly, if you pay good money for something, you should use it."
    And that's why in one of my earliest posts I mentioned, if you're not using any of the remote connect services (ie. you're not paying for any of them) then there's no need to have the DCM running.
    Anyway, autoharness house has rigged up some dongles to plug into the harness going into the DCM meaning you retain microphone and the one speaker that the DCM intercepts stays on while the unit has been unplugged. Toyota DCM/Safety Connect Bypass Harness - Fits 2020+ Toyota Vehicles
    VelvetFoot and kenmce like this.
  3. Dale Coba
    Dale Coba New Member
    2024 Prius Prime
    SE
    I found autoharnesshouse through a GR86/BRZ forum last week. Many GR86/BRZ owners are into modifying their cars and far more are interested in keeping their driving data to themselves.
    Emailed autoharnesshouse and got a prompt reply with the same link soft_r just posted. Arrives Thursday.
    Next challenge will be getting to and pulling the DCM connectors to install the bypass harness. As long as the DCM is fully unplugged, might as well leave it in case there's some future use. Thank you to cool_prius for the diagrams showing the relative location and R&R instructions.
    Does anyone have any actual experience they can share on getting to the DCM connectors *without* first removing the DCM?
  4. Blackat
    Blackat Active Member
    459
    319
    Colorado
    2023 Prius
    Limited AWD-e
    I wouldn't mind disabling but I just don't have it in me to go thru all that's necessary
  5. soft_r
    180
    145
    Beverly Hills
    2024 Prius
    Do take pictures of the actual disassembly and post if you don't mind.
  6. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I'll just drop this off here...
    Suit says that Toyota sold drivers data without permission
    soft_r likes this.
  7. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    I'll acknowledge you here this time -
    - and kindly add you to my IGNORE list, again, with a, BIG thanks for all your wonderful contributions regarding my posts of late ! Guessing probably politically motivated at there core? DDS - TDS :ROFLMAO:
    congratulations !
  8. Mendel Leisk
    41,458
    Not sure how I’ve crossed you, but sorry. The “ignore” person I was referring to was soft_r.
  9. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    The allegation seems to be that a salesman at the dealership signed the owner up for Toyota's optional and opt-in insurance program without the owner's approval. The program does not turn on by default, it has to be intentionally activated.
    While the actions of that rogue car salesman were not good, it does not begin to compare to what GM was doing -- selling detailed driver location and behavior data of all their customers without approval or consent. https://www.reuters.com/business/autos-transportation/ftc-bans-gm-disclosing-driver-consumer-data-consumer-reporting-agencies-2025-01-16/
  10. VelvetFoot
    VelvetFoot Active Member
    684
    248
    New York State
    2026 Prius
    Old topic but interesting nonetheless. I'm hoping to get a new Prius in the near future.
    On the MINI forums, nobody is interested in this.
    I couldn't believe there was a cellular chip in my car when I bought it...unreal, I thought.
    I suppose the BMW forums would have been a resource.
    Too bad it can't be disabled through the OBDC port...or can it?
    Maybe there's some region where Toyota sells its products that doesn't allow this data gathering.
  11. VelvetFoot
    684
    248
    New York State
    2026 Prius
    Started reading the manual.
    The section on Vehicle Data Recording on page 7, is quite scary from a privacy point of view.
  12. soft_r
    180
    145
    Beverly Hills
    2024 Prius
    VelvetFoot likes this.
  13. Paul Gregory
    2,154
    564
    Alberta
    2024 Prius Prime
    XSE
    Isolationist.
  14. VelvetFoot
    684
    248
    New York State
    2026 Prius
    I got the car.
    Pressed the SOS button.
    Lady on the line 'waived' connections.
    Light on SOS button subsequently went off, and pushing the button does nothing.
    Nothing else Toyota Connect works.
    Still, makes you wonder how it 'automatically' gets the time, lol.
    I have the dongle, but I'm torn.
    It only has 200 miles on it, and to start taking it apart already...
    I haven't even touched the noisemaker.
  15. networkingdude
    networkingdude New Member
    Nova Scotia
    2024 Prius Prime
    XSE
    It gets the time from a gps module and not over the cell network.
  16. VelvetFoot
    684
    248
    New York State
    2026 Prius
    GPS is in the head unit?
    Could also use satellite radio.
    I wonder if HD FM radio can provide time?
