Oil Filter Removal Wrench
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dave1UK, Oct 11, 2025.
  1. Dave1UK
    Dave1UK Junior Member
    66
    London, UK
    Active
    So I went ahead to do an oil change yesterday and for the life of me couldn't get the oil filter off. The oil filter wrench spanner top snapped off, also believe I took one of the housings plastic fins as well...
    My mistake for using a cheaper tool, I didn't realise that the internal removal wrench was welded on (visible welds) rather than being one unit like others.
    Also is it just me or does the oil filter housing angle seem a bit "bent" slightly diagonally by default?
    This opened up a whole new research avenue into conversion kit/aluminium housing but I think I'll just stick to the original but with a good quality wrench.
    Any recommendations for a oil filter wrench tool?
    Also what are the chances of loosing 1 fin causing a removal issue be?
  2. Tombukt2
    13,048
    2,339
    I've had to use a pair of slip joint pliers the big kind no like 16 inches long or something on a few that were deformed changed a few this way no issues ever . Never destroyed . You can take the oil filter jig off a Corolla w 2z engine relatively inexpensive. I think it takes 4967 rounds
    Dave1UK likes this.
  3. Mendel Leisk
    41,525
    Honda makes an oil filter socket that’s heavy stamped steel, very durable, and a perfect fit. I’ve had one since the early ‘90’s, used it on Hondas (obviously), my 2010 Prius, and a Mazda as well. Here’s a North American dealership link, Amazon has as well, any Honda dealership parts department, and you can search the part no:
    Genuine Honda Oil Filter Wrench (65mm) - 07AAA-PLCA100
    Presumably the first oil change for you? The last person probably used an impact, torque spec is 18 ft/lb.
    I finally got fed up enough with the permanent housing style, did the conversion. No regrets.
    see my signature for oil change and filter conversion links. (On a phone turn it landscape to see signatures)
  4. AzusaPrius
    AzusaPrius Senior Member
    2,184
    921
  5. CR94
    CR94 Senior Member
    2,696
    1,174
    Northwestern S.C.
    Machined steel filter cap wrenches are available on-line, and much stronger than the cheap stamped-steel and aluminum kinds. Ones that engage the "fins" on the plastic housing are a bad idea, as you proved.
    Dave1UK likes this.
  6. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    They get screwed because certain people over tighten them.
    They don't need to be super tight. I use a 6 inch ratchet to snug it once it stops.
    Just enough to almost engage the little clip on the side fin.
    Using quality tools is always the BEST thing to do.
  7. Dave1UK
    66
    London, UK
    Active
    My second oil change, I didn't overtighten the filter to my knowledge but the removal tool had always been a "weird" fit? Either my fault or cheap tool fault will be able to tell once I get a good quality one!
    Is that oil filter socket you linked compatible as it doesn't have those groves for the fins to "engage"?
    Unfortunately based in the UK and can't seem to find it available here without paying quite a bit to have it shipped over (if they even would).
    So the ones that just fit over the top without fin engagement are fine to use?
    Indeed should of learned this lesson long ago, but having only dealt with spin-on filter types before owning this Prius never thought a "generic" tool would be an issue! Never had any issues with a spin-on installation and removal. Easy to install by hand tight and then remove with whatever tool you want!
  8. Mendel Leisk
    41,525
    It’s a perfect fit, heavy-gauge, stamped-steel. Never any problems.
    Extra deep sockets with slots to match certain permanent housing stiffeners seem pointless to me, just make them proprietary.
    I’d recommend use of a medium or light duty torque wrench (3/8” or 1/4” drive). Torque for the permanent housing is 18 (ft/lb) and 13 for the spin-on conversion (which I’ve done).
    Georgina Rudkus and Dave1UK like this.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,435
    Taylors, SC
    I agree with Mendel.
    Over the past 13 years, I've tried and used more than 10 different wrench sockets.
    The only one I kept and use is the Honda one. The others; I gave away.
    I did the spin on conversion, too.
    The Honda one works with the spin-on wrench, too.
  10. AzusaPrius
    2,184
    921
    KlickWrench is available on Amazon.
    Just search the name there and you will the products.
    Dave1UK likes this.
  11. BiomedO1
    3,673
    1,907
    SacTown, Ca
    If you put a thin film of oil on the canister o-ring before re-install; those housings don't stick. You'll have an easier time removing them next time around. Properly torquing them down or just hand-tightening without any tools also works.
    Good Luck
    Dave1UK likes this.
  12. Dave1UK
    66
    London, UK
    Active
  13. Mendel Leisk
    41,525
  14. Dave1UK
    66
    London, UK
    Active
    Yeah I saw the eBay listings (US based) but they are quite pricey with shipping incl. Even with the link you provided that would be shipped from somewhere in the EU I'm assuming as price quoted is in Euros.
    I may give that Honda link a go the cheaper one (as it does seem to look durable?) whether the fit will be good is another story. If that fails no harm done, guess will have to pay up.
  15. Mendel Leisk
    41,525
    I got the Honda one in 1990. Back then the automotive ones were larger; I got that one for a motorcycle. Now it’s the size for cars, I found Honda, Toyota and Mazda oil filters are all the same.
  16. Dave1UK
    66
    London, UK
    Active
    I saw listings for motorcycle one as well which were way cheaper see linked:
    https://www.ebay.co.uk/itm/292186105940?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220405142716%26meid%3Dd17485abeda948b4bae6ec593dbe973e%26pid%3D101506%26rk%3D2%26rkt%3D10%26sd%3D272775095910%26itm%3D292186105940%26pmt%3D0%26noa%3D1%26pg%3D4481478%26algv%3DDefaultOrganicWebWithV11WebTrimmedV3VisualRankerWithKnnV3AndUltBRecallAndCassiniEmbRecall%26brand%3DHonda&_trksid=p4481478.c101506.m1851
    HONDA CBR 1000 RR CBR900 FIREBLADE OIL FILTER REMOVAL WRENCH TOOL 65MM 14 FLUTES
  17. Mendel Leisk
    41,525
    That looks distinctly different than mine, fwiw:
    (embossed number different as well, but maybe normal, since from 1990)
    #17 Mendel Leisk, Oct 22, 2025
    Dave1UK likes this.
  18. CR94
    CR94 Senior Member
    2,696
    1,174
    Northwestern S.C.
    Yes, and preferred. The ones with "fin engagement" tend to break off the fin, because they engage the fin before the 14 flutes.
    After the dealer overtightened my filter cap, I broke my stamped steel cap wrench trying to get it off. I finally got it loose using a PBT 7117 machined steel cap wrench, shimmed with a strip of aluminum to ensure snug fit on the flutes. That tool was about $25 through Amazon. There are similar ones of other brands.
    #18 CR94, Oct 31, 2025
    Dave1UK and priumium like this.
  19. priumium
    priumium Member
    258
    66
    Sweden
    2013 Prius Plug-in
    I use this one, works on gen2 and gen3 naturally.. I know it’s Swedish Amazon, but surely reasonably priced at apx 10usd and does the job lovely… As noted those grooves are not needed or ideal for gen3 plastic housings.
    Amazon.se
    CR94 likes this.
  20. CR94
    CR94 Senior Member
    2,696
    1,174
    Northwestern S.C.
    That model looks practically identical to the one I said (in post #18) I broke on a my stuck filter cap.. It was, as you say, "lovely," the previous times I used it, when the cap hadn't been overtightened.
    #20 CR94, Nov 6, 2025
    priumium likes this.
