Gen 3 SKS Antenna locations?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dale UK, Oct 14, 2025.
  1. Dale UK
    Dale UK New Member
    UK
    ----UK----
    I am trying to troubleshoot the code DTC (B1242 Wireless Doorlock Tuner circuit) on my 2010 Prius I have no SKS function at all and need to hold the Key fob to the start button to start the car, I did have someone run into the drivers door before all of this started but it was working up until I had a flat 12v battery and then I noticed the key fob was not being detected, even had a car locksmith come to make a new key fob but that did not work either, he said his scanner was detecting a fault on the SKS system?
    I scanned it myself using a Techstream interface I bought off Amazon and got the code B1242 Wireless Doorlock Tuner circuit, I have had the drivers door panel off and had a look at the SKS sensor and it all looks fine, does anyone know where all of the sensors/antennas are located there is somthing located near the high voltage battery that looks like an Antenna but I cannot be certain are there any behind interior panels or body panels that you know of?
    Some photos attached
    Any help greatly appreciated.
  2. Tombukt2
    13,141
    2,360
    Look at all the door wiring is everything in good shape when the door got smashed nothing got crushed? You got a new door and they pulled you're wiring through that or used the doors wiring as from salvage?. So the door wiring is your original or came with the salvage door that you had to buy to put on the car ? Or this is all worked fine since the accident this is a new problem!
  3. Dale UK
    Dale UK New Member
    UK
    ----UK----
    The door dent was only minor more of a scrape then an actual impact but the insurance company replaced the door from what I could see after I took the inner door panel off, it came back to me with a fully working SKS system no problems at all otherwise I would have got them to sort it out, the problem really seemed to arrive after I had a 12v battery go flat on me, I have replaced the 12v for a brand new one also the Fob Battery is also new, I noticed every now and then the function of the SKS would randomly return but only for a short time?, when I clear the B1242 Code from Techsteam it reappears after a few seconds?
  4. ASRDogman
    ASRDogman Senior Member
    7,656
    3,940
    How long ago did they replace the door? They had to move everything over.
    They easily could have damaged a wire, and it gets moved just a little to become an issue
    somethings.
    You should contact your insurance company and let them know the issue and what they will do
    about it.
    Unless it's been months and months....
  5. Dale UK
    Dale UK New Member
    UK
    ----UK----
    Thanks for trying to help with this, Its well over 12 months since the accident and when the SKS problem arrived I thought it was because of the 12v battery going flat not long after getting the car back from the insurance, so I recharged it and carried on with that battery, I should have wrote down the sequence of events but the SKS problem just appeared later and I thought it was the Key Fob battery so replaced that, I changed the 12v battery a few weeks ago because that kept losing charge and the internet seemed to think that the 12v battery can be the source of SKS problems, but the SKS problem still remained, the odd thing is around 4 months ago the Keyfob was suddenly working and was detected by the car but it did not last long just a few hours, I thought it had cured itself, the wires inside the drivers door seem firmly in place and I pulled the wiring plugs and re-seated them just in case but it did nothing for the SKS problem maybe I need to have another look?, I bought a cheap Techstream interface to hopefully get an exact diagnosis but its saying "Wireless Doorlock Tuner circuit" but that could mean any part of the SKS system not a specific module or antenna or its location on the car, does the Gen 3 have a SKS door lock control module behind an interior panel anywhere in the car that you know of?
  6. Tombukt2
    13,141
    2,360
    .no Gen 3 here anymore I'd think should be something mud car like console area and rear of car gen2 hast it right next to hybrid battery white with dark red writing on .I do not have a gen3 book set
  7. Tombukt2
    13,141
    2,360
  8. Dale UK
    Dale UK New Member
    UK
    ----UK----
    Thanks again for the assistance, I will see if I can find the one inside around the centre console area it does not say exactly were these things are, I found somthing near the High Voltage battery but the diagram you linked shows one behind rear bumper, I will try all the easy location first, hopefully I will get a result?
