Hybrid Battery Troubleshooting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by trevansg, Oct 12, 2025 at 7:34 PM.
  1. trevansg
    trevansg New Member
    Sunday
    Provo UT
    Hello, I'm looking for some help diagnosing the Red Triangle of Death on my 2005 Prius. The triangle came on a few weeks ago, and since then I’ve noticed a loss of acceleration power and the fan running loudly in the back. I tried running a test with Dr. Prius, but it wouldn’t complete because the battery was too cold or something. I decided to open up the battery pack and test all the cells individually, following the instructions in a video using a Harbor Freight battery tester. I recorded the results in a spreadsheet, and I’m not seeing anything that looks particularly bad, but maybe I’m interpreting it incorrectly. The lowest health status was 60%, and most were 85% to 100%. None of the internal resistances looked too high either. Would that be enough to trigger the triangle and cause these issues? My other thought is that the green corrosion on the bus bars might be causing problems, or maybe it’s a bad inverter cooling pump or dirty fan.
    thanks!!
    CELL, Health, Volt, Internal Res (mOhm)
    1 83 6.5 6.23
    2 100 7.65 4.9
    3 100 7.73 4.88
    4 100 6.72 5.25
    5 100 7.65 4.86
    6 60 7.23 7.29
    7 100 7.66 4.87
    8 85 6.39 6.16
    9 100 7.78 5
    10 100 7.77 4.92
    11 100 7.62 5.31
    12 100 7.06 5.59
    13 100 7.86 4.96
    14 100 7.87 4.96
    15 100 7.66 4.92
    16 100 7.87 5.02
    17 100 6.92 5.27
    18 100 7.42 5.11
    19 100 7.67 5.01
    20 100 6.61 5.2
    21 100 7.72 5.04
    22 100 7.7 5.11
    23 100 7.39 5.11
    24 100 7.66 4.98
    25 100 7.68 5.06
    26 100 7.1 5.18
    27 100 7.51 5.31
    28 89 6.35 6.02
  2. PriusCamper
    PriusCamper Senior Member
    12,449
    5,043
    Pacific Northwest, USA
    What were the error codes?
    Brian1954 likes this.
  3. bisco
    51,615
    clean the corrosion first, and replace the sensor wire
  4. ChapmanF
    17,835
    ^ This.
    May as well find out for what reasons (out of the couple hundred possible) the car has shown the triangle, before just starting to do things.
  5. PriusCamper
    12,449
    5,043
    And I'm willing to look at those battery module voltage and capacity numbers, but my morning coffee hasn't kicked in so would prefer a frame of reference before going too deeply down this very familiar rabbit hole.
  6. Brian1954
    Brian1954 Senior Member
    2,044
    795
    South Central PA, USA
    The voltages of the 28 modules are all over the place. A static reading of healthy battery modules should not vary by more than 0.10 volts of each other. My guess is that the trouble code that occurred was P0A80 " Replace Hybrid Battery Pack".
  7. PriusCamper
    12,449
    5,043
    That's common if a failed battery pack sits for a while. As in this these numbers may be just self discharge data. As in modules that have self-discharged the most should be noted on the spread sheet to further the pack diagnosis. There's a dozen additional types of data points for evaluating a module/pack you can read about on PriusChat.
    Resting voltage isn't as good of a data point compared to module voltage loss after 2 minutes under load from a 50w/12v bulb.
    But this is just preliminary data... I'd like to see a charge and balance of the pack as well as a couple of deep cycling of the pack before drawing any conclusions beyond the replacement of failed or hot-running cells.
    All this and more is how you'll find the bad modules before they find you.
  8. Hayslayer
    Hayslayer Member
    347
    188
    Holy bejesus. I can't believe not one person has been able to give you the answer you seek. In regard to the postings above, the OP stated:
    "The triangle came on a few weeks ago, and since then I’ve noticed a loss of acceleration power and the fan running loudly in the back."
    Which means the battery had probably not been sitting for months before getting his voltage readings.
    Yes, your voltages are all over the place. Yes, any module that is under ~7.2v is bad and anything that has drifted down to ~7.4ish will likely be bad very shortly. A module that can be salvaged and become reliable does not drop below 7.2 volts for months and very good ones will stay 7.6 or better for several months. All the ones in the 6's? Toss 'em. They will never be worth putting back in your car. The others that are less than 7.4 may or may not be salvageable, but with the number that you need to replace, it's not worth the risk.
