New Owner of an '08 Touring
Discussion in 'Newbie Forum' started by webbmoncure, Oct 13, 2025.
  1. webbmoncure
    webbmoncure New Member
    Washington, DC
    New owner of a 2008 Prius Touring with 125,000 miles which has been very well maintained in Washington, DC. I'm looking forward to doing some baseline maintenance (oil was just changed, not sure about everything else). I drive approximately 18,000 miles a year. I haven't driven a car this complex in a few years - I didnt realize what a technical marvel these Priuses are. I think as weekend tinkerer who is fairly good with things handy in the garage, this will be a fun car.
    I am planning to do of doing the following in the first month of ownership:
    (1) replacing HID headlight bulbs, possibly ballasts if necessary (the passenger side is intermittent). I will do all bulbs while I have everything open.
    (2) transmission drain and fill
    (3) new serpentine belt
    (4) brake bleed and inspection
    (5) inspect and replace air filter / spark plugs if necessary
    (6) headlight polishing, maybe sealing with clear coat afterwards
    (7) Shampoo (bissell little green) floors and floor mats, and detail interior
    (8) wash and wax exterior
    (9) Order OBD accessories and set up a dedicated Windows Techstream machine for diagnostics.
    (10) inspect and possibly drain and fill coolant(s). I'll inspect water pump, and may replace preventatively when changing engine coolant.,
    I'm looking forward to keeping this car on the road for a long time.
    xw20_driver and bisco like this.
    52,390
    congrats and welcome. she's a beauty, all the best!
    webbmoncure likes this.
  3. Hayslayer
    Hayslayer Active Member
    461
    265
    Do you have the window sticker for it? I thought all the Gen 2 models with the Touring package had the 16" 7 spoke rims with the 195/16/55 tires and different shocks (springs?)
    regardless, good looking car. If you have an HID headlight that is blinking, 95% chance it just needs new bulbs. That's exactly how they start acting at EOL. Gets to the point where you have to turn the lights off, then back on again to reignite the arc for a while. Eventually they both start doing it and then the road gets real dark, real fast when the first one goes out and you don't notice, then the second goes out. Butt cheek squeezer..........don't go cheap on the light bulbs. Get OEM philips if you can.
    webbmoncure and xw20_driver like this.
  4. webbmoncure
    Washington, DC
    VIN says touring. So does carfax / Edmunds / KBB. I was wondering about that as well. I ordered two generic HID’s with good reviews. The shocks feel somewhat spent and I was going to get the KYB shock spring combos and swap them out on a weekend. What’s the difference between the touring ones and regular?
  5. bisco
    52,390
    some have replaced with smaller wheels for a better ride
  6. xw20_driver
    xw20_driver Member
    101
    53
    PNW
    I have a 2007 Touring, which I think the 2008 is similar. Toyota offered 6 package options and the fully equipped Touring included: 16" alloy wheels, HID, backup camera, leather seats, tuned suspension, 6 disc CD changer in-dash, nav, smart key, larger spoiler, leather wrapped steering wheel, auto climate, fog lights.
    https://priuschat.com/attachments/prius-gen-ii-packages-pdf.14971/
  7. James Analytic
    360
    Michigan
    The rear spoiler doesn't appear to be a Touring as the Touring edition is larger more like the gen 3's.
    You can also see if there are blue marks on the rear strut springs or green if still Toyota struts. If blue, then those are the Touring springs.
    Mainly, if you look at the Tire Information Label specs on the inside door frame, you'll see the 195-55R16 to confirm. The tire specs are the easiest check. If the specs are the 185-65R15, then those are base model. Europe I believe uses 195-60R15 for theirs.
    xw20_driver likes this.
  8. webbmoncure
    Washington, DC
    I have the leather wrapped steering wheel, leather interior, maps, six disc cd changer, a VIN that says touring, the door jamb says 15” factory tires. I’m wondering if there was like a weird year where the touring had 15 inch wheels or someone ordered it like that. here’s a picture of the tailgate and again the vin keeps coming up as touring.
  9. James Analytic
    360
    Michigan
    touring owners: check your rear struts | PriusChat
    Prius Base vs. Touring edition: the dirty little secret | PriusChat
    Seems common to name as and be called Touring in documents when is not. I think I've even seen noted on a title being a Touring when not in fact being was an 04. Actually, all the Touring editions I've seen oddly had only the more basic options. Literally, every one I've ever seen did not have leather seats or have the navigation MFD. I've only picked maybe four at self serve yards and got the spoilers from em all and two the rear struts. Though the only difference that I am aware of are the strut springs, sway bars, rear spoiler and 16" rims and tires.
    Two of my base models, one leather with JBL and one not, have the touring spoilers installed currently. One has the Touring struts in the back awaiting install. Another one will probably have a Touring spoiler installed once I paint, along with the other pair of struts.
    So, long story short is there is no reason you can't convert yours into a Touring package. :)
    #9 James Analytic, Oct 17, 2025
  10. xw20_driver
    xw20_driver Member
    101
    53
    PNW
    I wouldn't sweat the differences between the base and touring branding. The visible clues for the true touring are the 16" 7 spoke dark bronze wheels, longer spoiler, and "tuned" suspension. This year I replaced the factory shocks and struts on my 2007 touring with KYBs and kept the original springs. Those 18 year old shocks were not leaking but have definitely lost their dampening functions. The touring's upgraded sway bar was only 1 or 2mm difference over the base edition. Supposedly the better upgrade is to pull the rear sway bar from a Corolla or Matrix to have noticeable handling improvements.
    James Analytic likes this.
  11. James Analytic
    360
    Michigan
    I like a dedicated Panlong or Veepeak OBD2 Bluetooth adapter as well with an associated dedicated cheap old smartphone with Hybrid Assistant and Dr Prius installed at least. Those two apps are excellent for gaining more info about the health metrics of your Prius, especially HV battery health and temps. Figured I'd mention as well. All my Priuses have dedicated setups with smartphone mounts for the additional heads up display.
