Alarm that cat!
Discussion in 'Gen 2 Prius Main Forum' started by edthefox5, Jan 11, 2021.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I recently bought a new car so my 07 is getting kicked out of the garage and will live at the end of the driveway now.
    I have sold its OEM cat and have a cheapie aftermarket cat that has been working good but it would really piss me off if it got stolen because they thought it was an OEM and damage the car to boot.
    So I am building a catalytic theft alarm using X10 devices.
    I have used X.10 products for years there cheap there useful and they work.
    They sell battery powered X10 motion sensors that you can buy for $5 on ebay all day long. All you need are the 3 devices listed for a system.
    The only caveat is the transceiver and the powerhorn alert box outlets have to be on the same phase in your ac panel.
    X10 works by sending signals over your home ac wiring to communicate with other X10 devices using the zero cross point of ac. For it to jump phases the signal has to go all the way out to the pole and cross over in the transformer resulting in very poor sensitivity and poor command of devices.
    If you want a 100% reliable X10 system you must install a phase coupler then transceivers and devices work pretty flawlessly no matter what outlet there plugged into to.
    To use without a phase coupler just move the powerhorn around to different outlets till it goes off then you know the transceiver and the alert horn are on the same side of the ac box. Also Helps if you know what breaker controls what.
    It also helps if the motion detectors are not to far from the transceiver. My transceiver will be on the porch very close to the car.
    I am going to mount 3 X10 battery powered motion detectors on a board and slide that board under the car at night. Anyone crawling under the car will immediately set off those motion detectors and alert me by making the powerhorn in my bedroom go off. It just dings loudly. I know this will work as I have used something similar to this using x10's many many times before.
    I have alot of Arlo cameras in the front yard but they don't work so good at the end of the driveway and if i turn up there motion sensitivity they go off all the time.
    I bet you can get all 3 devices listed for less than $40 off ebay brand new. I'll let you know if I catch any fish.
    PMS03 Wireless Motion Sensor - Controllers - X10 PRO
    PAT01 16 Channel Transceiver - Controllers - X10 PRO
    PSH02 X10 PRO Home Security Small PowerHorn Siren - Home Security
    XPCR Coupler Repeater Amplifier
    #1 edthefox5, Jan 11, 2021
    caliwaves, SFO and strawbrad like this.
  2. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    I hope this works for you. It's seems more likely to catch rabbits than fish.;)
    edthefox5 likes this.
  3. pgannon
    pgannon Junior Member
    Rancho Cordova, California
    Interesting. I, too, have used X-10 for MANY years. I'm wondering how often cats or other small animals have set off your alarm. :)
    BiomedO1 likes this.
  4. BiomedO1
    4,126
    2,168
    SacTown, Ca
    Sorry, just realized this was a zombie thread.......
    No-one is crawling under a 2007 to steal a CAT - unless it's a Smurf. The car needs to be jacked up. Just connect a mercury switch in series to your door sensor - that should trip your car alarm. You'll also need to wire a disable switch, otherwise your door ajar will be flashing while your driving.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,832
    844
    Southern California
    Parallel, no? If memory serves the door open sensor is just a spring loaded switch which is closed when the door is open (and vice versa). Open the door, switch closes, current flows to ground and pulls down a logic line which is normally at battery voltage. If the mercury switch is in series it can be open or closed when the door is shut and it won't make any difference at all because the door switch will be open.
    Put it in parallel and either the door switch or the mercury switch will cause that current and the car will think the door is open. The car's alarm must be enabled for that to make any difference though.
    pgannon and BiomedO1 like this.
  6. BiomedO1
    4,126
    2,168
    SacTown, Ca
    Yea, parallel - I think when you open the door, the plunger pops out and goes to ground.
