Prius won't start after burning smell, need help!!
Discussion in 'Generation 1 Prius Discussion' started by Kenneth Steere, Oct 17, 2025 at 6:14 PM.
  1. Kenneth Steere
    Kenneth Steere Junior Member
    Richardson, Texas
    2004 Prius with 228,000 miles. Won't turn on. Can't put into neutral.
    Last week the Red Triangle was intermittently coming ON and OFF. Before I could get any code from from my OBD reader using the TORQUE app, the light would turn off. I assumed it was the big battery as it has been many times before. I thought maybe a bad contact on the bus bars of the traction battery. This went on for several days with me trying to get a error code to no avail.
    Well it wasn't the traction battery as I found out when I drove home at noon on a hot day last week.
    On opening the door we could smell rubber or a plastic burning smell. My wife said she saw smoke coming out of the hood on the passenger side. I ran into the garage thinking it was something burning in the garage, but it was the car. When I got back in it to try and turn it on, the combination meter/gauge started blinking (all the lights) and then went off and the Start button was blinking red. I can push the start button ONE TIME and the screen comes on and the Windows and door locks work, but if I press it again, it crashes. The car could not be put into neutral.
    I had it towed to the dealership and they said it needed a combination meter because it would not turn on and so they couldn't get any codes. They wanted $1500 for this. I had it towed back and took the meter out and sent it to be repaired. The shop could not find anything wrong with it, although I think they just checked the capacitors that are known to fail.
    I thought it was the inverter and I ordered a used one. When I took the cover off the old one (still in the car) it was perfectly clean with no signs of smoke or anything burned. I'm stopping here and am not sure what to do next except install a refurbished combo meter/gauge from Texas Hybrids and see if I can get it into ACC mode to AT LEAST retrieve an error code but should I find what burned first? Could it have been the electric motor of the synergy drive? I'm very confused now.
    (you can see the pics of inside the inverter. It looks VERY clean)
  2. ChapmanF
    17,846
    You've posted this in the gen 1 forum, but if your car is a 2004 then that inverter cover probably says Hybrid Synergy Drive and you've got a gen 2 car.
    In the gen 2 forums you'll find this picture a lot. Unplug the circled plug first ... then replace the arrowed fuse.
    With that plug unplugged, if you've got the usual problem, you won't blow the new fuse right away, so you can drive, gently, until you are able to replace the pump that failed. Don't reconnect the unplugged connector until a good pump has been installed.
    Kenneth Steere likes this.
  3. Kenneth Steere
    Richardson, Texas
    I thought I posted in the Gen 2 forum. Don't know how that happened.
    I did replace the inverter coolant pump 5 years ago off amazon
    I'm not sure why my combination meter went out though right after the smoke.
    So are you saying that after replacing the combo meter I should do this procedure before trying to turn it on?
